Old Jan 07, 2013, 08:51 PM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Question
Connecting Cells in Parallel: Can This Be Done?
Hi All,
I have two 4s 5300 mAh 4s lipos that are both brand new. One of them arrived with one cell completely dead (0.7V). It is beyond the warranty period (I should have checked individual cell voltages when I got them). I realize that I could try to tickle charge the dead cell using the NiCd/NimH setting on my charger, followed by finishing the charging off with the charger's lipo settings. However, I imagine that the cell has been dead since arrival (4 months ago), and that not only is it probably irrecoverable, but the original problem that caused it to die is likely to remain even if I can successfully charge it (after all, how could it have gotten discharged in the first place?).
So, I would like to combine the two packs in parallel: the 4 cells of the good battery with the 3 cells of the bad battery. In other words, the idea would be to produce one 14.8 V 9275 mAh battery (5300 + 5300(3/4)). Can this be done without too much trouble? I have already combined a 4-cell and 1-cell lipo to form a 5-cell lipo before. I have also removed cells from lipos in order to decrease overall voltage. Therefore, I think I have the technical skills to do it; but, I don't know how it can be done in theory, including dealing with the balancing leads. Any input about how this can be done or whether I should go ahead and try to revive a dead cell that's likely been dead for quite some time, and whose original loss of charge is unknown?
AEM
AEMontoya is offline Find More Posts by AEMontoya
Old Jan 08, 2013, 01:47 AM
Roguedog is offline
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
AEM
Not going to work in parallel as the dead cell will drag down its parallel brother. In the example you gave you combined in series ending up with a 5 cell lipo for a total of 18.5 volts
If you really want to geek out on that bad battery cell you could always find another 2 or 3 cell lipo that has the same mahand size, canibolize one cell out of it, and try to replace the bad lipo cell battery in the 4cell pack. Would make a good build thread or how to thread with pics.
I found replacement lipos for my 18volt Ryobi battery packs thatt went bad on ebay. Cheeper to replace the bad lipos than to buy new battery packs.
Roguedog is offline Find More Posts by Roguedog
Old Jan 08, 2013, 03:15 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
To connect in parallel you MUST have the same number of cells/overall voltage. You've got a 4S and an effective 3S. It won't work and if you try it will almost certainly kill your one good pack.
BTW this is the sort of question that's answered every day in the Batteries and Charger forum. http://www.rcgroups.com/batteries-and-chargers-129/ It doesn't really fit in DIY Electronics...no electronics involved .
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 09, 2013, 10:39 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Okay, guys. I got it. Thanks. Sorry about posting in this section. I looked around for one on batteries, but must have missed it.
Discussion how close should lipo voltage be when connecting in parallel? Eddie500 Batteries and Chargers 6 Sep 27, 2012 06:49 PM
Discussion Sorting Classifieds by States ??Can this be done? eng30 Trader Talk 5 Aug 11, 2012 09:40 PM
Discussion This can be done with RC Belive me Kr1st1an Aerial Photography 5 Mar 09, 2012 09:54 AM
Question LiON Lithium Ion Batteries - Can the cells be put in parallel ???? JettPilot Batteries and Chargers 4 Aug 17, 2005 08:37 PM
Can (2) Walwart power supplies be connected in parallel? mrebman Batteries and Chargers 4 Feb 21, 2005 10:33 AM
