Old Jan 07, 2013, 07:23 PM
Carnifax is offline
Find More Posts by Carnifax
Carnifax's Avatar
Cleveland
Joined Jun 2002
Question about covering
I am building a larger airplane (Travel Air 6000 biplane) with a 10' wingspan. It will be static only so I wont have to be as worried about weight, etc. My question relates to the covering. I need a cheap covering method. I have been contemplating cellophane from the Dollar Store and held down by elmers glue.
This is not going to be a scale masterpiece, only used for a discussion about early aviators. Does anyone have any suggestions that they've used successfully in the past?
Any ideas would be appreciated.
Thank you.
Carnifax is offline Find More Posts by Carnifax
Old Jan 08, 2013, 04:25 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Something like cellophane could be used. May some Stix-it or Balsa-rite could be used for an adhesive???? then iron on the cellophane???? I have no clue the melting point of cellophane.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: I looked and I looked and I...
Old Jan 09, 2013, 12:37 AM
Carnifax is offline
Carnifax's Avatar
Cleveland
Joined Jun 2002
That's what I was thinking too. In review, Im going scale back the span back to 60". I will have to try some experiments with the cellophane and post the results. Thanks for the response.
Old Feb 11, 2013, 09:11 AM
vinnieg is online now
Find More Posts by vinnieg
vinnieg's Avatar
United States, NJ, Edgewater
Joined Feb 2012
I have been using cellophane gift wrap from the dollar tree to cover DTF planes. It comes in clear, red and green tints and is transparent. I spray 3M-77 on the cellophane, let it dry for about a minute and then stretch it across the foam. Once tacked on, I use my iron to remove the wrinkles. It shrinks quite a bit.
Yesterday I tried it on balsa tail fins and it worked well also. I will be trying it to cover balsa built up wings next. How did it work out for you ?
vinnieg is online now Find More Posts by vinnieg
Old Feb 13, 2013, 09:37 PM
Carnifax is offline
Carnifax's Avatar
Cleveland
Joined Jun 2002
I havent tried it yet.
Old Feb 14, 2013, 06:10 AM
Bob Mears is offline
Find More Posts by Bob Mears
F2D Pilot/Mechanic
Bob Mears's Avatar
United States, TX, Lubbock
Joined Dec 2011
Make sure you test it with your iron before you install the stuff. Its actuall colored on one side. If you get the color side up, you will melt off the color. So keep the color down. You can also test it by using airplane fuel, or carburator cleaner to rub off the color. The stuff shrinks great at a fairly low temp. I use 3m77 and spray it on the framwork then tack down the covering, and heat shrink it. Another alternative is laminating film. It doesnt come in colors, but I have sprayed the backside of it with rc car paint with great results.
Bob Mears is offline Find More Posts by Bob Mears
Old Feb 14, 2013, 09:16 AM
Carnifax is offline
Carnifax's Avatar
Cleveland
Joined Jun 2002
cool, that makes sense. I appreciate the advice,
Dan
Discussion Bird of Time Question Covering Question Jordonr Sailplane Talk 3 Mar 30, 2012 09:30 AM
Question about battery cover... Dave B Batteries and Chargers 2 Jul 16, 2003 08:59 AM
About to cover with CoverLite (Litespan clone)... Iron question. Fred Methot Parkflyers 18 May 30, 2003 01:11 PM
quick question about covering a zagi thl thor4944 Foamies (Kits) 7 Nov 10, 2002 11:20 PM
Quick Question About Covering the Deans Connectors after Soldering... cincyfler Parkflyers 8 Jun 03, 2002 10:20 PM
