Old May 08, 2013, 05:55 PM
Mrtarango32 is offline
Find More Posts by Mrtarango32
Mrtarango32's Avatar
United States, CA, Glendora
Joined Oct 2012
Originally Posted by ianhowser View Post
Don't know if this any help to anyone and I am new to all this gimbal stuff but with the help of posts on here I think I have it dialled in pretty well. Been out tonight in 30 Mph winds and the footage is still very usable and my hex was all over the place. When I connect to the USB, the assistant software doesn't see the controller unless I power my the gimbal as well. Once I am connected I am able to disconnect the gimbal power and make adjustments and write to the controller. I have found if I disconnect the power then set the balanced yun-1 in the correct level position and then calibrate it works a treat. I can then enter the settings I want and voila, nice working gimbal.
just tried this method. didnt work for me
i have downloaded and updated the drivers however once i plug the yun-1 to usb the yun-1 isnt detected under my computer or assistant, but i do hear the chime once i connect it to the usb
Mrtarango32 is offline Find More Posts by Mrtarango32
Old May 08, 2013, 06:06 PM
ianhowser is offline
Find More Posts by ianhowser
Joined Mar 2013
If you connect the gimbal to your PC via USB only and start assistant, what message do you get under the login details?
ianhowser is offline Find More Posts by ianhowser
Old May 08, 2013, 06:11 PM
Joined Oct 2012
checking if computer connected to USB device
and itll sit like that
Old May 08, 2013, 06:14 PM
Joined Mar 2013
So at that point if you power the gimbal from your lipo and leave for 30 secs, does that message change?
Old May 08, 2013, 06:25 PM
Joined Oct 2012
stays the same...
i keep thinking i downloaded the assistant and drivers wrong but i tried it 5 times. and its weird the yun-1 once connected to usb wont even come up in
Old May 08, 2013, 06:33 PM
Joined Mar 2013
stays the same...
Just checked, my connection doesn't show up in windows either but does connect to assistant using this method. Very strange!
Old May 08, 2013, 06:36 PM
Joined Oct 2012
Yes very lost here.
So your process is....
Connect yun-1 to USB
Open assistant.
Power up yun-1 with lipo
Let it sit for 30 seconds and the assistant should find yun-1??
Old May 08, 2013, 06:40 PM
Joined Mar 2013
Yes very lost here.
Open assistant.
Yeah that's how I have to do it, I am sure the first time I connected, it was USB only but now I must power up once the USB is connected. It's doesn't take 30s more like 3 but just wanted to make sure for you! Sorry this hasn't helped.
Old May 08, 2013, 06:45 PM
Joined Oct 2012
Ya it's fine. Ill keep digging at it. Or maybe some experts here will chime in. Ill try it on another computer once off work.
One thing I didn't do when I logged into the assistant register page. Was give the serial number of the yun-1 bgc
Idk if that means anything
Old May 08, 2013, 06:47 PM
Joined Mar 2013
I did put my serial number in, don't know if that makes a difference!
Old May 08, 2013, 09:42 PM
flyingdogfilms is offline
Find More Posts by flyingdogfilms
Joined Mar 2009
I seem to have a little hiccup in my gimbal. The roll is perfectly smooth and the pitch is not bad except on one point it breaks smoothness and I tilt it foward and back. It's always in the same place and if I hold it there the high pitched motor noise increases and it vibrates a little. as I move past this point it gets smooth again. I've messed around with settings in the gui but can't seem to dial it out. Anyone else run into this? Could it be my motor?
flyingdogfilms is offline Find More Posts by flyingdogfilms
Old May 08, 2013, 10:16 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Have you got video?
There's a difference between tilting the gimbal and tilting the camera. Which one is it?
Psionic001 is offline Find More Posts by Psionic001
Old May 08, 2013, 10:24 PM
badbill is offline
Find More Posts by badbill
Soylent Green is PEOPLE
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Sorry to post this in the middle of everyone's questions, but I did this video and several others today, and I am really impressed. The yun-1 is doing better than I thought it could. I am impressed.
Bill Davenport
AMA 28141
YUN-1 Brushless Gimbal , DJI Hexa 550 with WKM (6 min 50 sec)
badbill is offline Find More Posts by badbill
Old May 08, 2013, 10:39 PM
Exploroman is offline
Find More Posts by Exploroman
Explorocam
Exploroman's Avatar
Canada, ON, Ottawa
Joined Feb 2012
Bill Davenport
AMA 28141
http://www.youtube.com/watch?v=bpGbmzNef3s
Is that with stock motors?
Exploroman is offline Find More Posts by Exploroman
Old May 08, 2013, 10:41 PM
badbill is offline
badbill's Avatar
Joined Dec 2002
Yes.
Bill Davenport
AMA 28141
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1668 Feb 11, 2016 03:13 PM
Alert HOBBYWING SKYWALKER QUATTRO RC Model 20A x4 Brushless Speed Controller ESC szewang2805 Hot Online Deals 3 Sep 18, 2012 09:30 PM
New Product JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane wenney2009 FPV Talk 3 Jun 19, 2012 06:10 AM
Sold NTSC Sony CCD camera + Gimballed mount + Patch antenna and Simple OSD spbalaj FPV Equipment (FS/W) 1 May 12, 2012 09:14 PM
New Product The ROME Board or Smallest Simple Brushed/Brushless Motors Controller 26*27mm Doblao Multirotor Talk 36 Apr 02, 2012 09:23 AM
