Old Jan 07, 2013, 01:43 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Video
V22- Osprey (Foamy) crash!
My little V22- Osprey (Osprino) crashed today
Preliminary reports from the FAA says that high winds and a lost prop saver were to blame.
RCvertt is offline Find More Posts by RCvertt
Old Jan 07, 2013, 02:11 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
That looked like a super nice plane. Did it have a gyro system?
PinkYakRC is offline Find More Posts by PinkYakRC
Old Jan 07, 2013, 09:17 PM
verticalspark is online now
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Colorado Springs
Joined Oct 2008
ouch, always hate it when something as simple as that goes wrong.
verticalspark is online now Find More Posts by verticalspark
Old Jan 07, 2013, 10:14 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Thanks. Yup its got three gyros and an accel. Works much better on a low to no windy day.
At least we found out what happens if an engine goes out. Glides just like a brick or at least a spinning one.
Old Jan 07, 2013, 10:22 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
pretty neat plane, looks like fun. Is there a thread? Plans?
whirlcap is offline Find More Posts by whirlcap
Old Jan 07, 2013, 10:39 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Thanks. No real thread on it yet. Wasn't sure if people would be interested in plans. I can try to cook some up though. This one has a flight time of only 6 minutes so I was thinking or making a slightly bigger one with some changes to increase flight time to at least 8 minutes.
Old Jan 08, 2013, 05:02 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Did it have a servo-based motor tilt system?
Old Jan 08, 2013, 09:55 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
It does. It has a servo in each wing tip that tilts the pods/motors up and 90 degrees forward.
Old Jan 09, 2013, 11:10 AM
Osprey Engineer is offline
Find More Posts by Osprey Engineer
Osprey Engineer's Avatar
Philadelphia, PA
Joined Oct 2005
Plans please
Awesome job on the Osprey. I am an engineer on that program.
Please start a thread on your version. Very cool. I am sure it is much less complicated and money than the Rotormast kit. Which means it is attractive to a larger portion of the RC community.
Were you using differential RPM for roll and yaw control?
What kind of mixing did you do?
I am sure many people would be interested.
Osprey Engineer is offline Find More Posts by Osprey Engineer
Old Jan 09, 2013, 08:26 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
I hope you don't mind my questions, but how is the post the motor is connected to attached with the servo?
Old Jan 09, 2013, 10:01 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Thanks for checking out my foamy version. You guys are doing an awesome job on the real thing. This version costs about 100$ in parts or less depending on if you already have a transmitter and such.
When flying with the pods at 45 degrees, only differential motor RPM is used to turn the plane. When the pods are 90 degrees forward the pods move for vectored thrust roll and pitch control and a little differential motor thrust is mixed in as well.
The mixing is a custom modification of the MultiWii quadcopter code. I'll have to start a thread on it so I can give some more info.
The damage was surprisingly minimal. A little hot glue on the wing and it's back in action now.
V22-Osprey (RC Foamy) repaired (3 min 48 sec)
Old Jan 09, 2013, 10:05 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Questions are very welcomed. The video is about to be bumped off the front page so I'll have to start a thread soon so I can keep an eye on it better.
The pod has a servo horn hot glued into it which is screwed into the servo horn that is on the servo. So it's directly attached to the servo.
Old Jan 25, 2013, 10:09 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Hi RCvertt.
Verry good indeed..The code for osprey where i coul find!?
Best regards!!!
nadine is offline Find More Posts by nadine
Old Jan 25, 2013, 05:06 PM
Edmonds is offline
Find More Posts by Edmonds
Herndon, VA
Joined Oct 2005
How does that control pitch? Clearly it is doing a good job, you can clearly see the closed-loop pitch behavior when it is hovering.
RE
Edmonds is offline Find More Posts by Edmonds
Old Feb 26, 2013, 11:55 PM
Test Pilot Mafia is offline
Find More Posts by Test Pilot Mafia
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
I want technical specs and pics please... or your not invited to the bicopter club! very cool work, its nice to see someone got a control loop right (with transistion), i botched my build multiple times for 3 years.
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Video V22 Osprey (Foamy) RCvertt Electric Plane Talk 0 Dec 29, 2012 11:25 PM
New Product Art-Tech V22 Osprey darwincai Micro Helis 6 Aug 31, 2012 12:35 PM
Sold V22 Osprey billnj2002 Aircraft - Electric - Multirotor (FS/W) 6 Jul 26, 2012 03:00 PM
