Espritmodel.com Heli Air
Old Mar 03, 2013, 05:23 PM
Ancaster, Ontario, Canada
Joined Oct 2005
Nylon bell cranks are now the choice, at least if you are using multi strand led outs.
Good point on the inner hole...but it's all closed up now.
So, how about a longer elevator horn?
Yes, I've got to finish this up, and build mine, plus a few others.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Mar 04, 2013, 12:44 AM
Joined Mar 2011
Hi George!!
The old Q-tee is a good candidate for the "britplan"? i want try a glow model and it looks easy to build and i´ve read that she is a great trainer for glow....
colibriguitars is offline Find More Posts by colibriguitars
Old Mar 04, 2013, 12:53 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by colibriguitars View Post
Hi George!!
I don't think the Q-Tee qualifies for the Britplan Build Off Rodrigo, as far as I know it was never published as a plan in a British magazine - unless someone can tell me different???
Sundancer is offline Find More Posts by Sundancer
Old Mar 04, 2013, 09:13 AM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
American as apple pie Designed by Lee Renaud, published in January 1976 RCM and kitted by Airtronics.
Ray
RFJ is offline Find More Posts by RFJ
Old Mar 04, 2013, 10:37 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Thought so Ray. The one below is called Lorelli and is also American in origin, I believe. I don't know whether it's publication pre-dated or post-dated the Q-Tee's: who was looking over whose shoulder will depend on which! But then, how many ways are there of designing a small parasol wing model???
Old Mar 04, 2013, 10:53 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Which is remarkably similar to Trixie, an RCME free plan for diesel or geared 400....
Yes, I did start one!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Mar 04, 2013, 12:16 PM
Joined Oct 2005
Peacemaker- "Britplan" Build Off - 1st January 2013 to 30th June 2013
The Peacemaker, Aeromodeller, 1958 plans service qualify.
It was designed by George Aldrich conforming to the then UK normal combat model size (2.5 - 3.5 cc) specifically for publication in Aeromodeller.
This is a build log.
Old Mar 04, 2013, 01:09 PM
Joined Nov 2008
My apologies, John....
Old Mar 04, 2013, 01:24 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
My apologies for screwing your build log up John; it was just that Rodrigo (Colibriguitars) for some reason posted a question which I decided needed an answer in the same place, then it got slightly out of hand.
Back to the Peacemaker!
Old Mar 04, 2013, 02:19 PM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Pre-dated by a long time. Lorelei was a free pull out plan in the April 1965 edition of RCM.
Ray
Oops - just read post #52. I'm outa here
Old Mar 05, 2013, 11:43 AM
Joined Oct 2005
No problem gentlemen.
I guess it keeps readers more interested than the build.
Maybe I'm doing something wrong, or U/C is too boring.....
Anyway, it's a fun build, remembering to do a few past things, realise changes are always easier to do before you have done something and have to "fix it" , etc.
Just hope Bill gets a few good flights.
Maybe I'll re-cover the Flite Streak for a practice run and get a few laps in?
John
Old Mar 09, 2013, 03:12 PM
Joined Oct 2005
Peace Maker build
I’m just about done with the Peace Maker.
I talked with Bill to-day. He might have some model diesel fuel.
Anyway, he said he got out flying and had several really good flights to-day.
Now why didn’t I go out? Darn!
I got side tracked with the Doculam covering and decided that I might try a little of it here.
In fact, this model will have a little of everything. The rudder, stab/elevator are tissue covered,
the balsa fuse is painted, one wing half will be Doculam, and the other plastic. If we don’t like
the Doculam, then it can be covered over with the plastic.
One advantage of the clear covering is that it makes a good covering/protection for the “decal”.
John
Old Mar 09, 2013, 04:29 PM
Dog is my co-pilot
brokenspar's Avatar
Denver, CO
Joined Jan 2004
Looking good....
brokenspar is offline Find More Posts by brokenspar
Old Mar 16, 2013, 10:37 AM
Joined Oct 2005
Work continues on the Peace Maker. Bill’s is almost finished. It has Doculam covering on only half of the wing. The model just needs the elevator horn, push rod and single LG leg added.
Also,the engine and tank will have to be fitted.
Working on the second wing should have gone much quicker, but it hasn’t.
I cut the spar depths just a little too shallow and didn’t catch this until gluing in the top spar which is standing maybe 1/100th inch proud.
Not really a problem, but when you know there is an error it just stands out and waves its arms.
Of course this isn’t really a worry on a combat plane!
I ordered control line parts from MBS Model Supply at mbschuette@cox.net.
Email "Melvin Schuette" <mbschuette@cox.net>
for bell cranks and flying lines, Nelson plugs and led out wire. Great service. Got the parts all within a week. And much nicer than I had expected.
Bill’s Peace Maker has a Perfect metal bell crank (BC), the only one I had at the time.
Now I have a 3 inch Sig (BC) which is a little larger and took a little/lot, more fiddling to get it installed and moving perfectly. I had to open up the centre ribs a lot more for clearance.
And, Greg suggested that additional braces should be added to the BC mount. This has been done.
John
Old Mar 19, 2013, 09:19 AM
Joined Oct 2005
more pictures
ooops, hit the key too soon.
Build Log Dart Kitten - Britplan Build Off January 2013 to June 2013 Colonel Blink Vintage & Old-Timer Designs 211 Yesterday 08:43 PM
Discussion Cyril Shaw "Envoy" - Britplan Build Off January 2013 to June 2013 cpmcgraw Vintage & Old-Timer Designs 254 Yesterday 07:04 AM
Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Half Time Update Post#156 Sundancer Vintage & Old-Timer Designs 196 May 15, 2013 03:08 AM
Build Log "TV" Sparky (Aeromodeler 1951) - Britplan Build Off January 2013 to June 2013 hoffboy Vintage & Old-Timer Designs 11 Feb 11, 2013 11:25 AM
Discussion K. Edgerton "King Harry" BritPlan Build off January 2013 - June 2013 Doncrashum Vintage & Old-Timer Designs 4 Jan 14, 2013 05:30 PM
