This thread is privately moderated by edwen303, who may elect to delete unwanted replies.
Old Jan 07, 2013, 11:37 AM
edwen303 is offline
Find More Posts by edwen303
edwen303's Avatar
United States, CA, Corona
Joined Jan 2010
Concorde twin 55mm EDF
Hindthought about Concorde:
It would be nice to build a bigger, twin 64mm or twin 70mm EDF, larger scale, with retract and nose-dropping features. Of course, make her nose and/or tail detachable for transport.
She is fairly easy to fly even underpowered. I learned to turn her without losing too much altitude. It is better to lose some speed than to lose altitude. Airfoil should not be that complicated. Even flat airfoil should be fine, although I did carve some undercamber right behind the LE.
My build is a little too heavy so I add some power for landing. Well which manufactured EDF don't need power for landing? At least most of mine EDF need power to land anyway.
I use the nose from a foam glider as Concorde nose, all the rest mainly use Blue-cor, 6mm Depron with carbon rod reinforcement for only v-stab. Peel off the skin from the Blue-cor makes it easier to glue and bend.
The wing is mainly glued together from overlaid two sheets of Blue-cor, with three reinforcements across the wing. On top of this, I use one 3 feet long ~10mm diameter CF tube to reinforce the fuse. The full scale is so long that the passengers sitting at both ends of the plane can see the bending of the fuse when the plane was turning at speed. I use nichrome wires to join the CF tube and the CF strip. I used bamboo skewers to reinforce the front part of the wing, to save the cost.
The blue-cor sheets were prebent to feature the famous Concorde anhedral. I use a rod with ~2" diameter to roll over the peeled foam sheet upon sofa pad. There is at least online video showing the technique.
Another feature in my build is the use of carefully applied masking tape for added strength and look. Beware that the tape might get wrinckled after applying water-based paint and the paint might not hold well if the tape is not sanded. Also the end of the tape might peel off on its own over time or even right away. Use some foamsafe CA or GWS glue to seal the ends of the tape.
These are some of my thoughts on the build. Don't have the time to start a build thread in RCG.
More photos from Ron Keith at circlecityfliers.com:
edwen303 is offline Find More Posts by edwen303
Old Jan 11, 2013, 09:51 PM
edwen303 is offline
edwen303's Avatar
Joined Jan 2010
more build photos
Here are some photos I took during the build.
Old Jan 12, 2013, 01:50 PM
MrConvair is offline
Find More Posts by MrConvair
Rc planes having flown
Holmes PA
Joined Jan 2010
Really Cherry Edwen my buddy is building a couple Concordes to, she looks great in the air!
MrConvair is offline Find More Posts by MrConvair
Old Jan 15, 2013, 01:02 PM
edwen303 is offline
edwen303's Avatar
Joined Jan 2010
Thanks MrC! Keep me posted about your buddy's build. The key is building her light or more power. I wish I can have >500W for this 2.5 lb bird.
Sold Twin 55mm EDF Setup wkener2 Aircraft - Electric - Jets (FS/W) 6 Aug 07, 2012 04:04 PM
Discussion resurection: F-22 twin 55mm EDF- need advice NickFox Foamy EDFs 0 Jul 02, 2012 03:21 PM
Sold F-22 twin 55mm edf kit hi2nr Aircraft - Electric - Jets (FS/W) 4 Mar 27, 2012 11:37 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 06:28 PM
Discussion Twin 55mm edf twin setup getting hot ?? buddman36 Electric Plane Talk 8 Mar 20, 2011 07:47 AM
