Old Jan 07, 2013, 09:22 AM
Theo911 is offline
Find More Posts by Theo911
Joined Jan 2013
New Syma S107 for nephew not working properly help please
Hi Everyone my wife and I bought a Syma S107 for our nephew and it charges up fine and the controller green light is solid (not blinking). The light on the heli blinks initially then turns solid green after it autobinds with the controller (on either A or B). BUT, the heli does not respond to the controller inputs unless I hold the heli in one hand and move the controller around to certain angles around the heli which causes the signal to somehow get through. Obviously it wont fly properly like this. Has anyone heard of this problem or is there a known issue with the controllers? Can I fix the controller somehow? We purschased it on Amazon and I dont think its a knockoff. Thanks
Theo911 is offline Find More Posts by Theo911
Old Jan 07, 2013, 09:25 AM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
You do understand this heli is infrared, right?
No line of sight with sensor, no fly.
Steve_ is offline Find More Posts by Steve_
Old Jan 07, 2013, 09:33 AM
Theo911 is offline
Joined Jan 2013
Thanks Steve I'm learning and very much a newbie to rc helis. So since it is infrared is there a proper angle that the heli should be used at? I would assume that the IR sensor would have a widely accessible "sweet spot" that would receive signals from the controller if its all working properly. When I'm trying to get it to work the heli is on a table and I'm holding the control just a few feet from it pointing it at the heli.
Old Jan 07, 2013, 09:43 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Low transmitter batteries will make it do that, try some new ones.
I don't know if it charges from the controller, but if it does, it will drain
AA alkaline cells flat in one day.
Replace the transmitter batteries, and do not charge helicopter from it.
Old Jan 07, 2013, 09:47 AM
Theo911 is offline
Joined Jan 2013
I will try that Steve and report back much appreciated.
Old Jan 07, 2013, 03:13 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Keep it away from big screen TVs and any kind of florescent lighting. They cause lots of interference even if they are not in the line of sight.
Balr14 is offline Find More Posts by Balr14
Old Jan 07, 2013, 10:15 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Bright light--window or outdoor--blinds the IR.
Confirm all 3 LEDs in the sender dome are working. Look at it with a cellphone camera while operating the throttle (heli off at this time).
arbilab is offline Find More Posts by arbilab
Old Jan 08, 2013, 06:11 AM
overedline is offline
Find More Posts by overedline
overedline's Avatar
Chino Hills, CA
Joined Dec 2006
If you're trying to fly it outside, that is the problem. Sunlight overpowers the infrared signal from these rc transmitters. You can only fly it indoors or at night. Even sunlight coming through a window will affect it.
overedline is offline Find More Posts by overedline
Old Jan 08, 2013, 08:11 AM
Theo911 is offline
Joined Jan 2013
Thanks everyone for the suggestions. I replaced the batteries in the controller to no avail. This has all been inside during the day (and evening) btw. I am 10-15ft away from the big screen and no flourescent lighting. How do I confirm the 3 LED's in the sender dome are working? Do they light up? I did notice that the LED's are not lined up perfectly in the controller dome. I just think its really strange almost like the signal from the controller is a small beam that only can communicate with the heli receiver if the perfect angle is transmitted at it.
Old Jan 08, 2013, 08:15 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
One. One broken helicopter. Ah Ah Ah.
Two. Two broken helicopters Ah Ah Ah.
(the Count, speaking of his infrared no-sunlight helicopters)
Old Jan 08, 2013, 08:35 AM
Theo911 is offline
Joined Jan 2013
I'd like to add that this heli has never flown more than a couple feet up in the air and has incurred no accidents.
Old Jan 08, 2013, 08:42 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Ah Ah Ah.
Time to replace the flux capacitor with a variable length belt.
Lining all your walls floors and ceiling with mirrors seems to help, too.
Sometimes you can use the remote to your TV to test fly the heli.
Old Jan 08, 2013, 08:58 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Seriously, take apart the TX, one or more of the IR LED's may
have a bad solder joint.
If you have no idea what I'm talking about, return it as defective.
Old Jan 08, 2013, 09:06 AM
Theo911 is offline
Joined Jan 2013
I'll try taking it apart. Can't return it because the kids had to open their gifts immediately on Christmas eve and all the manuals/boxes got thrown away at the same time. I'll probably end up ordering a new one.
Old Jan 08, 2013, 09:07 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
It would be good to have a spare on hand for parts.
You are using Alkaline cells, correct? They give stronger signal
on some TX's.
My infrared heli does not get a good signal when it's on the ground.
Only when it's flying around. Sometimes I would hand launch because of this.
Discussion syma s107 back rotor not working lames Coaxial Helicopters 5 Feb 22, 2012 07:39 PM
Discussion Syma S107 Top Blades Not Working rcpilottt Coaxial Helicopters 1 Nov 16, 2010 11:47 PM
Discussion syma s107 top blade not working rplunkett87 Coaxial Helicopters 7 Sep 17, 2010 09:26 PM
