Old Feb 10, 2013, 07:54 PM
MustangAce17 is online now
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
I still need to finish mine, maybe will tonight
MustangAce17 is online now Find More Posts by MustangAce17
Old Feb 10, 2013, 09:35 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
It's a bit of a handfull on 2s brushless, but it has nice vertical.
20130210 170635 (1 min 27 sec)
mcross is offline Find More Posts by mcross
Old Feb 10, 2013, 09:40 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Kevin Cox, The Mustang motor is the black ended 8.4mm brushed motor used in Parkzone's Ultra micro P-51 Mustang :
http://www.parkzone.com/Products/Def...ProdID=PKZ3616
There is a clone vapor brick thread here some where in the micro forums you could use (which I don't really like). But works as well. You would also have to get ahold of A GWS 30mm fan and rotor available from HK, or other sources for less than 10 bucks total (even with shipping) Foam is 3mm Pro formance foam from Great Planes or others. Perhaps I should do a build thread if there is enough demand. This is a very simple plane to build as there are only 5 peices total to the build. Rounding up the parts is not too hard and the rewards are a great flying plane for indoors and outdoors in moderate winds. Wind does not bother me with this plane unless it's simply overpowered and flying backwards. As long as I can make forward progress it flies fine.
MUTCAKE is offline Find More Posts by MUTCAKE
Old Feb 11, 2013, 01:38 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
I wonder,how it will flying,with 10mm hk inrunner and 1s...hmmm?
nadine is offline Find More Posts by nadine
Old Feb 11, 2013, 03:40 AM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Nadine, that sounds like a good idea. Oh and Kevin, Thanks for the kind words.
I have two more planes to post up next. An F-117 and BAE Hawk. I have flown the 117, and it flies very stable buy I used heavier black 3mm foam so I think it was a bit porky so will probably go to lighter white and spray black. When I work out the weight issues I will post up video and plans. The hawk is almost finished. It will have no dihedral and AET. I hope to build it so it rolls better than the P-80 I built with ailerons. I know these are only profile jets but I really want to keep it simple. And I really want to see them built. If I make enough of these many of you will make them, they are fun!
PS, I will also give the details on how much to scale them up, They are a lot of fun to fly using just a cheap old brushed 40mm and junk gear you may have lying around.
Old Feb 11, 2013, 10:13 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Mutcake,
Been keeping an eye on you guys. May I suggest a profile J-35 Draken by Vleisie. It's a profile prop slot build, but adapts well for EDF. Here's my 10" Draken build. It was my first micro EDF. You guys have me thinking of redoing the build. But I think it would be a great canidate for what your doing.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Feb 11, 2013, 02:16 PM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
ksqm,
Just watched your video, now that's was a good looking plane you built! Sounded great on 2s. I think it would work well on 1s also if it's kept light. I'd like to do some pylon racing with ours. Actually I think just about all the prop slot pusher profile jets would work.
Old Feb 11, 2013, 02:43 PM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
BTW, does anyone have thrust figures for the turnigy 1015 motor with GWS fan on 1s? I am trying to keep these to 1s only because I want to keep the weight low and I know these fly well on 1s.
Old Feb 12, 2013, 02:00 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Originally Posted by akwardflyer
so i looked through but couldn't find anything on it. what kind of thrust can you get on 1s? or had nobody actually run it on only 1S?
I think it is about 20g of thrust on one cell
I found this,in one old post..More or less,the thrust,it will be close to the 8,5mm mustang motor,me think....With 2s ,the music change
Cheers MUTCAKE
Old Feb 12, 2013, 09:39 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Thanks for the information! I really like the idea of using the inexpensive 1S configuration.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Feb 12, 2013, 11:03 PM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Kevin, if you have any of the old minimum series bricks you can use those also. I bought 2 last year from the LHS. They discontinued Parkzone Citabria fuselages with gearbox and electronics originally listed at $59.99. I got them for $9.99 each. A smoking deal IF you have the original TX, since these are not dsm dsmx compatable. I just happened to have one from years ago which i retrofitted with the ARCOX mixer so it also has servo reversing and Vtail mixing. Some of the discountinued models can be had quite cheaply if you can find them. This plane will also scale up nicely for a brushed 40mm GWS fan on light equipment. These put out 70grams thrust and will fly really well using FFF blue foam, or some thicker depron!
Old Mar 01, 2013, 01:17 AM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Sportjet 1s jet
OK, so now I just made a new 1s jet. This is an easy to build (by rolling 1mm depron to form the body like Chris Orielly's micro pitts) There is no thrust tube since it takes about 5gms thrust away. Weight is 27.5gms and the wing area is similar to the P-80 at near the same weight. I have yet to maiden it but it should fly very well. (at least that's the theory) I did not want to start a new thread for this and other 1s Jets I have cooking up. I hope the maiden goes well since the main goal is to also be able to upsize these for 40-55mm jets.
Old Mar 01, 2013, 10:05 AM
indoor_fr is online now
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Sweeeet!
I would like to build a bigger one with EPP sheets. Will you have a plan or something?
indoor_fr is online now Find More Posts by indoor_fr
Old Mar 01, 2013, 10:11 AM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
nice, I plan to make a Horton x (10) with the same design. I prefer a delta so that I would have ailerons.
minimicrorc is online now Find More Posts by minimicrorc
Old Mar 01, 2013, 11:02 AM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Yes, I will be posting a plan as soon as I get everything to line up correctly. I also have plans for making the canopy from folded depron. I hope you all don't mind that there is no bottom to the rear of this jet, or that there is a cheater hole. At this size (1s) it is difficult to have ducting as any losses are hard to make up in weight savings.. Work has not allowed me to maiden it yet so there is that to do yet.
Discussion BVM P-80 Shooting Star Electrified jets Electric Ducted Fan Jet Talk 22 Apr 28, 2008 06:23 PM
New project: P-80 shooting star eaticus Electric Ducted Fan Jet Talk 12 Dec 02, 2005 09:32 PM
Cool Which Wing Profile did the P-80 Shooting Star have? ralf dvorak Scale Kit/Scratch Built 7 Oct 13, 2005 03:59 PM
Anyone flying a LEG 60" P-80 Shooting Star? IwantaJet Slope 3 Jun 03, 2005 06:53 PM
My P-80 Shooting star project begins...I need help! ssyed Electric Ducted Fan Jet Talk 8 May 08, 2004 03:12 PM
