Old Jan 11, 2013, 03:27 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Transall C-160 build log
Now the landing gear. Make sure you have all the little parts. My kit was missing a few.
Started with the main gear. The problem is if you mount the wire gear brackets 1st then there is no clearance for the wheels to slide on. So you are forced to mount the wheels 1st and then try to reach down with a screwdrive to install the plastic brackets that hold down the wire gear assembly, not easy.
ecworks is offline Find More Posts by ecworks
Old Jan 11, 2013, 03:31 PM
ecworks is offline
Joined Sep 2011
The sequence for wheel installation is: First slide a collet on the wire, push to the end of the wire and set with set screw. Then slide on a wheel, then a spacer, none provided in kit, I used a prop hub insert. Then slide on another wheel, and then slide on another collet and tighten set screw.
Another problem, the outer wheel will rub on the fiberglass wheel fairing so I had to sand/grind in order to create some clearance:
Old Jan 11, 2013, 03:35 PM
ecworks is offline
Joined Sep 2011
Front wheel is pretty simple, the kit has all the parts. Very little room (I have big hands) to get in there to tighten the set screw for the steering arm and the final collet of the vertical wheel axle.
I've read about the bulkhead that the steering assembly is attached to needs strengthening so I epoxied a piece of basswood vertically to the bulkhead to help carry the load up to the top of the fuselage. I think I'll had more structural wood on either side of the assembly as well.
Also the height of the lower collet will establish the front wheel height relative to the fuselage. 60mm from the bottom of the wheel/tire is the recommended setting. If you have it too low it will raise the nose of the plane and also raise the front two wheels of the main landing gear so they hardly touch the ground. You know you have the nose wheel height correct when both sets of the main gear wheels are touching the ground/table equally.
Old Jan 12, 2013, 12:11 AM
ecworks is offline
Joined Sep 2011
Tail feathers now:
This is possibly the trickiest part of the entire assembly. The elevator joiner wire has a clevis that is held in place by a 4mm set screw. That same clevis has another tapped hole for a 25mm bolt that works as the attachment point for the elevator push rod. The problem is that the holes tapped in this clevis are threaded very poorly. I used epoxy just in case. Also lining the joiner wire with the holes in each elevator section is a lot of work. Use epoxy when attaching the joiner wire to each elevator. Standard CA hinges.
The slot in the fuselage for the bolt that attaches to the joiner wire was poorly cut and didn't line up. I used a dremel to get clearance but will need to clean it up by hand.
Old Jan 12, 2013, 12:14 AM
ecworks is offline
Joined Sep 2011
The rudder attaches to the vertical stabilizer with CA hinges but the slots are not opened up for you. Just slits in the covering. You'll need to cut in a slot thru the fiberglass. After 15 minutes with a razor blade I used a dremel blade instead. The actual rudder is balsa so cutting in those slots to receive the hinges was easy.
Old Jan 12, 2013, 12:57 AM
ecworks is offline
Joined Sep 2011
Weight so far:
With 1 x 5500 mah 3 cell battery: 6 lbs 15 oz.
With 1 x 4400 mah 3 cell: 6 lbs 12 oz.
I still have to install all the servos and pushrods. Looks like this will be a 7 lb bird after all.
Old Jan 12, 2013, 12:59 AM
ecworks is offline
Joined Sep 2011
I'd appreciate some observations about the Twinstar II wing installation.
I'm getting used to seeing it on the Transall but I wonder if anyone sees any problems with the angle of incidence.
Old Jan 13, 2013, 12:24 AM
ecworks is offline
Joined Sep 2011
Front landing gear steering linkage/rudder linkage. Plan on the better part of an evening to get all of this worked out. The carbon fiber rods w/ adjustable metal pushrods require a lot of trial and error to line up. My kit was missing the carbon fiber rod and linkage for the front steering gear so I use a rod I had lying around and epoxied some control rods on each end.
Old Jan 13, 2013, 12:26 AM
ecworks is offline
Joined Sep 2011
Front gear linkage test, this is not the servo I'll eventually be using
Front Steering/Rudder test (C-160 Transall RC) (0 min 33 sec)
Old Jan 13, 2013, 12:31 AM
ecworks is offline
Joined Sep 2011
Landing gear steering test:
RC C-160 Transall steering test (0 min 16 sec)
Old Jan 13, 2013, 12:33 AM
ecworks is offline
Joined Sep 2011
Thrust vs weight tests:
Current weight: 5 lbs 12 oz
Power plant: 2 x Eflight Park 480 1020 kv w/2 4 blade 9x6 props
Battery: 1 x 4400 mah 3 cell 40c
Thrust : 4 lbs 13 oz.
450 watts wot
39.5 amps
Old Jan 13, 2013, 01:41 PM
ecworks is offline
Joined Sep 2011
Working out the probable thrust with the two Master Airscrew 3 blade 9x7 props using 3 cell batteries. Using an on-line calculator they should produce close to 6.12 lbs of thrust. So with the estimated final flying weight of 6 lbs 12 oz the thrust to weight will be right at 1:1
Old Jan 14, 2013, 09:15 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
NICE-WORK! ECworks! Very cool French cargo plane your building there!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Jan 14, 2013, 11:15 AM
ecworks is offline
Joined Sep 2011
Outdoor taxi tests today. Trying to maintain a straight line while simulating a takeoff roll. Not easy using the rudder controls while also using same stick (left) for throttle. Decided to mix rudder with ailerons so I can steer on the ground using the right stick (aileron) and also added some dual rate to dampen the steering some and that did the trick.
Old Jan 15, 2013, 10:13 AM
ecworks is offline
Joined Sep 2011
French/German
Sold CMP C-160 Transall willyrobert Aircraft - Fuel - Airplanes (FS/W) 3 Dec 16, 2012 06:09 PM
C-160 Transall Chris True Scale Kit/Scratch Built 13 Jul 05, 2009 06:27 AM
Looking to buy Transall C-160 havin fun Scale Kit/Scratch Built 6 Jan 24, 2007 05:59 PM
WANTED: C-160 Transall gromitvt10 Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2002 06:24 AM
Check out the Transall C-160- 72" KOMET 44 Sport Planes 7 Aug 06, 2001 06:48 PM
