Old Jan 07, 2013, 11:48 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Transall C-160 build log
Will be using Spektrum 8 channel receiver and my DX-8i tx
ecworks is offline Find More Posts by ecworks
Old Jan 08, 2013, 10:44 AM
ecworks is offline
Joined Sep 2011
Some versions of this kit have been weighing in at more than 8 lbs which seems hard to believe when I weigh the components. Hobbyking shows that the flying weight is 2600g max (5.73 lbs) That seems be closer to what I'm finding:
Wing with servo, motor, esc, nacelle, and wiring installed: 1lb 2 oz x 2 = 2 lb 4 oz
Fuselage: 2lb 3 oz
Elevators and rudder: 3.3 oz
Landing gear assembly with wheels: 5.8 oz
Wing spar & elevator/rudder control rods: 3.7 oz
Nuts & bolts in kit left to install: 2 oz
Sub total: 5lbs 5.5oz
That does not include the radio receiver or battery.
Radio receiver: 0.5 oz
5000 mah 3 cell battery: 1lb 1 oz
Grand total: 6lbs 4.3 oz
Old Jan 08, 2013, 01:13 PM
ecworks is offline
Joined Sep 2011
The wing loading does look like a problem.
Transall C-160 with stock wing:
Wing area: 317 sq. inches
Weight: 110 oz
Wing loading: 49.88 oz/sq. ft.
Using Twinstar II wing:
Wing area: 476 sq. inches
Weight: 110 oz
33.27 oz/sq. ft.
Typical wing loading:
Glider: 10 oz/sq. ft.
Trainers: 15 oz/sq. ft.
Sport plane: 20 oz/sq. ft.
Fighters: 25 oz/sq. ft.
Old Jan 08, 2013, 06:07 PM
ecworks is offline
Joined Sep 2011
I've got one of the stock Transall wings setup but the wing loading issue has me worried so I'm setting up an alternative wing, a Twinstar II which is has 50% more wing area and looks like it will be an easy fit with minimum alterations. Even so this will be a 7lb bird so I'm going to cut in some flaps.
Old Jan 08, 2013, 06:08 PM
ecworks is offline
Joined Sep 2011
Slowed down the speed of the flap servo thru the DX-8i:
Transall C-160 build with Twinstar Wing w/flaps flap test (0 min 14 sec)
Old Jan 08, 2013, 10:15 PM
ecworks is offline
Joined Sep 2011
Painting the Twinstar II wing to work with the C-160 paint scheme:
Old Jan 09, 2013, 01:22 AM
ecworks is offline
Joined Sep 2011
Twinstar II wing on the Transall (mockup)
It's just sitting there, the angle of incidence not correct of course.
Old Jan 09, 2013, 11:51 AM
ecworks is offline
Joined Sep 2011
I order to mount the Twinstar II wing I'll need to fab a wood mounting board/saddle that will bolt in the normal wing mounting holes but will have its own mounting holes that will line up with the standard Twinstar wing mount holes. This way I can switch wings fairly easily.
Old Jan 10, 2013, 09:23 AM
ecworks is offline
Joined Sep 2011
Stock wing/Twinstar wing comparison
Old Jan 10, 2013, 11:39 AM
ecworks is offline
Joined Sep 2011
Stock wing epoxied together, rubber grommets wiring holes.
Old Jan 10, 2013, 03:09 PM
ecworks is offline
Joined Sep 2011
Stock wing wired, motored, and installed.
Wood horn in center of wing fits into a wood saddle in the fuselage holding the front of wing in place, two allen screws take care of the rear.
Old Jan 10, 2013, 11:48 PM
ecworks is offline
Joined Sep 2011
Worked on the attachment for the Twinstar II wing. Cut out a plywood deck that temporarily screws into the stock wing mount saddle using blind nuts
Old Jan 10, 2013, 11:51 PM
ecworks is offline
Joined Sep 2011
Then I used the plastic hold-down straps that comes with the Twinstar but instead of using the center hole and nylon bolt I drilled holes on either side. Then I marked and drilled holes in the plywood deck where these bolts came thru and then installed blind nuts on the underside of the plywood deck to receive the bolts coming thru the Twinstar wing.
Old Jan 10, 2013, 11:53 PM
ecworks is offline
Joined Sep 2011
Using the Twinstar strap mounts bolting to the temporary plywood deck seems to work great. It feels super strong and can unbolt and remove in a few minutes to transport or to change to the stock wing. You gain about 50% more wing area.
The angle of incidence seems to be the same as the Twinstar and a little more positive than the stock Transall wing.
Old Jan 10, 2013, 11:55 PM
ecworks is offline
Joined Sep 2011
Motor test (Eflight Park 480's 1020 kv) with 4-blade props (9x6)
Transall C-160 build motor test w/4 blade props (9x6) (0 min 21 sec)
Sold CMP C-160 Transall willyrobert Aircraft - Fuel - Airplanes (FS/W) 3 Dec 16, 2012 06:09 PM
C-160 Transall Chris True Scale Kit/Scratch Built 13 Jul 05, 2009 06:27 AM
Looking to buy Transall C-160 havin fun Scale Kit/Scratch Built 6 Jan 24, 2007 05:59 PM
WANTED: C-160 Transall gromitvt10 Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2002 06:24 AM
Check out the Transall C-160- 72" KOMET 44 Sport Planes 7 Aug 06, 2001 06:48 PM
