Espritmodel.com Heli Air
Old Jan 07, 2013, 12:22 AM
ecworks's Avatar
Joined Sep 2011
Transall C-160 build log
Starting on the Transall C-160 from HobbyKing http://www.hobbyking.com/hobbyking/s...arehouse_.html
ecworks is offline Find More Posts by ecworks
Old Jan 07, 2013, 12:27 AM
ecworks's Avatar
Joined Sep 2011
First impressions:
Very high quality, great paint job w/lettering/labels.
Also, very well packed and double boxed. No damage
No instructions but this is my 8th build so I think I can muddle thru.
Did find an instruction manual on the HobbyKing site:
http://www.hobbyking.com/hobbyking/s...X462171X50.pdf
I'm starting with the right wing glueing up the aileron. It comes with the slots already cut in and the CA hinges in place but not glued
Old Jan 07, 2013, 12:29 AM
ecworks's Avatar
Joined Sep 2011
Small wood blocks glued to servo hatch to hold the aileron servo in place. I also used amount of hot glue to attach the servo to the hatch and then used two screws to secure the servo to the wood blocks. The small wood blocks come with the kit
Old Jan 07, 2013, 12:34 AM
ecworks's Avatar
Joined Sep 2011
Then I fished some control rod thru the wing and pulled the servo wire back thru the wing and then seated the servo which is now attached to the servo hatch. Note that I needed to cut away (pic #1) some of the balsa on the wing for the wood blocks supporting the servo to clear.
Old Jan 07, 2013, 12:36 AM
ecworks's Avatar
Joined Sep 2011
I then attached the horns and clevis' on the aileron. These were pretty high quality, normally I trash the stock hardware that come with these models but the stock hardware seems high quality.
Old Jan 07, 2013, 12:40 AM
ecworks's Avatar
Joined Sep 2011
Repeated the same process on the left wing:
Left Wing Aileron test (0 min 5 sec)
Old Jan 07, 2013, 12:45 AM
ecworks's Avatar
Joined Sep 2011
Right wing aileron test:
Transall C160 build right aileron test (0 min 6 sec)
Old Jan 07, 2013, 04:33 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The C-160 brings back some memories.
I scratch built an electric powered Transall, (brushed motors, belt drives, and Nicad batteries), way back in 1991, (first flight was July '91)
She had opening rear doors and could drop a parachute load, two troopers or a pallet.
Also at the time I ran quite a small car, so she also had to fit her 80" span wings and big fat fuselage in there somehow. She became my first model that could be disassembled in a big way.
Sold it a few years later, fool.
Hope you have as much fun as I did ecworks
eflightray is offline Find More Posts by eflightray
Old Jan 07, 2013, 02:36 PM
ecworks's Avatar
Joined Sep 2011
Read many comments about the high wing loading so I'll be putting together an alternative wing (from Twinstar II) for slower, more forgiving landings.
Old Jan 07, 2013, 11:41 PM
ecworks's Avatar
Joined Sep 2011
Started work on the motors. This part is pretty easy. Used 2 x Turnigy G10 810 kv
375 watts:
Old Jan 07, 2013, 11:44 PM
ecworks's Avatar
Joined Sep 2011
Using 2 x Turnigy Trust 40amp ESCs. I removed the power wires and soldered the longer power wires directly to the power terminals and then covered with electrical tape.
Old Jan 07, 2013, 11:45 PM
ecworks's Avatar
Joined Sep 2011
Esc with power wire extensions
Old Jan 07, 2013, 11:46 PM
ecworks's Avatar
Joined Sep 2011
Motor installed in the mount and temporarily installed the 2 piece nacelle. Motor test using a Master Airscrew 9x5 3-blade tractor:
Transall C-160 motor in nacelle w/9" prop test (0 min 36 sec)
Sold CMP C-160 Transall willyrobert Aircraft - Fuel - Airplanes (FS/W) 3 Dec 16, 2012 06:09 PM
C-160 Transall Chris True Scale Electric Planes 13 Jul 05, 2009 06:27 AM
Looking to buy Transall C-160 havin fun Scale Electric Planes 6 Jan 24, 2007 05:59 PM
WANTED: C-160 Transall gromitvt10 Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2002 06:24 AM
Check out the Transall C-160- 72" KOMET 44 Sport Planes 7 Aug 06, 2001 06:48 PM
