Old Jan 07, 2013, 07:51 PM
soccer du25 is offline
Find More Posts by soccer du25
Fly hard or Fly home...?
United States, TN, Lenoir City
Joined Oct 2012
I went there, it was listed on fat sharks suppliers....
EDIT: I have NO clue where the correct link went... let me try to find it. sorry
soccer du25 is offline Find More Posts by soccer du25
Old Jan 07, 2013, 07:52 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I would never buy from BEVRC. Their website is constantly changing to different domains or redirecting to viruses. They have non-existant customer service, and the whole company seems like it could disappear and no one would ever know what happened.
gooby is offline Find More Posts by gooby
Old Jan 07, 2013, 07:54 PM
Joined Oct 2012
Well the fat sharks on ready made are out of stock... And i do not need a single thing more? No batteries or tx/rx???
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
It's ok, not your fault. I think bevrc must have changed their name again so none of the links work properly.
Old Jan 07, 2013, 07:57 PM
Joined Oct 2012
Yeah, i already don't like that website.
But when will they be back in stock, and i really do not need anything else? just plug and go... I feel like i need another tx/rx for the ground and then a battery for the plane or something...? Also With my Remote Im buying the telemetry, i was also going to order a simple osd from hobbyking
Old Jan 07, 2013, 07:59 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Not a single thing. Most of the so called pnp fpv systems are only half complete, but not this one and the other readymaderc packages.
You could ask readymaderc when they will be back in stock, and they should reply very quickly. (Such a relief dealing with an American company)
Old Jan 07, 2013, 08:00 PM
Joined Oct 2012
Alright, so how do i get power to the rx and video camera on the plane?
Old Jan 07, 2013, 08:07 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
It comes included with a filtered power cable that plugs into the balance lead on your flight battery.
Old Jan 07, 2013, 08:14 PM
Joined Oct 2012
Alright, so do you mind if i give you a final check list of everything i will be buying. Btw i have a radian pro and have some mods to it and will need a bigger prop I also have a 40amp and 70amp esc, and my battery atm is a 1500mah 30c 3s battery:
Remote:
Tx: 50
http://www.hobbyking.com/hobbyking/s...Firmware_.html
Smart board: 45
http://www.smartieparts.com/shop/ind...roducts_id=331
Telemetrz:
http://www.smartieparts.com/shop/ind...roducts_id=337
Backlight for Tx: 5
http://www.hobbyking.com/hobbyking/s...hite_DIY_.html
Voltage sensor:
http://www.hobbyking.com/hobbyking/s...y_System_.html
Module:
http://www.hobbyking.com/hobbyking/s...Module_RX.html
FPV:
Goggles:
http://www.readymaderc.com/store/ind...oducts_id=1129
Osd:
http://www.hobbyking.com/hobbyking/s...ing_E_OSD.html
Battery Charger:
Charger:
http://www.hobbyking.com/hobbyking/s...lls_COPY_.html
Charger Power Supply:
http://www.hobbyking.com/hobbyking/s...er_Supply.html
Prop:
http://www.hobbyking.com/hobbyking/s...ropeller_.html
Extra battery for the radian:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Old Jan 08, 2013, 06:27 AM
Joined Oct 2012
bump
Old Jan 08, 2013, 09:31 AM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
Remote:
Tx: 50
Smart board: 45
Telemetrz:
Backlight for Tx: 5
Voltage sensor:
Module:
FPV:
Goggles:
Osd:
Battery Charger:
Charger:
Prop:
Lol you are not understanding. When you get the fat shark V2s they come with all of that stuff. It comes with the camera for fpv, transmitter for fpv, receiver in goggles for fpv. Its already a complete system. Just plug it all up and your ready to fly.
BUT!!!! If you have never done fpv I would not start with osd and everything like that. You need to start as simple as possiblea and work your way up. That is what everyone does. Once you start putting osd and other things into the mix it gets complicated and for you, since your new to fpv, that would be stressful. IMHO get the Fat Shark V2 goggles and thats it. Use that for 3-6 months then if you want, get a cheap osd to start with or whatever else. But learn to fly simple first.
Wrice4 is offline Find More Posts by Wrice4
Old Jan 08, 2013, 03:18 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I'm still not flying with an OSD since I only do shorter range fpv (1km), and it adds a failure point. And you will not have to do any upgrades to your radian, the fpv setup is lightweight. (53 grams for mine).
Old Jan 08, 2013, 03:24 PM
Wrice4 is offline
Wrice4's Avatar
Joined Nov 2012
I ordered an OSD, but will only use it on one of my planes, because I just want to try it out. I usually just do short FPV like Kovs. I rarely even go 1/2 a mile. The farther you go, the greater chance of losing your plane forever. Make sure when you fpv for your first time you fly right around yourself because you will not know where you are in the air. It is a totally different view and even though you think you know where you are, its hard to determine sometimes. I fly beside a church so I can always spot it and easily find myself. Beginners dont think of small things like this. I had a buddy lose his first fpv plane with all of his setup because he thought he was close and then got lost and couldnt find his way back. He had no osd gps so we never found the plane because the video cut out. He lost all of his fpv gear on that plane, along with the plane.
ALSO! Be sure you have a spotter with you and only fly LOS (line of sight) for at least the first 10-15 attempts. Will help you greatly. I still slide my goggles off from time to time to make sure I am where I think i am.
Old Jan 08, 2013, 05:22 PM
Joined Oct 2012
Well i fly from the highest point in our area, its the only big hill for 10+ miles
Old Jan 08, 2013, 11:43 PM
Ascended is offline
Find More Posts by Ascended
Ascended's Avatar
Canada, AB, Calgary
Joined May 2012
9xr came back in stock today btw
I'd recommend one of these:
http://www.readymaderc.com/store/ind...roducts_id=579
Over the stock camera. It handles sunlight in frame better than any camera i've ever seen. Get it with the OSD cable, the stock backlight setting isnt much good for FPV.
Ascended is offline Find More Posts by Ascended
Discussion DH 9116 Tx howto Reverse Rudder settings - v911 can fly with this Tx jamiedg Beginner Training Area (Heli-Electric) 40 Sep 11, 2013 10:39 AM
Discussion Need help setting up Tricopter with Spektrum DX7s with gyros Easyrider717 Multirotor Talk 35 Apr 19, 2012 11:50 AM
Discussion Hobby King Tx & Rx set up help, please? Refrik FPV Talk 2 Apr 15, 2012 02:26 PM
Discussion Help with setting up JR TX for Heli J.Avant Large Electric Helis 6 Apr 02, 2012 12:40 PM
Help! Need help setting up my tx/rx bnb2fly Beginner Training Area (Heli-Electric) 2 Mar 04, 2012 08:23 PM
