Old Jan 21, 2013, 05:08 PM
cswee is offline
Find More Posts by cswee
United States, CA, Oakland
Joined May 2005
Managed to get the wing built. The pic shows it in place, still needs final sanding. The nose has been shaped ready for installing the diesel power, time to think about covering materials.
Chris
cswee is offline Find More Posts by cswee
Old Jan 22, 2013, 02:58 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Quick work Chris, it's looking great.
Sundancer is online now Find More Posts by Sundancer
Old Jan 26, 2013, 10:24 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Good progress on a nice looking model. Subscribed!
sparks
sparks59 is offline Find More Posts by sparks59
Old Jan 28, 2013, 08:00 PM
cswee is offline
Joined May 2005
A little more progress. I have started doping the tissue covering but the weather is not cooperating so I will have to wait a couple of days to finish it. I will not add much color trim until after test flying. I have forgotten if nitro dope needs fuel proofing for diesel fuel, any suggestions?
chris
Old Jan 29, 2013, 02:37 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
I think nitrate dope is usually OK with diesel fuel, if the exhaust residue isn't left on the surface for a long time, however, I would certainly want to fuel proof the engine bay and immediate surroundings.
Old Jan 31, 2013, 12:35 AM
colibriguitars is offline
Find More Posts by colibriguitars
Joined Mar 2011
Hi CSWEE!
Your plane looks beauty! your building is so clean, like the color with just some trim. Thanks for share!
colibriguitars is offline Find More Posts by colibriguitars
Old Feb 01, 2013, 08:41 AM
tri-pacer is offline
Find More Posts by tri-pacer
Napa, CA
Joined May 2007
A light coat of epoxy wouldn't hurt around the engine mount and immediate areas. Diesel fuel isn't aggressive because it doesn't have the nitro, but it can still "soak in" if you're not careful. By the way, VERY nice looking model!!
Never been brave enough to fly single channel (at least not on purpose), looking forward to your flight test!
tri-pacer is offline Find More Posts by tri-pacer
Old Feb 01, 2013, 09:48 AM
cswee is offline
Joined May 2005
tri-pacer I usually use epoxy thinned with alcohol for fuel proofing engine areas, there is still a lot of oil to deal with. I have a few single channel planes. The first flight can be a challenge if you have too much wing incidence the plane will want to loop so you end up with turning that into a spiral climb like a contest model( you hope )
colibri I agree with simple color trim. I had planned to paint the fuselage but now I see it covered I like the way it looks mostly tissue colored.
I am glad I chose this design, it has produced a very nice looking little plane.
Chris
Old Mar 18, 2013, 09:33 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Chris. Been a while since we heard from you, last picture the Wendy looked 90% done. Any progress??
Build Log Paageboy - 2013 Britplan Build Off owlsabie Vintage & Old-Timer Designs 114 Nov 02, 2015 10:17 PM
Contest "Britplan" Build Off - 1st January 2013 to 30th June 2013 Now 22 Finished Models! Sundancer Vintage & Old-Timer Designs 257 Jul 16, 2013 12:23 PM
Discussion Cyril Shaw "Envoy" - Britplan Build Off January 2013 to June 2013 cpmcgraw Vintage & Old-Timer Designs 280 Jun 26, 2013 01:35 AM
Contest Auster-Britplan Build-Off Jan 2013- Jun 2013 mrdj Vintage & Old-Timer Designs 6 Apr 02, 2013 06:02 AM
Discussion Proposed "Britplan Build Off" 2013 Sundancer Vintage & Old-Timer Designs 96 Dec 31, 2012 07:56 PM
