Old Jan 06, 2013, 01:19 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
do I need 3D
Been using model cad (2D) for many years. I see everyone using 3D cad, and I looked at sketchup as maybe a starting point.
So lets say I create a set of balsa wings with balsa ribs - in 2D I print out rib templates. Will 3D print the same templates, or is 3D pretty much for CNC and 3D printers?
Is there really a reason for me to learn 3D software?
karlik is offline Find More Posts by karlik
Old Jan 06, 2013, 03:11 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Usually would need to flatten a 3D part to make the best looking template. For a symetrical part this might be as simple as showing the edges of the surface, and hiding the surface leaving the edge outline showing.
I use 3D mostly to find the locations of other parts, and to see how it all fits together.
A couple of examples.
--A wing from only the root, and tip rib. Skinned in between, and the ribs sliced out from the skin.
--A fuselage side developed from the intersection of the top view, and the side view.
Roto Rob is offline Find More Posts by Roto Rob
Old Jan 07, 2013, 02:41 PM
Treeline is offline
Find More Posts by Treeline
Joined Oct 2010
For designing, drawing and printing aircraft plans, not really.
Thousands of very successful aircraft plans have been drawn and built using just 2D software, and it's really all you need unless you have an additional personal interest in learning 3D for your own benefit beyond model airplanes.
I draw everything in Rhino4 (just upgraded to Rhino5), and I do it in 3d, but that's ONLY because I can output it to the company CNC machine (a 5x12) for free if I do it after work. The 3D part of the design lets me do carvings of canopies and cowls because the machine has a 12' lathe that hangs off the side.
If I step back for a moment and imagine my losing my job and access to the CNC machine, but still wanting to draw model aircraft plans, I would revert to just whipping them out in my trusty dusty old version of AcadR12, obsolete by CAD standards but a real gem for drawing accurate plans of models.
The learning curve from 2D to 3D is quite exponential for most people, and you short yourself nothing if just drawing nice plans to build from is your purpose.
Treeline is offline Find More Posts by Treeline
Old Jan 07, 2013, 02:51 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
i gotta say ...
i have been a AutoCAD user for 15 years plus ... and have recently started on solid works ....
it has been the most frustrating thing i have ever done in my life , i think , worth it ? for sure
the only reason is because i have a CNC router that can churn out awesome 3d parts.
once you get used to the interface and the way it works (solidworks for me) it is simply amazing ... im getting to the stage that i can now do most of my drawings without having to touch acad anymore
Blackrat is offline Find More Posts by Blackrat
Old Jan 07, 2013, 04:03 PM
DeadTom is offline
Find More Posts by DeadTom
Team of ONE....or...Team Me
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
Although 3D CAD is useful in CNC machining it is not necessary, one of the products that I use it Vectric's Cut2D for alot of my CNC use such as ribs, quad-copter parts, simple signs, etc.
DeadTom is offline Find More Posts by DeadTom
Old Jan 07, 2013, 05:08 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
I would say "need it or not" is related to the workflow you want to establish in your model design ...
A) Some come bottom up - draw 2D parts extrude them to get 3 D parts - arrange them to getblock instances and assemble those to get the final model
-> result -> you can check if everything would fit together.
B) Others come top down - design a plane -> check if you like the result then derieve the details which are needed for to construct the structure and the parts in 3D
arrange them to the machine space and flatten them to get 2D shapes for cutting
Two possibilities with rather the same effort - difference Top down gives you an earlier proposal what you will get and if a sub construction fails or shows that there should be changes done, you always are able to refer to the original design and look...
Further possibility is that you can do the proposal and move the decision which technology and size the plane will be to the time finishing it ...dependent on that decision you detail afterwards!
So its just a way of philosophy: I also started with the upcomming 2DCAD systems ( Fast CAD Generics CAD and Autocad and then changed to 3D when performance of computers got better . Looking back I don't want to miss the possibilities and would choose the same way again! But now that is on you...!
Good luck!
Hansjoerg
Harpye is offline Find More Posts by Harpye
Old Feb 02, 2013, 03:55 AM
mungral is offline
Find More Posts by mungral
mungral's Avatar
Australia, TAS, Grove
Joined Mar 2009
2D if good. but 3D is better.
The upside of 3D you can easily make sure your CofG is spot on before the design even leaves the computer. and you can get parts 3D printed Do you need something 3D printed directly from your CAD model.
on the down side. getting the exact view with out showing too much or too little detail can be a pain when trying to create 2D drawings from a 3D model compared with just drawing it in 2D to start with.
mungral is offline Find More Posts by mungral
Discussion I need a plane that: is hard to brake, wingspan not more than 600mm, can do 3d coMix Parkflyers 6 Aug 24, 2012 11:18 PM
Discussion what do you guys think of u can do 3d Evan03 Fuel Plane Talk 15 Apr 29, 2012 11:11 PM
Discussion Do you need a sim to fly/learn 3D Pyrofan 3D Flying 16 Apr 07, 2012 07:37 AM
Discussion What stunts do I need to be able to do before I can consider myself a 3d pilot 7oneWo1f 3D Flying 35 Nov 24, 2011 12:32 PM
Do I need to fly Both Ailerons & Rudder to do 3D? mrebman 3D Flying 9 Nov 24, 2003 08:23 PM
