Old Jan 06, 2013, 01:19 PM
ed_jza80 is offline
Find More Posts by ed_jza80
Joined Dec 2007
Strange gimbal movement - ideas ??
Heya folks,
After some trouble-shooting ideas regarding some funky gimbal movement im getting
basically the system is 2 axis, 2:1 belt drive on both axis, all ball bearing pivots, analog hitec hs82mg (0.12sec @ 6v) metal gear servos (new) running at 100Hz and 6V through a separate BEC, control through my naza.
there is zero mechanical slop in the system. gear backlash in the servos is minimal, but it is there.
problem is when rocking the frame from side to side, ie rolling from left to right repeatedly, im getting a lag/delay at the very moment the roll changes direction. you can see this quite clearly in the first video below.
the gain settings are otherwise spot on, the horizon stays level and controlled the rest of the time, but there is def something funny going on!
i kow the naza isnt great, but i havent heard of other people complaining of this particular problem, and im otherwise quite happy with how the naza is driving things.
so yeah.... the question is! - is this a control problem (ie naza is crap) or is it a servo problem (ie crap servos) or have i missed something altogether and theres something else i could be tweaking?
cheers
ed
latest video @ 100Hz after i tried playing with a few things to see if i could improve the lag. best demonstrates the lag issue during rocking from side to side:
Ed's IAISS Y6 - fine tuning 2 (0 min 38 sec)
and the following is my first video from earlier today @ 50Hz wheni first fine tuned the gimbal for the first time. im pretty happy with how it works in generally, just that lag during rocking motion has me stumped!
Ed's IAISS Y6 - fine tuning (0 min 32 sec)
ed_jza80 is offline Find More Posts by ed_jza80
Old Jan 06, 2013, 03:59 PM
tstrike is offline
Find More Posts by tstrike
tstrike's Avatar
United States, UT, Cottonwood Heights
Joined Mar 2012
It might be the buffer lag out of the gopro.
tstrike is offline Find More Posts by tstrike
Old Jan 06, 2013, 05:14 PM
ed_jza80 is offline
Joined Dec 2007
never seen any artefact like that out of a gopro before
im 95% sure its a naza control issue, in combination with basic analog servos.
it would be nice to know if anyone has seen similar effects with naza based gimbal systems, before i go chasing new hardware for a gimbal control system
Old Jan 07, 2013, 09:06 PM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Hi! I have the same problem with my KK2.0 board with firmware 1.5. I know it's not comparable with the NAZA but i think it's not the FC's problem. I think it's the servo increments. I have already tried digital and analog servos with no luck. It is worth trying if you increase the gear ratio to 1:5. Then put some dampening on the camera plate to absorb the remaining jitter.
DYORD is offline Find More Posts by DYORD
Old Jan 07, 2013, 10:56 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
We had the same problem with Hitec servos and 5:1 ratio ...Switched over to the Photohigher gyro same ratio and still had the same lag...switched to savox servos same ratio and radian gyro and the problems went away...
skizziks is offline Find More Posts by skizziks
Old Jan 08, 2013, 12:23 AM
DYORD is offline
Joined Apr 2012
So is it the gyro or the servo? I can get a savox servo but i guess the price is over-rated. Do you think that an ALIGN DS620 will do the same?
Old Jan 08, 2013, 03:47 AM
ed_jza80 is offline
Joined Dec 2007
whats the deadband on the various servos you guys are using? the HS82MG that im using is 0.008s which is on the slower side.
the Hitec (cheaper digital) HS5084MG servo (about equivalent to the HS82MG in size/spec)although not programmable, has a deaband of only 0.002s and is about twice as fast @ 6v
http://www.servocity.com/html/hsg-5084mg_servo.html
thoughts of giving this servo a try?
Discussion Bumpy/twitchy gimbal movements fabianabegglen Multirotor Electronics 0 Jul 19, 2012 03:55 AM
Discussion Camera Gimbal Movement webgeek Aerial Photography 0 Apr 11, 2012 03:58 PM
Help! Stange servo movement Happykid Radios 23 Dec 13, 2010 06:20 PM
Discussion Gimbal unwanted movements, please help zaguruinzasky Aerial Photography 2 Nov 04, 2010 05:33 PM
