Old Jan 06, 2013, 12:56 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Brushless electric motors for selected old timers
Brushless electric motors for selected old timers and smaller models.
See also:
http://www.rcgroups.com/forums/showthread.php?t=966298
Motor Data - test bench data for several hundred brushless motors.
As the title suggests, what BL motor(s) are you using in your model?
Yes, there are many tables and spread sheets for determining what motor goes with what model, prop to use, power, and all that great information, but not for a lot of these old timers shown on this thread.
You modelers have built excellent models and worked out the best combinations of BL power to get them to fly nicely. So, rather than the rest of us “re-inventing” the wheel, why not table and provide the information that you have found works best.
For starters how about these parameters?
Model
Weight
Wing area
BL motor
Size
Kv
Prop
ESC, amps
Battery used
Suggestions?
JohnAV8R is offline Find More Posts by JohnAV8R
Last edited by JohnAV8R; Feb 18, 2013 at 07:04 PM. Reason: added link to motor data
Old Jan 06, 2013, 12:57 PM
JohnAV8R is offline
Joined Oct 2005
Estimate Propeller's Static Thrust
see
http://adamone.rchomepage.com/calc_thrust.htm
Prop size is 7x4 and 15000 rpm is 200 watts or 34 oz thrust
Similarly, 8x3 at 15k 265 W 38 oz
1.) Miss Delaware, with video, post #6
2.) Dallaire Sportster, post #7
Converted .40 diesel to electric
3.) Champion, post #9
Large model at 8.5 lbs, WS 108”
4.) Halfax Spartan, post #13
Auw 36 oz, Turnigy BL 260 w with 10x4
5.) RimFire 200, small model less than 7 oz, post #15
6.) Flair Junior 60, similar in size to the Halifax Spartan and Simplex.
see post #16.
Graham provides the following info:
The Flair is equipped with an Axi 2820/10, Jeti Eco 40 Esc and a 3S 2,300 LiFe battery which gives about 10 minutes flight with an APC 12x6 Electric propeller.
My Ben Buckle Southerner 60 has an exactly identical power train, but is waiting for suitable weather for the maiden flight.
post #31 Emax brushless BL2826/06 950 kva
post #32
Turnigy 2830
post#33
BRC A2208-14T 1450 Kv
post #37, all data for
http://www.rcgroups.com/forums/showthread.php?t=2170922
Hyper Speed 400 (brushed) geared 2.33:1 is used with this model -
SOPWITH TRIPLANE
Sopwith Triplane (all 3) 34"
See post 43 by adamtc for a large model.
Majestic Major 128 oz, 88 inch span- Overlander thumper 5045/10- 14/7 prop- 650w on 4 cells.
Old Jan 06, 2013, 01:49 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Sounds like an excellent idea John - sometimes a pinch of practical experience is worth a pound of theory. I'll put a table together for my models, which are mostly smallish. I'll need to re-run watt meter tests on a few of them as a number have had prop changes since I did the original set-up.
Sundancer is online now Find More Posts by Sundancer
Old Jan 06, 2013, 10:21 PM
colibriguitars is offline
Find More Posts by colibriguitars
Joined Mar 2011
Looks Fantastic!!! there are too many engines around, China made as many models as Chinese people, hard to chose one...
colibriguitars is offline Find More Posts by colibriguitars
Old Jan 06, 2013, 10:22 PM
Joined Mar 2011
What about a link of the motor?
Old Jan 07, 2013, 01:21 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Model -Miss Delaware - Steve Kowalik 1936
Weight-4lbs
Wing area-996
W.S-86"
BL motor-Rimfire
Size-3548
Kv-1300
Prop-Xoar 13 x 4
ESC, amps-80
Watts @ WOT-650
Battery used-2 2250 3S 50C lipo parallel
1936 Miss Delaware taking off (0 min 26 sec)
Leadchucker is offline Find More Posts by Leadchucker
Old Jan 07, 2013, 09:09 PM
Alex VK2KR is online now
Find More Posts by Alex VK2KR
Albion Park Rail Aus
Joined Nov 2009
Dallaire Sportster
Model -Dallaire Sportster - 1936
Weight - 71 oz
Wing area - 1360 sq in
BL motor - HK 3548 - 850
Kv - 850
Prop - 12x6 - for E Texaco, 14x6 for HL
ESC, amps ESC - HK 100 amp ESC, texaco 38 amps, HL 56 amps
(HL - Electric height limited event in Australia - 200m)
Alex
Battery used - 3S 1600mah texaco, HK 3S 3000mah for HL
Electrification of a prior diesel model which used an Irvine 40 on a 16x4 prop
Nice sedate take off with 12x6 a a much more invigorated one with the larger prop.
lack of ether supplies necessitated the electrification.
Alex VK2KR is online now Find More Posts by Alex VK2KR
Old Jan 07, 2013, 09:27 PM
JohnAV8R is offline
Joined Oct 2005
Thanks Leadchucker and Alex. We’re off to a start.
John
Old Jan 08, 2013, 11:12 AM
pomroyj is offline
Find More Posts by pomroyj
History Eraser Button?
pomroyj's Avatar
United States, AZ, Phoenix
Joined Aug 2010
Model Name - Champion
Designer - Ben Shereshaw 1937
Weight - 8.5lbs
Wing area - 1500 sq in
W.S - 108"
Motor - ExceedRC 5055 780Kv
Prop - APC 14x7
ESC - Turnigy 80A
850 Watts @ WOT
Battery - LiPo 4S 3500 to 4500mah
20~35minutes of leisurely flying
pomroyj is offline Find More Posts by pomroyj
Old Jan 08, 2013, 12:07 PM
cpmcgraw is offline
Find More Posts by cpmcgraw
Experienced Balsa Mangler
United States, AL, Tillmans Corner
Joined Oct 2012
Weight - 8.5lbs
W.S - 108"
Prop - APC 14x7
ESC - Turnigy 80A
Watts @ WOT-850
Oh, thanks for this one! This looks great for the (slightly smaller) Cloud Cruiser [aka KK Falcon], too.
cpmcgraw is offline Find More Posts by cpmcgraw
Old Jan 08, 2013, 02:19 PM
pomroyj is offline
pomroyj's Avatar
Joined Aug 2010
Weight-4lbs
Wing area-996
W.S-86"
BL motor-Rimfire
Size-3548
Kv-1300
Prop-Xoar 13 x 4
ESC, amps-80
Watts @ WOT-650
http://vimeo.com/13695364
Hi Lead - Boy, that gets up there in a hurry
Thanks for sharing, John
Old Jan 08, 2013, 06:20 PM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
Does anyone have a proven set-up for the 60" Simplex designed by Paul Plecan? Thank you in advance.
Greg
Greg Knipp is offline Find More Posts by Greg Knipp
Old Jan 09, 2013, 04:42 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Greg
Can't offer anything on the Simplex, but I have a 60 inch Halfax Spartan which must be very similar.
Built from an old Cambrian kit for the John Venti modified version of the original 1945 design. Power train; Turnigy 300 watt outrunner, Turnigy 35 amp ESC, 3S 2200 lipo. Radio: old Futaba Challenger 35 MHz Rx, two 15 gram JR servos. Covering: Esaki jap tissue and dope over 10 micron mylar. AUW 36 ounces. Wing loading 12 oz/sq. ft. Motor is deliberately under-propped (10 x 4) and produces 260 watts at full power, power loading 105 watts per pound.
It will take off, even from my rough grass in 3 metres and hold a 60 degree climb out with ease reaching visibility limit in about 45 seconds. Normal flying is at about one third throttle, hence the long duration with flights averaging 30 minutes without lift.
Old Jan 09, 2013, 10:47 AM
pomroyj is offline
pomroyj's Avatar
Joined Aug 2010
Greg
Greg - The setup from Sundancer for his 60" OT bird is a great starting point. If you find changes to duration or thrust are desired after you complete your Simplex, these can easily be modified. For thrust changes, prop and/or LiPo cell count will provide alot of adjustment. For duration, LiPos with higher or lower capacity. Great thing about BL electric vs. glow/gas motors is BLMs have a very wide power band (i.e. can operate at design RPM over a wide range of props and/or RPM can be changed via bat voltage)
Old Jan 31, 2013, 10:27 AM
JohnAV8R is offline
Joined Oct 2005
RIMFIRE 200 may be of interest for small models weighing less than 7 oz.
Small brushless motors such as the RIMFIRE 200 may be of interest for small models weighing less than 7 oz.
I wanted something for an indoor model, so this is where I got my little BL.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAETX&P=7
Designed for Sport airplanes up to 6.2oz (177g) and 3D airplanes up
to 3.9oz (110g)
Ideal for use with 6A Brushless ESC's, 7.4v LiPo packs and 7x3.5
GWS electric props
SPECS: Motor Diameter: 0.71" (18mm)
Overall Length: 0.74" (18.8mm)
Kv: 2400
Burst Watts: 47 watts
Weight: 0.38oz (10.7g) motor only, 0.44oz (12.4g) motor, mount &
prop adapter
Shaft Diameter: 0.079" (2.0mm)
Input Voltage: 7.4v (2S LiPo)
Build Log The Raven, Old Timer Classic for the fun of it. Freddie B Foamies (Scratchbuilt) 63 Feb 01, 2013 09:33 AM
For Sale Laser cut old timer kits for sale rcbobcat55 Aircraft - Electric - Airplanes (FS/W) 4 Mar 09, 2012 10:27 PM
Discussion Electric Old Timer pilots Leadchucker Vintage & Old-Timer Designs 0 Mar 01, 2012 02:02 PM
Looking for Old-Timer Model For Electric Duration Comp Mick Molloy Vintage & Old-Timer Designs 9 May 31, 2005 03:05 AM
