United States, OH, Cleveland
Joined Oct 2011
Joined Oct 2011
anyway I am using the settings posted by #1ztoon13 for the v911. they work ok but one problem I'm haveing is that the back right knob should fine trim the tailrotor instead it turns both motors up and down. also on take off on N, the aileron pulls way right. this happens on both helis 911 and 912, so I have
had something entered wrong.. I would appreciate any help. tonytester |
New Zealand, Hawke's Bay, Napier
Joined Dec 2012
Had a great flight today out in a large field. Noticed when I picked up a lot of forward momentum, clockwise turns became impossible (I could hear the rear rotor straining). CCW turns were obviously fine still. I'm guessing this is just all the juice going into the main rotor to keep the bird aloft, leaving no power for the tail?
Here is my situation: I have a couple V911s and I am very comfortable with them. I am looking for a bigger FP for my next heli so I can fly outdoors. I have narrowed it down to the V912 or the F45. I would consider the V913 it were available soon. The opinions of the owners are the most helpful. But being an engineer I cant help myself from comparing the specs. Here is what I have gathered. (Its suprisingly difficult to find specs for an apples to apples comparison): V912 - rotor diameter = 400 mm weight = 294 grams + battery(?) battery = 850 mah flight time = 7-8 minutes transmitter = high and low rates cost = about $80 F45 - rotor diameter = 533 mm weight = 458 grams (with or without battery?) battery = 1500 mah flight time = ? transmitter = high and low, maybe sub trim features (not really sure yet)? cost = about $110 I think the V912 might be better sized for my backyard but a bigger heli has a certain appeal and I live only 1/2 mile from a park with open fields. Also, after seeing some of the aerial video taken from F45's I am thinking I need to get into that. That is too cool. Does the V912 have enough power to spare if I wanted to attach a tiny video camera to the belly? I am just getting into this and dont plan on getting an advanced transmitter. So whatever features come on the stock transmitters, that's what I will be using. |
United States, TX
Joined Aug 2012
If you like larger copters and want to get into video, the MJX 645 may just be your cup of tea. I have had the MJX 645 and I liked it a lot. There are camera packages readily available for it. I don’t know if the V912 would be a good camera platform or not, but I do know that the MJX 645 is a pretty good one and is probably a better option if that is something you want to get into. It is also 5 inches longer and while that doesn’t seem like a lot, when you put the two side by side, it seems much larger. Many owners do all kinds of mods and I don’t recall anyone really bad-mouthing them. They cost about twice as much but parts are readily available. They are also pretty tough birds. I have two V912s and another on order for roughly what I had in one MJX 645 and some spare parts that I never had to use. This way I can cycle through 3 flights and not have to fool with batteries or anything else. When I break one, I can fly the other two while waiting for parts. My main reasons for liking the V912s a little better is because of the size and I “think” I can control it better plus I like the idea of only having to fool with one transmitter for my fleet of V911s and V912s. I like to just step out the door and fly around my yard and I really couldn’t do that with the MJX 645. Even though a fairly large field is only ¼ mile away, I found that I just didn’t get around to it very often and spent my free time flying the V911s in my yard instead. Conversely, I have 20 something flights on my V912s in just over two weeks (two today). Guess I am just lazy. BTW, I will likely get a V913 when they become available if the transmitters are compatible and the reviews are good. Don’t ask me why, ‘cause I have no idea. lol Cheers, Jim |
Joined Jan 2013
The postal person put a note in my box today saying they tried to deliver 2 packages from HK... Funny cause I was here waiting and never heard a knock on the door... Anyway, flew the v912 a bit today. Sure is fun but I'm such a noob I'm thinking I should do the same and pick up 2 more spares.
Now I must wait until Monday to get my v922 spare parts, a FBL100 and a couple different v911 BNF to pair up with the v911 TX that are collecting dust while I use the v912 TX all the time for both. |
Joined Oct 2011
out door 912
got home tonight almost no wind after 4 days of 30mph gusts and snow.
I snoblowed the drive then went in and got out the 912. with all the snow it was as light as day 8:45 22 F. wow it flew like a dream great hover nice forward speed . I was impressed with the flight time about 7 min and I also forgot to crash. I see jonboys point about the bigger heli I was really enjoying it. I did have the headlight disconected. I wonder if you can put a flasher on the circuit. tonytester |
The F45 transmitter permit full aile, elev,throttle,ruddr adjustment in %, not the V912 or F46. So robust, the F45 is a tank. Parts are available and cheap. Just bought a third one there, to put a fuselage around, very satisfied. $83. with camera $104 http://www.aliexpress.com/store/110320 Go to my blog, click fauconnier, to know more about the cyclic return see my older messages. |
I hooked up the V912 with my Turnigy 9X (flashed with ER9X firmware). It was a huge difference!
![]() I increased the servo throw / range for elevator and aileron for faster forward flight and more aggressive banks; and more importantly, applied a throttle curve that made sense to me. Now, the heli lifts off at about 65% throttle, hover at 60%. I need to fine tune the settings more so that left and right banked turns "feel" the same. Unlike the CP helicopters that I'm used to, the V912 they does not turn the same way. This annoys me a lot. I may share the settings if there's demand for it.
Canada, BC, New Westminster
Joined Feb 2012
Here is the link for the V912 PCB from Banggood: http://www.banggood.com/Wholesale-Wl...6-p-60691.html and here is the link for the DH 9116 PCB from Banggood: http://www.banggood.com/Wholesale-Do...0-p-40984.html Although the two parts look identical, they have 2 different sku numbers. The reason why I ask all of this is because it looks like you have been able to get the 9x to work with the V912 and we at the DH 9116 forum have not been able to get the rudder to work properly with a 9x Tx. Everything else works but when we increase throttle position the tail motor goes to max rpm and the heli spins clockwise (nose right when looking from behind). Did you have any rudder issues with setting up the er9x for the V912 or was it straight forward? Do you know if the above two PCB's are the same? Mike |
| Thread Tools | |
| Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review | FyreSG | Micro Helis | 2687 | Today 12:20 PM |
| Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) | jameschen072 | Micro Helis | 358 | Today 11:15 AM |
| Discussion WLToys V912/NEX helicopter | jameschen072 | Micro Helis | 26 | Mar 30, 2013 05:56 PM |
| Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45° Flybar Coaxial RTF Helis | ShaneXman | Aircraft - Electric - Helis (FS/W) | 4 | Mar 09, 2012 10:23 AM |
