Old May 14, 2013, 11:32 AM
Switchy is offline
Find More Posts by Switchy
Zipties and Velcro
Switchy's Avatar
United States, NE, Omaha
Joined Mar 2013
Hey Guys. Im replacing the tail boom on my 912. I notice that the replacement boom doesnt have the carbon liner on the inside. Is this an issue? Has anyone else noticed this? It doesnt appear that the liner will come out of the old boom..
Switchy is offline Find More Posts by Switchy
Old May 14, 2013, 12:02 PM
trase is online now
Find More Posts by trase
Joined Aug 2012
Originally Posted by Ricomon View Post
Mine hit me in the forehead, so it was pretty easy to find.
Ouch, that must have hurt... :S
Seems like the flybar is a weak spot on this heli. Anybody tried flying without it? ..Would it even be possible? (I remember seeing a video of somebody flying the V911 flybarless)
I'd try it myself if I hadn't also broke some ball heads.
trase is online now Find More Posts by trase
Old May 14, 2013, 12:28 PM
Crackup is offline
Find More Posts by Crackup
United States, TX
Joined Aug 2012
Yes, I understand about balance charging. What I did not know is that the BLACK connector, for which I do have a jumper, is electrically the same as the WHITE two pin connector on the LiFe battery and can therefore also be used for charging. The compatible jumper I needed was provided with the Thunder A6 charger, so my problem is solved. I was just to dumb to realize it could be connected that way.
Thanks for your response,
Jim
Originally Posted by edk83 View Post
The life batteries have standard balence charge plugs that are 4 pin on the 3s.
You connect that to the balence port on the charger and any one of the 2 pin connectors (may have to make your own) to the charger output.
You need to select life program on the charger or get a charger that supports life. You can't charge them as lipos as they have a lower high voltage!
Crackup is offline Find More Posts by Crackup
Old May 14, 2013, 12:30 PM
FlyGuy912 is offline
Find More Posts by FlyGuy912
[]-[] E [] i []P [] []v[] []P
FlyGuy912's Avatar
Joined Mar 2013
While my AXE 100 is waiting on a motor/board from HobbieCo, thought I would take a break on learning CP and fly the v912 When I spooled it up It started too spin counter clockwise? I checked the tail motor and gears, alls good there. Has anyone seemed to find out what's the issue? Maybe needs a new gyro/PCB Board I see others posts, any solutions?
FlyGuy912 is offline Find More Posts by FlyGuy912
Old May 14, 2013, 02:44 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
it did come out of mine though ...
http://www.rcgroups.com/forums/showp...6&postcount=44
Old May 14, 2013, 07:04 PM
FlyGuy912's Avatar
Joined Mar 2013
Originally Posted by nagromnewo View Post
Either a bad tail motor or a bad gyro. Depending on which way it's spinning.
Owen
Correct me if I'm wrong for the record. If the v912 spins clockwise, it could be the tail motor is going out?
If the v912 spins counter clockwise it's the gyro?
Old May 15, 2013, 12:13 AM
AreaWest is offline
Find More Posts by AreaWest
Joined May 2013
Originally Posted by nuttcaze View Post
no no no, stay far away from that motor, your heli will thank you
just curious but what's wrong with the Xtreme 380 motor? I used it in my DH9117 and haven't had an issue. I was thinking about putting one in my V913. Just like to know why you said to stay away from it?
AreaWest is offline Find More Posts by AreaWest
Old May 15, 2013, 12:59 AM
Switchy is offline
Zipties and Velcro
Switchy's Avatar
Joined Mar 2013
Originally Posted by erdnuckel2 View Post
I think that my flybar is just damaged so bad it wont come out. I think I remember seeing that a whole new tail unit is available.
Old May 15, 2013, 03:19 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Yes have the same idea to put a 380 motor on the V913 ....
The question is how many teeth have original pinion of V912 & V913 370 motors .... and what is the voltage requiered for the 380 motor (ref XTR-EBL015)
SeByDocKy is online now Find More Posts by SeByDocKy
Old May 15, 2013, 05:59 AM
Mattster73 is offline
Find More Posts by Mattster73
Joined Apr 2009
remove/replace battery?
Usual apologies for the noobishest of comments/replies, but I have 2 questions. Firstly, how the hell do you get the cover off to access the battery? Do you literally have to screw/unscrew something? With my V911 I just pull of the plastic cover to access/solder/repair, but with the 912 the cover is attached at the bottom and the manual definitely does not show how to remove the front cover.
Mattster73 is offline Find More Posts by Mattster73
Old May 15, 2013, 06:09 AM
Jonboy. is offline
Find More Posts by Jonboy.
Underdog
Jonboy.'s Avatar
United States, OH, Toledo
Joined Dec 2012
Welcome to the V912, it's a great heli.
Replacing the battery is a bit clumsy compared to the V911. The fastener on the bottom grips too tightly. I pinched it together so it only lightly holds the canopy. So I pop the canopy off of the two posts then wiggle it off of the bottom clip. You definitely don't need to unscrew anything.
Jonboy. is offline Find More Posts by Jonboy.
Old May 15, 2013, 06:24 AM
Joined Apr 2009
thanks
Thanks for explaining and not making me feel stupid for asking - at first, the fastener and cover seemed to be one piece. Thanks for solving that mystery.
Now to work why, A) the green charging light won't come on when charging,
and B) why the thing now won't sync with the transmitter.
In fact, perhaps someone can assist - when I connect the battery, instead of blinking furiously (like my V911's LED), the LED simply stays solid red, as if it's not even searching for/wanting to bind to the TX.
Any ideas?
Thanks again.
Old May 15, 2013, 07:36 AM
handy2 is offline
Find More Posts by handy2
handy2's Avatar
United States, CA, Redding
Joined Feb 2013
I think its the reverse
handy2 is offline Find More Posts by handy2
Old May 15, 2013, 09:07 AM
edk83 is offline
Find More Posts by edk83
United Kingdom, Belper
Joined Jan 2011
Jim
Yeah the black connector also fits the 9x internal power jack so I just use that. The + is the centre pin so you shouldnt be able to get it wrong either. You could also use it for charging but I just cut off the while futaba connector and fitted a jsx to connect to my charger.
edk83 is offline Find More Posts by edk83
Old May 15, 2013, 11:42 AM
barbas25 is offline
Find More Posts by barbas25
Joined May 2013
Good afternoon and greetings to all the forum, I am a new purchaser of the V912 and I wonder if it is compatible transmitter V912 to Fly the V911, because I have ordered the V912 if supported would ask also the V911 which goes for $ 19.99 .
thanks and regards
barbas25 is offline Find More Posts by barbas25
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 475 Mar 14, 2016 09:33 AM
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 8315 Jan 29, 2016 09:21 PM
Discussion WLToys V912/NEX helicopter jameschen072 Micro Helis 41 Jan 27, 2015 10:17 AM
Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45 Flybar Coaxial RTF Helis ShaneXman Aircraft - Electric - Helis (FS/W) 4 Mar 09, 2012 10:23 AM
