Old Jan 26, 2013, 10:04 AM
Crackup is offline
Find More Posts by Crackup
United States, TX
Joined Aug 2012
Originally Posted by ITS ME DAVID View Post
Get a smartphone like an iPhone and record 1080p video and upload it straight to youtube no computer needed
I have a smartphone. Just not smart enough to know how to use all its features. Maybe I will figure it out one of these days..lol
Cheers,
Jim
Crackup is offline Find More Posts by Crackup
Old Jan 26, 2013, 10:17 AM
Crackup is offline
United States, TX
Joined Aug 2012
Originally Posted by tonytester View Post
my 912 came today from tmart, tx right stick broken right in the box. no sign of any impact on the box. the pivot point was cracked off on the elevator gimbal. so rather than causing a ruckess I took apart the tx (forbidden) and was able to make a new part in my shop while the batt was charging. wow the tx is soldered together with some spit and a prayer waiting for cold solder problems world wide. the canopy is a bear to get off , and if you look at the rx board the same guy soldered that also. the copter looks kind of sturdy but I think after a few crashes the board connections will begin to come apart..I'd be surprised if not. just my opinion.
very sad to have the tx arrive borken .
dark and windy out now and I don't want to bash around in the little house.
tonytester.
Alas Tony, I had the same problem with one of mine. Fortunately I have two, so I was able to use the one transmitter on both hellis. I took the broken transmitter apart and the upper post on the (starboard control stick) was missing and it was also pushed out of its cradle. I think it was damaged in shipment. I managed to get it all back together but couldn't replace the missing post. I can fly with it but no left/right movement on the helli. Got a replacement coming on the slow boat.
If you can relay how you fixed yours, maybe I can figure out a way to fix my broken one.
Jim
Old Jan 26, 2013, 11:15 AM
SmileyChris is offline
Find More Posts by SmileyChris
New Zealand, Hawke's Bay, Napier
Joined Dec 2012
smiley were you in church??? my son in law and I mop and buff the floor in a local church huge with 30 ft ceilings.. I always wanted to take my helis but they say no. oh well
Yeah, my local church. It's definitely a great place to fly!
No helis allowed at yours? What a bunch of party poopers :-P
The walls are very solid - a swoop of my v202 into it broke my ladybug cover, heh.
Originally Posted by Crackup View Post
Looking good Chris! You got it going. Keep us posted with your experience.
Jim
Thanks for the encouragement, Jim! Apart from the wall incident I also hit a metal chair leg on landing of my v912 which sounded bad but not even a ding in the blades, thankfully :-)
SmileyChris is offline Find More Posts by SmileyChris
Old Jan 27, 2013, 09:18 AM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
[QUOTE=Crackup;23936513If you can relay how you fixed yours, maybe I can figure out a way to fix my broken one.
Jim[/QUOTE]
jim check this out
tonytester is offline Find More Posts by tonytester
Old Jan 27, 2013, 09:22 AM
Yo R Wee Too Lo
Joined Oct 2011
Description:
Jim
jim check this out can't get this to load properly sorry read it with a microscope.
Old Jan 27, 2013, 11:13 AM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
Size
I am curious about the V912, for comparison, what is the main rotor diameter size ? DH 9116 is 380 mm , Walkera CB180Z is 440 mm.
Thank you
fauconnier is offline Find More Posts by fauconnier
Old Jan 27, 2013, 12:43 PM
Joined Dec 2012
I measure one blade as 185mm, full rotor diameter of 395mm
Old Jan 27, 2013, 12:59 PM
hifinsword is online now
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Substitute blades
Thank you
I've used the CB180Z blades on my 9116 but switched over to the Novus 200 FP blades (part # HMXE8309) for 2 reasons. They are an exact fit on diameter (no trimming required) and more durable than the Walkera blades. The Walkera blades shattered easily if they hit anything. Both need a 5/32" drill bit to enlarge the hole for attachment. Both blades are stiffer than the stock 9116 blades if that's what you're looking for.
Don
hifinsword is online now Find More Posts by hifinsword
Old Jan 27, 2013, 07:57 PM
Yo R Wee Too Lo
Joined Oct 2011
Description: try again
Old Jan 28, 2013, 06:48 AM
fauconnier's Avatar
Joined Jul 2012
Don
I have those 2 helicopters. Just wanted to compare the size. Rotor diameter is more reliable then fuselage length.
Walkera blades are fragile. The last time I ordered blades for my Walkera, I received 10 blades for a cheap price from China. The graphic , the same as my old blades, is not very clear, I thought they were probably copies. You know what, I didn't break a blade since that ! they can take more strike then original blades.
Old Jan 28, 2013, 09:13 AM
Crackup is offline
United States, TX
Joined Aug 2012
Thank you Tony. I can't figure out a way to enlarge it or make out the writing, but I appreciate your help. I e-mailed the vendor. Maybe they will send me a new transmitter.
Thanks again,
Jim
Old Jan 28, 2013, 06:08 PM
Yo R Wee Too Lo
Joined Oct 2011
Thanks again,
Jim
this should work
Old Jan 28, 2013, 06:10 PM
Yo R Wee Too Lo
Joined Oct 2011
my 4 oldest kids
Old Jan 29, 2013, 11:52 AM
Yo R Wee Too Lo
Joined Oct 2011
912 ball links
on myV 912 the links between the swash plate and the flybar swivel travel at an askew angle. if you move them to the long arms and the flybar to the short arms they then go straight , where are everyone elses links attached. thanks in advance.
Old Jan 29, 2013, 12:02 PM
Crackup is offline
United States, TX
Joined Aug 2012
Mine are attached to the long arms on the swash plate and the short arms on the mixer. The long arm on the mixer is then attached to the flybar. They came that way and I have not made any changes.
Jim
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 475 Mar 14, 2016 09:33 AM
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 8315 Jan 29, 2016 09:21 PM
Discussion WLToys V912/NEX helicopter jameschen072 Micro Helis 41 Jan 27, 2015 10:17 AM
Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45 Flybar Coaxial RTF Helis ShaneXman Aircraft - Electric - Helis (FS/W) 4 Mar 09, 2012 10:23 AM
