Old Jan 06, 2013, 10:10 AM
Buster1000 is offline
Find More Posts by Buster1000
United States, NY, Schenectady
Joined Sep 2009
Question
Efficiency of High End vs. Low End Motors
I have always liked the dependability of higher end motors such as Axi, Hacker, Motrofly, E-flite.......
However, many people believe the cloned versions of these motors that sell at ~1/2 the price are a much better bargain. Other than material quality/bearings being questionable quality, do the cheap motors exhibit decreased efficiency?
Buster1000 is offline Find More Posts by Buster1000
Old Jan 06, 2013, 10:38 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
This is by no means a detailed analysis! High quality motors tend to have slightly higher peak efficiency - say 80%-85%, versus the 70%-75% for cheaper motors. The main difference I see in looking at www.drivecalc.de graphs is that high quality motors have flatter efficiency curves (maintaining good efficiency all the way up to max. amp draw)... in lower quality motors there is a far more pronounced drop off in efficiency as max. amps is approached.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 08, 2013, 01:03 PM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
I will not place E-Flite and Motrofly on the same level as Axi and Hacker.
High efficiency is not an exclusive feature of high class motors. I tested a lot of motors on a dynamometer and found some cheap motors with efficiency just as high of even higher than the expensive motors. One of those I always recommend is Suppo, also marketed under different other names.
Efficiency and power are not always synonym. Some of the manufacturers such as scorpion claim highest power and highest efficiency, but it is not. Suppo does not do such claims, but when I dyno tested it together with a lot other similar sized motors including some more expensive motors like Hyperion and Axi, the power output of the Suppo was not far behind, however, it was the most efficient of them all.
rebell is offline Find More Posts by rebell
Old Jan 08, 2013, 02:49 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I've tested a lot of Suppo too... and have always been impressed. When I was hunting for an efficiency curve for a low end motor (like this E-max... and there are plenty worse, but no use for this comparison, since they were not in the same size class or Kv as the Axi I happened to use as the high-quality baseline) I had to exclude Suppo from my search since they looked too good for my purpose!!
Old Jan 08, 2013, 03:31 PM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Interesting you mention E-Max. I tested the E-Max 2826 as well and it came 3rd on the efficiency list. 1st was Suppo, then Axi and then E-Max with other motors to follow. I don't think the E-Max data in the Drive Calc database is accurate. Hyperion 3025, the old one before Scorpion made it, was the most powerful but the least efficient.
Old Jan 08, 2013, 07:35 PM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
I have an Emax BL 2210/30 machine wound motor that dose perform as advertised (barely) Although inspecting the winding shows lots of empty space. I don't think a machine can pack wire like a skilled winder but the end product will be consistent. I marvel at the incredibly inconsistent turn counts on budget based motors and that they work as well as they do.That's the problem with testing motors unless I wound it or unwind it I don't know precisely what is being tested. So machine wound motors are likely to be on the light side of wire (lower eff. even when better magnets are used to try to recover some performance)) at least if the motors replaced the new one should be the same as the old one. I like low cost motors because the bang for the buck is there with good copper fill and a great improvement is realized. That doesn't really happen with the top shelf motors in fact performance can be lost deviating from their original design.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Question most efficient/low amp percentage motors. steef 95 Multirotor Electronics 4 Sep 03, 2012 01:15 PM
Discussion low-S high-KV vs high-S low-KV battery-motor set up jy0933 Multirotor Electronics 33 Aug 19, 2012 03:28 AM
Discussion Reynolds number, High vs Low Iboxx83 Modeling Science 10 Apr 19, 2012 09:42 PM
Question High efficient motors + controller Don Moretti Power Systems 11 Apr 18, 2012 06:55 PM
Does the low end affect the high end? deegola Engines 5 Jul 29, 2005 02:12 PM
