Old Jan 15, 2013, 10:50 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Hot drawing!
wuest3141 is offline Find More Posts by wuest3141
Old Jan 16, 2013, 03:39 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by DarZeelon View Post
Earl,
I believe this is the main justification for using a felt clunk.
It prevents anything but liquid fuel, from going into the fuel-line, until the tank is virtually empty and there's no fuel to soak-up into the felt.
Correct
Reginald is offline Find More Posts by Reginald
Old Jan 16, 2013, 05:42 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Originally Posted by wuest3141 View Post
Hot drawing!
Aw, shucks. Thanks.
Originally Posted by pilotpete2 View Post
The loop of fuel line on top of the tank goes a long, long way to eliminating the problem, BUT the loop should extend a little beyond the rear of the tank, so the loop will be the highest point in the vent line on downlines.
Makes sense - I'm plumbing a new tank for a new-to-me 50cc plane using a Fiji water bottle and a two-line system. Here's the diagram:
I've heard from a couple of different sources that fibres from the felt clunk may work their way loose and into the supply line. That's what the inline filter is for - insurance. I also have a filter inside my fuel jug.
I have photos of the installation and will post them if there's any interest.
grosbeak is offline Find More Posts by grosbeak
Old Jan 17, 2013, 04:00 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
I did mine with 3 lines
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Old Jan 17, 2013, 05:07 PM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
3 lines
What is the benefit of the 3rd line instead of a T in the main line? Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Jan 17, 2013, 05:33 PM
kwj48 is offline
Find More Posts by kwj48
probro 2567
kwj48's Avatar
Midlothian,VA
Joined Jan 2006
Originally Posted by BrianSmith View Post
What is the benefit of the 3rd line instead of a T main line? Brian
Basicly less points of failure.
Personally I like the two line setup better, because while filling your tank you also prime the line to the carb. Less flipping to get the engine choked/started.
kwj48 is offline Find More Posts by kwj48
Old Jan 17, 2013, 05:47 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The advantage with the 3 line setup is that it minimizes the connections where air can be drawn into the line to the carb. While I do drain my fuel tanks at the end of the flying session, the fuel in the line between the clunk and carb remains filled with fuel. With gas engines, most folks do not run them dry after the last flight of the day to keep the gaskets in the carb wet and to eliminate the need to prime the engine.
One other note. The fill/drain line on a 3 line setup should be mounted higher than the top of the tank, never on the bottom of the plane
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Jan 18, 2013, 07:37 AM
screilly is offline
Find More Posts by screilly
United States, FL, Orlando
Joined Feb 2008
Pete has a valid point with the Fill / Drain assessment.
A) It would be a point of failure if that were to open during flight or if it were leaking due to any reason; bad line, maybe someone forgets to cap it after fueling, vibrating loose, etc.
B) Also for ease of access: Easier to see and connect / dis-connect for service if mounted on the side or top of plane .... still higher elevation than the tank though.
screilly is offline Find More Posts by screilly
Old Feb 25, 2013, 08:13 PM
purcilas is offline
Find More Posts by purcilas
Team PAS
purcilas's Avatar
United States, MD, Bowie
Joined Mar 2011
Even cheaper Viton: http://www.zorotools.com/g/00057078/...azonProductAds
purcilas is offline Find More Posts by purcilas
Old Feb 28, 2013, 01:12 PM
Joined Nov 2011
Don't forget to use fuel barbs on all your lines as the tygon expands with age and can come off.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWH38
Old Feb 28, 2013, 11:44 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I like a 3 line set up with a felt clunk mainly because of the flitering
kerwin50 is offline Find More Posts by kerwin50
Old Mar 01, 2013, 12:44 AM
Propdinger is offline
Find More Posts by Propdinger
Joined Mar 2007
I use neoprene tubing, it works with gas and you can get it at any auto parts store. I have some on my plane for 3 years no problem.
Propdinger is offline Find More Posts by Propdinger
Old Mar 01, 2013, 01:04 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Originally Posted by kerwin50 View Post
I like a 3 line set up with a felt clunk mainly because of the filtering.
Actually, Kerwin, filtering is only the fringe benefit...
The leading virtue of the felt clunk, is its ability to soak the tank dry and to perform bubble free fuel delivery, to the last cc in the tank.
DarZeelon is offline Find More Posts by DarZeelon
Old Mar 04, 2013, 04:46 AM
Tucson
Joined Nov 2009
Watch out with an 11 oz fuel tank (20cc engine). The gas Tygon tubing is stiff, and so with the clunk falling in the bottom rear of the tank, the last of the gas will run to the FRONT of the tank when you stick your nose DOWN to come in to land. I sucked air coming in to land, and bushed a plane, even though the tank was not empty.
I have gone to 16oz tanks for a 20cc gas engine.
I like the drawing above. This is a good setup for tubing. The T going to the clunk and engine is vital, so that you do not have to hink around pulling off tubing to refuel.
Old Mar 07, 2013, 12:32 AM
DarZeelon's Avatar
Joined Nov 2003
Wuest,
They say here Viton® tubing does a much better job of following the fuel in the tank.
It is significantly more flexible.
For Sale Large lot of fuel tanks for glo or gas Steve H. Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 31, 2012 10:30 PM
Help! O.S. FS-20 Fuel Tank Set Up PatrickRC Engines 1 Apr 17, 2012 05:29 PM
Discussion Gas engine => fuel tank/line/engine set-up... Commplexxo Scale Sailplanes 7 Apr 24, 2011 08:26 PM
Discussion Need help with fuel tank set up wjbender Engines 5 Jun 27, 2008 06:42 PM
Discussion Fuel tank set up problems: unable to fill with wind up filler arukum17 Beginner Training Area (Fuel) 3 Dec 28, 2007 03:43 PM
