Old Jan 06, 2013, 06:08 AM
ecreative is offline
Find More Posts by ecreative
It's all about Quadcopters
United Kingdom, England, Surrey
Joined Nov 2012
Need some upgrade advice
Hi
I have built a quadcopter using Turnigy D2638/8 motors with 10x4.5 props and now I want to upgrade my X550 frame to this frame for fpv but I've noticed in all the pictures I've seen they seem to be running smaller props and motors.
Will mine be suitable or does anyone recommend another type of motor?
I'm running on 3S batteries with 30amp ESC's
ecreative is offline Find More Posts by ecreative
Old Jan 06, 2013, 07:17 AM
Great_Dane is offline
Find More Posts by Great_Dane
Woof!
Denmark, Region Zealand, Roskilde
Joined Oct 2012
If there's not too much of a difference in weight between the old and new frame, you will most probably be quite OK. Actually, the recommandation on the page you link to (new frame), they say:
-Biggest propeller can be used: 12-inch, usually we use 10.11 inch ones
Now this is where the recommandations become 'problematical':
-Recommended motor: 2212.2216.4006.5005
The first 3 are at best ambiguous/indistinct, as it's just types/makes of motors, which all come with different kV numbers. To me it's like recommending that you should buy a Toyota, but not telling if it's a Land Cruiser or a family sedan.
If you're in doubt, or if you'd really like to find another combination of motors/propellers, which will work for a new frame, check out eCalc - it's really sweet.
I could not see the weight of the new frame on that page, maybe someone else knows?
There's another page with a similar frame; they list the weight as 112g (the tab called 'Additional Information', which I think is not true; the figure is simply too low to be true
Great_Dane is offline Find More Posts by Great_Dane
Old Jan 06, 2013, 08:24 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
In my opinion, it should be totaly suitable.
Turnigy D2638/8
Battery: 2~4 Cell
RPM: 1100kv
Max current: 18A
Max power: 336W
Weight: 70g (including connectors)
This motor is light and power is interesting.
You may use 9", 10" or 11" propellers, according to your quad's UAW and wished stability.
Mortimer is offline Find More Posts by Mortimer
Help! Need some advice on upgrading my EDF Gliding-Peter Electric Ducted Fan Jet Talk 5 Jun 27, 2012 07:24 AM
Discussion Need some advice please quadcopter goldsworthy Multirotor Talk 5 Mar 09, 2012 04:41 PM
speed 400 rascal brushless upgrade... need some advice! ground pilot Electric Plane Talk 6 Jul 15, 2004 05:53 PM
Need some advice on Li-Poly upgrade JonB Power Systems 5 Aug 12, 2003 04:13 AM
