Old Jan 05, 2013, 07:40 PM
microairman1 is offline
Find More Posts by microairman1
Team Heads up RC
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
Help!
dollar tree foam trainer plans needed
hey guys i just bought this stuff and i need to build something that flys well and can train someone to fly.it needs to be able to built (and be rebuilt) very fast and possiblly 4 channel it cannot use any mixing except possiblly elevon mixing. any suggestions would be great. thanks
(i will be using 8*4 props)
motor esc and servos
http://www.hobbypartz.com/60p-dy-1006.html
battery
http://www.hobbypartz.com/83p-800mah-2s1p-74-15c.html
microairman1 is offline Find More Posts by microairman1
Old Jan 05, 2013, 07:46 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
the motor and gear is a bit heavier than what I originally used, but will work ok on an OSFloater. I had to put the battery right behind the firewall, but with that motor, it could go in the "cabin". http://www.rcgroups.com/forums/showthread.php?t=1391606
springer is offline Find More Posts by springer
Old Jan 05, 2013, 07:54 PM
Team Heads up RC
Joined Sep 2012
how hard is your osglider to build? and fly?
Old Jan 06, 2013, 12:52 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Here is one made from 2 sheets of Dollar Tree foam board . It's SUPER EASY to make ( and re-make ) since it's just a few straight cuts , and can be a slow flying , self-righting trainer if built light and with some dihedral . And it protects your electronics if you do crash .
A number of people here on RCG have made one , including several first time builders/flyers . If you're interested , I can give you links to their builds ( including videos ) .
http://www.rcgroups.com/forums/showthread.php?t=1685988
Al
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jan 06, 2013, 01:17 AM
Team Heads up RC
Joined Sep 2012
looks nice. But i would like it to have a airfoil(or some sort of positive lift) on it. I dont like thhe flat wing planes to much.
Old Jan 06, 2013, 01:36 AM
Joined Aug 2010
You can certainly put a KFm airfoil on it , I did on a 1/2 size SE I made , and so did Nightstone on a few he made . The basic SE is meant to be a quick , easy build .
Nightstone's full size with KFm airfoil : http://www.rcgroups.com/forums/showt...1#post22557319
My 1/2 size with KFm :
Old Jan 06, 2013, 08:01 AM
springer is offline
treefinder
springer's Avatar
SE MI
The OSG is actually easier to build than the OSF. Simple box fuse, UC or KFM2 airfoil wing. I designed it as a thermal motorglider, (which it does well) but several guys have used it as a first trainer. It's a very gentle flyer on calm air.
Old Jan 06, 2013, 03:10 PM
Team Heads up RC
Joined Sep 2012
is it 3channel or 4 channel?
Old Jan 06, 2013, 03:29 PM
springer is offline
treefinder
springer's Avatar
SE MI
OSG is designed to be 3ch (RET) but I suppose one could add ailerons pretty easily. If you really wanted them, then the OSF or a blue baby would be a better choice. Several guys have done 33" BluBabys in DTF and some have used ailerons. Typically one goes with a KFM2 wing when using ailerons, as it's easy to do a flat, no dihedral wing using the KFM2 airfoil. The important thing to remember is that a removable wing (rubberbanded on) is key. Then you can do either plain wing for 3ch or aileron wing for 4ch. I still swap them in and out. the UC wing is a nice float around, and works well when I use floats, while the KFM3(in the case of my 42" BB) with ailerons makes the plane quite acrobatic.
Old Jan 08, 2013, 12:54 PM
Team Heads up RC
Joined Sep 2012
do you have plans for the floats?
Old Jan 08, 2013, 02:41 PM
springer is offline
treefinder
springer's Avatar
SE MI
I just cut them from 1" foam from home depot. I think there are templates in the Blubaby thread.
Old Jan 08, 2013, 07:49 PM
Team Heads up RC
Joined Sep 2012
ok cool thanks just one more quesion do you know of a simple little bit aerobatic plane? that uses the same electronics
Old Jan 08, 2013, 10:30 PM
springer is offline
treefinder
springer's Avatar
SE MI
Use a KFM2 aileron wing on a 33" BluBaby and it'll be about as aerobatic as one could want. (the nice thing about removeable wings, you can make the plane capable of serveral roles) But there are tons of planes that are purpose designed to be aerobatic. You should just search through the 600 planes thread for one you like.
Old Jan 11, 2013, 02:56 PM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
microairman1
How about the Wot Next http://www.rcgroups.com/forums/showthread.php?t=1525812. It can be built with a KFm wing or Armin with dihedral with the option of switching to a flat wing later on once you the have become comfortable. It's a simple box fuse and mostly straight edges.
Here is the post with my build http://www.rcgroups.com/forums/showp...&postcount=482 and video of her in action
WOT-NEXT maiden flight (3 min 16 sec)
Andy
headlessagain is online now Find More Posts by headlessagain
Old Jan 22, 2013, 01:58 PM
newguy2012 is offline
Find More Posts by newguy2012
Using foam in moderation
newguy2012's Avatar
United States, IL, Aviston
Joined Sep 2012
Originally Posted by headlessagain View Post
microairman1
http://www.youtube.com/watch?v=NcECBVkmKGc
Andy
what power set up are you using? that thing looks great!!
newguy2012 is offline Find More Posts by newguy2012
Question Foam question...Depron vs Dollar Tree Foam. Disco Stew Foamies (Scratchbuilt) 27 Apr 25, 2014 02:36 PM
Build Log Full fuselage Fokker D-7 designed for dollar tree foam...now with plans! gmwahl Foamies (Scratchbuilt) 110 Mar 22, 2012 10:09 PM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Question Baking Dollar Tree Foam in a Jig ?? Wilfor Foamies (Scratchbuilt) 25 Feb 25, 2012 06:17 PM
