Old Jan 07, 2013, 09:45 AM
Gil Gauger is offline
Find More Posts by Gil Gauger
Play loud, Fly high
Gil Gauger's Avatar
Vincennes,IN USA
Joined Apr 2007
Towel
Ryan, I kneel just outside the path of the line in front of the winch with the towel in my right hand and the switch in my left. Only my right hand is in the path of the winch line. I am a guitar player and my left hand dexterity is pretty well developed. Try it on the other side if tapping with your right hand works better for you. I also intentionally rig my chute so it can't pass through the turn around. I tap down to the stake, walk out and remove the chute and pickup the stake, and only then come back and wind in the line. I forgot two turnarounds at the field many years ago before developing this habit.
Gil Gauger is offline Find More Posts by Gil Gauger
Old Jan 07, 2013, 10:38 AM
dharban is offline
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
Whenever possible, make it a two man task. One man runs the winch and watches the line and one man guides the line onto the spool. Stop winding when the end of the line is 75 feet or so away from the winch and wind the rest in by hand.
If the chute can go through the turnaround it is useful for spotting the end of the line (and it facilitates, as Gil mentioned, forgetting the turnaround sometimes).
If you are not rewinding with the chute on TAKE ANY METAL STUFF (RINGS, SWIVELS, ETC.) off the end of the winch line. If you misjudge on the retrieve these things are really deadly. I saw a clubmate lose a pretty nice chunk of flesh AND muscle in a mishap like this.
While it never occurred to me, using a cordless drill to rewind is not a half bad idea. It substantially reduces the amount of damage an errant winch line can cause without much of a downside other than a very little extra time. Every modeler I know owns one or more cordless drills and how many of us have been so lucky as to have never had a winch or battery failure that made it impossible to rewind anything? Sure, we're all used to doing it the way we have always done it. And while I don't use a winch much anymore, I will probably give it a try just to see how it works.
Thanks for the suggestion.
Happy Landings,
Don
dharban is offline Find More Posts by dharban
Old Jan 07, 2013, 10:48 AM
rdwoebke is offline
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Once again guys, thanks for all the feedback on this. There has been a lot of good ideas/suggestions/commentary.
I hadn't really thought about metal things on the end of the winch line being dangerous but then I don't have anything at the end of my winch line because I have always cut the line from the chute because for my gear it won't go through my turn around. And by "always" I have probably setup my winch maybe 20 times ever. I have occasionally thought of doing a quick link or a snap swivel instead of having to cut and tie the chute on. Now the comments here make it so that I in fact won't be doing that.
I'm not sure I really can wrap my head around how a person would wind the line with a cordless drill. Currently I'm not getting how that would work. Maybe somebody could post some pictures or a write up of this?
Thanks guys!!
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Jan 07, 2013, 10:57 AM
Jimn8uay is offline
Find More Posts by Jimn8uay
JimN8UAY
United States, OH, Medina
Ryan, no need to cut lines, just make two knotted loops, one on the chute leader and one on the winch line and slip them together. (Wish I could draw you a picture) Simple when you see it. You could even put a welded ring in between if you need it for a retriever line or something.
Jim
Jimn8uay is offline Find More Posts by Jimn8uay
Old Jan 07, 2013, 11:01 AM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Thank you, Jim, that is another interesting suggestion. I think I understand what you mean. It would be useful for me because I share the same chute with my high start and winch.
The high start I have definitely used more than 20 times.
Ryan
Old Jan 07, 2013, 11:09 AM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Also, it might help to have some pictures of my winch for all of you awesome folks to use to make suggestions for me.
http://pinterest.com/pin/108790147218768722/
http://pinterest.com/pin/108790147219491624/
http://pinterest.com/pin/108790147219261854/
Ryan
Old Jan 07, 2013, 11:27 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Originally Posted by rdwoebke View Post
...I'm not sure I really can wrap my head around how a person would wind the line with a cordless drill. Currently I'm not getting how that would work. Maybe somebody could post some pictures or a write up of this?
Details would depend on the winch construction. I have seen a hex socket bolt at the end of the winch shaft and a piece of a ball-shaped hex wrench chucked onto the drill.
jkettu is offline Find More Posts by jkettu
Old Jan 07, 2013, 02:12 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Originally Posted by jetmaven View Post
Yes, it can be dangerous , I have a scar to prove it . I use a pice of 12" piece of 1" aluminum pipe to keep the "reel in "distributed on the drum .it works fine if you pulse the pedal sparingly and don't get greedy . When that chute is ,by all appearances ,one pulse away, don't be fooled . It will leave a mark.it comes in faster than you think as the drum fills up . I wish we had a low speed alternative
I always remove the chute to avoid damage to the turnaround pully. That metal ring going through the turn around will damage the pully causing line brakes. So all metal is removed befor I reel it in.
aeajr is offline Find More Posts by aeajr
Old Jan 08, 2013, 06:12 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
I just wanted to point out one more time, that a lot of these drills have torque settings... I would set it just heavy enough to pull the line, and no more.
A snag would stop it.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Jan 08, 2013, 03:45 PM
VegasRay is offline
Find More Posts by VegasRay
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
Drill Motor Used for Wind-up
I've attached several pictures of our drill motor wind-up system. Two of our guys, Tod and Mac, decided that we needed a safer and simple method of winding up the line after flying.
The modified hole saw blade shows the notches necessary to fit over the winch drum thru bolt. I've also included a picture of the simple threaded 'clip' we use to connect / disconnect the winch line from our retriever line or parachute. We tie about a two inch loop knot at the end of the winch line that the clip slips thru. We get the clips from Home Depot in the hardware dept.
Hope these help.
Ray
Las Vegas Soaring CVlub
VegasRay is offline Find More Posts by VegasRay
Old Jan 08, 2013, 03:50 PM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Ray,
This helps a ton. Thank you very much. I am going to post some pictures of my winch drum and try to come up with a similar plastic piece attachment for a cordless drill.
For me it would also save some wear and tear on my ancient winch motor.
Ryan
Old Jan 08, 2013, 05:24 PM
jetmaven is offline
Find More Posts by jetmaven
Vegasray - that has got to be the most stuffed drum I've ever see, how much and what weight , just curious .
jetmaven is offline Find More Posts by jetmaven
Old Jan 08, 2013, 06:02 PM
VegasRay is offline
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
Jetmaven - our winches are both filled with 1200 feet of 400 lb/test Nylon braided line from Memphis Net and Twine. We fly on desert gravel,stones, rocks (no grass) so we need a fairly thick line to resist abrasion. Over the years we found the 400 lb line works best.
Ray
Old Jan 09, 2013, 07:20 PM
jetmaven is offline
Holy cow ! I believe I have the same approximate size drum with almost 2000' of 250 test #24 line from Memphis and it comes nowhere close to what you have loaded up . I trust and hope you have a landing area not as menacing as where the line is laid out .
Old Jan 09, 2013, 07:42 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Best way to reel line in on a winch?
Carefully
tkallev is offline Find More Posts by tkallev
Question What is best way to replace wing on HZ Champ winginman Scratchbuilt Indoor and Micro Models 4 Oct 04, 2014 10:09 PM
Question whats the best way to get tail feathers straight tankreefer The Builders Workshop 20 Apr 13, 2012 12:28 PM
Question What is the best way to balance motors ?? G-unit Multirotor Talk 3 Mar 16, 2012 09:36 PM
Question What's the best knot for splicing winch or retriever line? Miami Mike Sailplane Talk 28 May 15, 2011 07:17 AM
Discussion What is the best way to cut out your foam for the straightest lines possible. wamsy55 Foamies (Scratchbuilt) 23 Jan 29, 2009 01:34 PM
