Old Jan 05, 2013, 04:19 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Straightening a warped balsa plank/wing?
So I found my latest headache Got this wing all feverishly planed down and sanded smooth from a solid 3/8" plank, only to discover that it's got some lovely built-in polyhedral. I've been messing with it since last night trying to figure out a good way to straighten it with no real results. I tried wetting the top side and then weighting its tips down while it dried, but no cigar. Also left it suspended with weights on its center overnight. Nada.
I know there's a solution, and I know you guys know it
This is the plane... I also tried to get a shot of the warpage but it's a bit of a tricky subject
Piece is online now Find More Posts by Piece
Old Jan 05, 2013, 05:44 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
If the sheet was warped like that to begin with you might have a problem on your hands.
It look from your second picture like it's mostly the one wing that is closest to the camera. Or is that an optical illusion due to the curved leading edge?
I'd brace and lash it to a big 2x6 or similar so that it flexes the curve out of the wood and in a way that it leaves a good 1 inch space between the 2x6 and the wing. In fact you want to slightly overbend the wood so it's forced the other way by about the same amount.
Then with something you have that is available to you make up a well insulated steam box and stick the wing and a kettle full of water into the box together and let it sweat. The idea is that you want BOTH heat and moisture to soften the lignum in the wood cells so that it eases the curves. You'll need to keep it hot and steamy for a good hour or more to ensure full saturation of the wood and proper softening. Then open it up and allow it to cool and dry for a couple of DAYS still strapped to the support board that
BMatthews is offline Find More Posts by BMatthews
Old Jan 05, 2013, 07:50 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Would the old soak the balsa with ammonia trick work? Maybe in combination with the steam box????
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Jan 05, 2013, 09:29 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Likely a little overkill to do both. But if the wood proves stubborn? Sometimes a little overkill is just the right amount....
Old Jan 05, 2013, 09:41 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
Houshold ammonia has detergent in it and is really not potent enogh to affect a softening of the wood fibers. Indusrial strength ammonias are avaiable from janitorial supply wholesalers, etc. and may be just the ticket BUT require extreme care in handling and a large enough container into which the balsa and the noxious liquid can be sealed.
packardpursuit is offline Find More Posts by packardpursuit
Old Jan 06, 2013, 10:39 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
That sure is a pretty airframe! Ailerons? Speed plane?
ARUP is offline Find More Posts by ARUP
Old Jan 06, 2013, 12:13 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
I think this is the way to go.Build/ find a trough to take the wing,line it with polythene if you're not sure it's watertight.Place the wing inside,silicon seal a top on with a plug able hole to pour the ammonia in.
Needs be done outside with the full spec of safety gear!
( or you could buy the balsa planks from the other thread..........)
Stuart A is offline Find More Posts by Stuart A
Old Jan 06, 2013, 10:21 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Hmmm... Thanks for the help, guys. It looks like with the stuff I have on hand, it'd be easier/cheaper just to go back to the shop for another plank (absolutely ramrod straight and consistent this time) and do it over. I think I'll just continue on course with what I have. There will be two nearly full-span 1/8" round fiberglass spars epoxied into the wing, so I might be able to use them against the wood to straighten it out. I don't love the idea of doing it that way, but it looks like the best option.
Thanks! It's an evolved Speed 400 racer based on Paul Daniels's Slipso400 but reworked around more modern gear. Power system will be a Mega 16/15/3, 3S 1800mAh 30C pack, 60A ESC, and APC 4.1x4.1 prop. Generally good for ~165mph straight and level. I'm basically building an airframe to match a Voodoo's abilities for $250 less than one .
Ailerons are literally the last step; they don't get added until the wing is entirely finished... Mwahahahaha
Old Jan 07, 2013, 12:26 AM
Petem is online now
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Hinge line
If you decide to go ahead, finish and fly, the only significant issue might be the aileron hinge line - needs to be straight for smooth operation.
I notice my Easy Glider Pro has smoothly curved wings, and the aileron hinge line follows a dead straight line from near center at both ends to near the top in the centre of each aileron.
You could mark a similar hinge line if you have to, and carve the aileron LE to allow good movement - not as neat as a top hinge, though.
Cheers,
PeteM
Petem is online now Find More Posts by Petem
Discussion Straightening Warped Balsa Surface NEW222 Beginner Training Area (Fuel) 6 May 15, 2012 10:41 PM
How do I straighten warped balsa?? rver43 The Builders Workshop 2 Sep 24, 2004 04:29 PM
Question Straightening Warped Glassed Balsa Tails? marctrudeau Hand Launch 1 Mar 24, 2003 10:12 AM
Straightening Warped Foam Wing WhiteCloud Foamies (Kits) 1 Feb 10, 2003 06:57 PM
Straightening warped balsa-sheeted foam core wings cold boy Foamies (Kits) 2 Mar 20, 2002 11:37 AM
