Old Jan 05, 2013, 03:06 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
RFM Folding prop-spinner offset question?
Hi,
I have a RFM folding prop 17x18 model 5 offset.
On variuos websites, the vendors say "you must use a offset spinner"
Do I really need to get a RFM offset spinner or can I use a beefy stock spinner and the prop will be ~17x13 or something less than 17x18?
Going on a 1509 1.5d 6.7 will setup for ~1500watts on short burst runs of ~5-15 seconds.
Tony
kilwein is offline Find More Posts by kilwein
Old Jan 05, 2013, 04:10 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
What is printed or impressed on your blades? Does it say 17x18 or 17x13?
jaizon is offline Find More Posts by jaizon
Old Jan 05, 2013, 04:14 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
It has 17x18 model 5 printed on.
Not sure if the offset yoke verses non offset yoke changes the pitch.
I was hoping to run a non offset yoke verses buying a $50 offset spinner.
May be a mute point as on a new three cell 5000mah neu pack, the ICE CC controller says it draws ~160 amps at ~10.5v then shuts down as it is supposed to. Looks like I will be selling this prop and getting a smaller one.
Old Jan 05, 2013, 04:45 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
Yes. An offset yoke will change it. A +3 offset will make it a 17X21.5. Zero offset and you will get what you see. As far as I know there are no negative offset spinners. If you need less pitch, just sell this one on RCG.
Old Jan 05, 2013, 04:52 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
Hi Jaizon,
It will be going up for sale soon.
Tony
Old Jan 05, 2013, 06:59 PM
rev.iain is offline
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
Are you looking at a TWISTED yoke or and OFFSET yoke?
There is a big difference. An OFFSET yoke does require a special spinner. Both impose additional load on the motor and ESC, but with different goals.
The TWISTED yoke is intended to increase pitch, but the OFFSET yoke is intended to allow the blades to fold closer to the fuselage. The value of which is debatable.
Iain
rev.iain is offline Find More Posts by rev.iain
Old Jan 05, 2013, 08:10 PM
kilwein is offline
kilwein's Avatar
Joined Jan 2007
RFM data say's, must use an offset yoke with these props.
I put these on a normal yoke and it looks like it works, but their statement "must" has me wondering, as I never have used these before.
Looks like I am going to put the prop up for sale and get a smaller pitch prop.
They do look nice.
Tony
Sold RFM folding prop with HM Light Spinner ShredAir Aircraft - Electric - Power Systems (FS/W) 3 May 12, 2007 09:19 AM
Off Site RFM 16x16 thin folding prop and 32mm spinner hbielich Aircraft - Electric - Power Systems (FS/W) 3 Dec 06, 2005 07:45 AM
FS: RFM 32/6 Spinner and RFM 16x16 Thin Folding Prop PDX Slope Pilot Aircraft - Sailplanes (FS/W) 2 Jan 09, 2005 11:00 AM
FS: RFM Carbon 32mm spinner for folding props (4mm shaft) kyril Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2004 09:57 AM
RFM folding carbon props don't fit RFM turbo spinner? opualuan Power Systems 1 Jul 11, 2003 03:25 AM
