Old Jan 09, 2013, 05:12 PM
rimshotcopter's Avatar
Joined Aug 2009
Colored Text but it is a starting point.
Video overlay with PIC18F258, color scrolling text (9 min 30 sec)
http://electronics-home-projects.tripod.com/
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 10, 2013, 05:42 PM
Joined Mar 2009
Maybe not exactly what you're looking for, as it is generated at ground station, but there's a potential :
OSD Cockpit for FPV : 3D cockpit + HUD + 3D radar + antenna tracker + google earth (6 min 0 sec)
flipflap is offline Find More Posts by flipflap
Old Jan 10, 2013, 06:32 PM
Ascended's Avatar
Joined May 2012
Originally Posted by rimshotcopter View Post
Only from an RGB input, not CVBS which our cameras output...
Ascended is offline Find More Posts by Ascended
Old Jan 10, 2013, 06:36 PM
Joined Aug 2009
Interesting and we are learning.
What are the symbols here "CVBS"? Would like to do some research.
Thank you.
Edited: Never mind: http://en.wikipedia.org/wiki/Composite_video
Old Jan 11, 2013, 02:42 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
http://vimeo.com/23092643
Well by judging from some replies in this thread that is the future.
But for myself I'd rather have a solution that transmits everything in the video stream to make it compatible with simple goggles and video screens.
boopidoo is offline Find More Posts by boopidoo
Old Jan 11, 2013, 06:37 AM
Joined Aug 2009
There is nothing precluding the overlaying process to occur on the ground verse on the aircraft.
Old Jan 11, 2013, 12:37 PM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I didn't say otherwise. I replied to flipflaps comment that it was made on a ground station.
Old Jan 11, 2013, 01:23 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
if you have a cockpit overlay, it might be possible to use information from the pan channel to make it so that the info is only visible when the camera is facing forward, or even add input from tilt so you can look 'over' the panel, then down if more info is needed.
ashdec87 is offline Find More Posts by ashdec87
Latest blog entry: SS FPV Maiden
Old Jan 11, 2013, 02:44 PM
Joined Mar 2009
That's actually why the cockpit was designed in 3D : it can be moved in any position according to the head tracker position. So if the pilot looks on the left, the camera on the plane looks on the left, and the cockpit is drawn on the right.
I made some tests like this one (but it's quite old stuff now) :
Virtual Cockpit for FPV - Proof of concept (1 min 30 sec)
Old Jan 11, 2013, 02:48 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
that's very cool
Joined Mar 2009
I agree, but when I started the project, almost all that was possible onboard was a microcontroller and a max 7456 osd (as in most current osd systems). Now I think that with the raspberry pi it's maybe possible to create something colorful onboard.
My goal was also not to have too much $$$ in the plane, in case of crash...
I expect also computers to be so small as to be integrated in goggles in the near future. The raspberry pi is credit card sized, with the processing power of a pentium 3 + 3D graphic card.
Old Jan 11, 2013, 02:49 PM
Joined Aug 2009
+1 Bingo!!!
Old Jan 13, 2013, 03:36 PM
Joined Aug 2009
Are there any risk takers out there?
Propeller Backpack
The Propeller Backpack is a compact, multipurpose Propeller-based module that is optimized for audio and video applications. Out of the box, and without programming, it serves as a video character display for your BASIC Stamp (or other compatible controller). Using one of our 3-wire Extension Cables (#805-00001 or #805-00002), you can plug the Backpack into a standard 3-pin servo header and communicate using a simple serial protocol. Any NTSC video monitor plugged into the Backpack’s A/V connector will then display the characters sent by your program – in color, in selectable windows, and with selectable character sizes.
http://www.parallax.com/Store/Microc...2/Default.aspx
Old Jan 13, 2013, 06:04 PM
Ascended's Avatar
Joined May 2012
Propeller Backpack
While the prop will output colour video, it's generated internally. What you need for OSD is at the very least a video signal timed to the cameras which you can then switch in and out between one source and the other - however this precludes any use of transparency. The prop, as far as I know, cannot be synced to the pixel clock of a camera (using hsync/vsync) - only it's own internal timing.
Old Jan 13, 2013, 06:18 PM
Joined Aug 2009
Serious, I do not know and from the source I received this from, stated, it would not work with an arduino so I most likely will not ventured this way however, in the Overlay document, it states.
General Description
The video overlay object for the Propeller Backpack provides the ability to overlay text on an NTSC video signal using a simple byte-oriented protocol. With the included overlay terminal program, BASIC Stamp (and other micro) users have the ability to control the overlay process via the Backpack’s three-pin serial interface.
http://www.parallax.com/Portals/0/Do...tv_overlay.zip
Discussion Using EPSON MOVERIO glasses and DJI iOSD to create a functional HUD vislaw Multirotor Talk 9 Apr 25, 2013 12:11 AM
Discussion Cleaning cockpit "glass" SafetyChain Painting and Finishing Tips 5 Aug 28, 2012 02:04 PM
Wanted 1/4 Scale Accessories (pilot, cockpit, spoiler, tow-release) pchewn Aircraft - Sailplanes (FS/W) 3 Feb 23, 2012 09:13 AM
Discussion All I'd like is onboard video with OSD Tomy. Video Piloting (FPV/RPV) 3 Jan 15, 2012 06:39 PM
Discussion Those with no osd would like to see 400ft agl on a few setups branflakes Video Piloting (FPV/RPV) 11 Sep 20, 2011 12:14 PM
