Old Jan 05, 2013, 10:12 AM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
FoamCasualty 6 Axis CNC Foam Machine
Bert and I have been working on this setup for some time now and a lot has changed since the original thread so I decided to start a new one. The price is $3500 and over 3 years of engineering are done for you. You supply the keyboard, monitor, mouse. The Foam Cutter comes as a kit, including the stand, the wire, the mill, and the computer that runs the machine.
Sketchup is our CAM platform, as we've written a custom plugin, NCGen, that allows wire cutting, 3d milling, and 2d milling.
Presenting the FoamCasualty 6 Axis Foam Cutter:
Cycle test the FoamCasualty 6 Axis Foam Cutting CNC Machine (0 min 26 sec)
Our Machine and Control Solution are manufactured in Halethorpe, Maryland.
We debuted the system at the 2012 Weak Signal Show in Toledo, Ohio and had a great reception.
The general goal for our system was to be able to hotwire and then mill a wing for foam constructed aircraft such as my Corsair. The results have exceeded all of our expectations. Here is a link to one of the later prototype builds and the results of it's cuts.
Our most limited axes (Z and W) are run at a rapid travel (G0) of 90ipm (~2200mm/min). Foam wire cutting however requires a much slower rate of about 4ipm. In the XY plane we cut at 200 ipm with higher speeds capable, although I have not tested the limit.
We have sold several machines now, one of which is used in industry at Com-Pac International. Com-Pac uses our product to demonstrate large foam profiles of tiny extrusions that are used as medical/space grade "zippers" for plastic bags that absolutely can not leak.
I'll be getting some more pictures up soon, for now here is some video of it cutting:
FoamCasualty 6 Axis CNC Foam Cutter (3 min 33 sec)
tvcasualty is offline Find More Posts by tvcasualty
Old Jan 06, 2013, 05:06 PM
Pile-it
Alien_Tech's Avatar
United States, CA, Edwards Air Force Base
Joined Nov 2007
Fantastic machine! Have you sold any yet?
Alien_Tech is offline Find More Posts by Alien_Tech
Old Jan 08, 2013, 05:34 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
We have sold several. Here is a picture of some of the foam extrusion mock ups that Com-Pac Int. has made with our machine.
Old Jan 08, 2013, 07:26 PM
Austin,TX
Joined Jul 2009
Awesome machine!
That looks very swell! Is that a brushless outrunner spinning the spinny thing?
I'd give my left pinky toe to know where to get a long endmill like that. Any chance you would share?
Cheers!
billcat is offline Find More Posts by billcat
Old Jan 09, 2013, 05:29 AM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Thanks billcat,
It's a 450 heli style outrunner driving the spindel. Low cost, higher torque, and easily replaceable should it decide to fail.
The endmill is not really a trade secret.
Check out Mcmaster-Carr, it's a 2" or 3" 1/8" diameter ball endmill:
2" 8878A22 or 8885A191 or 8885A192 or 8885A193
3" 8878A35 or 8885A211 or 8885A212 or 8885A213
http://mcmaster.com
Old Jan 09, 2013, 09:01 PM
Austin,TX
Joined Jul 2009
Ahh..., the wonderful McMaster! I have purchased endmills from them already but did not find any of the long ones at the time, I guess I needed to look a little harder.
Thanks for the advice!
Old Jan 09, 2013, 09:47 PM
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Do you think your mill could cut 1/8" ply given a shallow cut, slow feed, and several passes? I would sure like to cut formers in addition to foam.
BillO is offline Find More Posts by BillO
Old Jan 09, 2013, 09:50 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Can a more stout router motor be used? I'm really intrigued by this for my kit production, but would rather have a little more muscle for the mill part. I see lots of possibilities!
Old Jan 18, 2013, 11:47 AM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
I was wanting to respond with some pictures or video of cutting harder materials but I can’t seem to find any and I did not get time to get out to the shop and cut over the last weekend.
I don’t want to pull any punches about our machine so here it goes, please keep in mind that it was designed to cut foam, but we understand the want to also mill harder material for use in RC aircraft construction.
The largest issue we had to overcome, and is the limiting factor for harder materials, is not so much the small brushless motor driving the spindle. The real issue is all of the degrees of freedom required to cut tapered wings/profiles with the bow (as it’s built into the mill gantry). The gantry is only pinned to the left side, to more or less a u-joint. The other side is supported, but is allowed to slide along the X axis. A typical gantry is pinned from both sides in a very rigid arrangement, while ours basically is a cantilevered gantry, and the corner is a u-joint, that is also allowed to rotate. This means our machine must sacrifice some rigidity for flexibility, but we feel for the purpose of cutting foam the trade off is well worth it.
The bottom line is that it can be done, if you have the right endmill, at a slow enough feed rate, with a shallow enough pass. As the machine is designed to cut foam, do not expect to be able to rip through plywood at 200ipm at 1/4” depth. Less then 10ipm at 1/32” (or less) is far more reasonable for this system and any harder material will obviously put more wear on the components.
I have cut 1/32 – 1/16 counter top material (Formica) for control horns.
I have cut 1/16 – 3/16 “light” plywood for firewalls.
I have cut 1/8 to 1/4 deep into MDF material for the table top.
And
I have cut 1/8” expanded PVC (almost like plastic) for firewalls.
I will try to get some more video up as soon as possible, and I’ve got some balsa to try to chew up for testing as well, maybe I’ll make some demo ribs.
Old Jan 18, 2013, 12:49 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Hi,
Thanks for the response. I have a laser, so the cutting part is no biggie for me. What I would like to do in addition to servo pockets, hinge lines etc, is to cut things like Corian or MDF to make plugs for molded parts like canopy's and cowlings. Do you see that being possible?
Old Jan 18, 2013, 05:02 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
I do understand the problem.
Unfortunately I do not believe this machine, designed as a foam cutter, is entirely capable of working with harder materials for that purpose. Given enough time, proper dust collection, and the correct end mill I believe parts could be made, however you would be extremely limited by the amount of material that could be accurately taken off at a time. A simple 3 axis mill would be much better suited for this process.
However, I do make mold parts with the machine, only they are made from foam.
I am limited by a 2" long end mill so I use blocks of 2" thick foam (1.875" actual) to cut my parts and then glue them together. Once assembled I will coat them with StyroSpray and they will be fine for several draws. If a longer lasting mold is needed a Plaster of Paris mold can be made from the first draw from the foam part. Obviously it's not a Corian or hardwood mold, but for hobbyist use it's a good low cost solution.
If your heart is really set on harder materials, using our basic platform, we are in the process adapting the machine to be a sole 3-axis mill. The 3 axis mill will not be able to wire cut, but will maintain the dimensions and rapid travel speeds of the original setup. The idea is a more conventional setup, capable of a full sheet of depon foam, yet providing more structure for harder materials to be cut. The price point will be about the same as the 6 axis machine, perhaps a bit less as fewer steppers are needed. Our goal is to have it ready for the Toledo Show this year.
Old Mar 19, 2013, 12:06 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
Update
Just got in the latest shipment to assemble to have ready for sale at the Weak Signals show in Toledo this year. We've really refined our shipment process, and now include pre-wiring and pre-assembling on some of the more challenging parts. There is a lot of work involved in getting the parts ready like this, but the results are much worth it. Also we've streamlined the process to only sell the machine in white, so if one was to order one, this is now what it will look like.
I'll be adding more pictures as we assemble the machine from here.
If you are curious as how this all goes together take a look at some of the assembly reference drawings here:
http://www.foamcasualty.com/?p=410
Thanks!
Old Mar 19, 2013, 12:16 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Sweet, wish i could afford one...
Eric B.
AirX is offline Find More Posts by AirX
Latest blog entry: T/A 37 Tweet/Dragonfly
Old Apr 02, 2013, 12:56 AM
Kevin Matney's Avatar
United States, MI, Monroe
Joined Mar 2000
Are you going to the Toledo Show?
Kevin Matney is offline Find More Posts by Kevin Matney
Old Apr 03, 2013, 07:54 AM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
We are going to be at the Toledo Show!
Help! Foam cutting CNC machine Plans electro77 The Builders Workshop 8 Nov 11, 2012 12:26 AM
Discussion Making Reusable Molds with CNC Machined Foam and Stretchelon Bagging Film AcmeAircraft Composites Fabrication 6 Apr 30, 2012 01:50 PM
Help! Cnc foam cutter 4 axis plans srkipa Foamies (Scratchbuilt) 1 Apr 04, 2012 03:41 PM
Wanted stepper motors for 3 axis cnc machine snolord1 Non R/C Items (FS/W) 0 Mar 25, 2012 07:58 PM
Discussion FoamCasualty: 4 Axis CNC Hot Wire Cutter tvcasualty CAD/CAM 35 Jul 12, 2010 09:12 AM
