I need a control rod recommendation
I've been looking online for something to control the flaps on my current build and haven't found exactly what I need. It needs to have an offset to allow for clearance.
The Sig SH-555 setup in the pic below is pretty close, but I need it to have the torque rods rotating through a tube such as those on strip aileron torque rods. The Sig version does come in either 4 or 5 inch spread with either left or right offsets, but no torque tube. Suggestions? |
That flap system won't have much of a load on it...I believe you can take a piece of 4-40 wire (3/32"), and a couple of pieces of tubing,and make your own.A 3/32" nose wheel steering arm,installed along with the tubing,then making the bends will give you the same result.-for a couple of bucks.
1/16 " music wire will work, if you want strength,but I don't know of that small a steering arm. I like your drawings. |
Latest blog entry: Model Builder
Dang, a fella takes a couple of decades off from building and forgets the simple stuff! Man, that's a long time though! ![]() @lindart - yah... I DID remember that trick from my prior days. Continuing to clear the cobwebs here! ![]() Thanks all. |
Got it!
I cut one arm off of a servo arm, drilled a hole for the grub screw and inserted a 1/16" wheel collar into the arm hole. I left the grub screw hole undersized and actually threaded the screw into the plastic in addition to driving it into the wheel collar. Simple and dirt cheap. Thanks again everyone. |
Do it yourselfers
Necessity is the mother of invention.
Well done. |
Yep, when I get to the point where I'm actually constructing the wing and bending the wire to fit, I'll grind a flat on the wire once the final position is established. Was thinking that I'd epoxy the arm to the collar but soldering the collar to the wire sounds like a solid approach. I'll do that as well!
Thanks again, ya'll. |
| Thread Tools | |
| For Sale Tail Control Guide for T-rex 600,550 Tail Push Rod (Blue) | ucusclub | Aircraft - Fuel - Helis (FS/W) | 3 | Jul 25, 2012 06:15 AM |
| For Sale Metal Tail Control Guide for T-rex 700 , Tail Push Rod | ucusclub | Aircraft - Electric - Helis (FS/W) | 0 | Apr 09, 2012 03:20 AM |
| Question PZ Habu Control Rod Position | Mike81 | Foamy EDFs | 0 | Mar 17, 2012 12:37 PM |
| Wanted Sullivan Precision Control Rod | ROYLAB | Aircraft - General - Miscellaneous (FS/W) | 0 | Feb 28, 2012 11:27 AM |
