Old Jan 05, 2013, 06:10 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Flaps on Delta wing
How would Flaps on delta wing work?
On planes that have a measurable distance between tail and wing like F-18(ok, not exactly delta) F22, where would the CG be? Behind? Then flight characteristics?
On one-piece delta wing with aileron mix? Surely it acts like elevator.
Teddy Ong is offline Find More Posts by Teddy Ong
Old Jan 05, 2013, 07:40 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
A properly set up delta doesn't need flaps as the wing itself acts like a flap One of the characteristics of a delta is the ability to land at a very high angle of attack, the wing itself causing a lot of drag. Some full size deltas use spoiler ahead of the trailing edge of the wing, to do just that, spoil the lift. To land you gradually pull back on the elev, adding throttle to control the decent rate. With enough back stick, with the nose high, and enough throttle on. you can fly quite stable at almost walking speed. Of course this depends on wing loading too.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jan 05, 2013, 08:49 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Flaps on delta and elevon models are usually implemented as drag brakes. As Gord noted, you really don't need them for landing. But if you want to make a sudden change in airspeed w/o gaining altitude, a drag brake is the way to do it.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Discussion Urgent: Modelling Delta Wing On Solidworks Billy88 CAD/CAM 24 Dec 08, 2014 05:53 AM
Discussion Need help on servos and settings for dx6i delta wing Wa7sh Foamies (Scratchbuilt) 4 Aug 08, 2012 06:08 AM
Discussion Air Brakes on a delta wing... yogz Flying Wings 10 Apr 26, 2012 04:56 PM
Discussion Air Brakes on a delta wing... yogz Modeling Science 0 Apr 19, 2012 04:31 PM
Discussion Delta wing (elevon) on 9X Teamsherman Australia 20 Apr 04, 2012 07:46 PM
