Old Jan 05, 2013, 05:53 AM
nicosoh is offline
Find More Posts by nicosoh
Australia, NSW, Randwick
Joined Nov 2012
wiring a bec and esc in parallel
hi guys, i recently bought a durafly trojan and was deciding to put a bec in it cos it has tonnes of servos and lights and retracts as well, 15 wires in total all running off one esc. what i thought of doing at first is to go by the books and remove the red wires and then connect half of the wires to the bec and leave half on the esc cos i only have a 3A bec. but then i got lazy and thought that i might just wire the esc and bec in series and therefore provide it with more current output if needed. dont know if anyone has tried it before but please let me know what you think! and do you think it will work. and if anyone has flown a durafly trojan and had a great time or brown outs please let me know too! thanks
nicosoh is offline Find More Posts by nicosoh
Old Jan 05, 2013, 08:20 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
SERIES would be a complete disaster. PARALLEL as in your header might just work but it's not a very good idea. If the voltages produced by the internal BEC in the ESC and the separate BEC are not identical they can sort of fight....and there's a chance that one or both of them will die.
Much better to get a separate BEC that provides all the current you need and disconnect the internal BEC.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 05, 2013, 10:37 AM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
If one BEC won't meet your needs, you can always use two, isolating one group of servos from the rx and other servos, My 1/6 Cherokee has retracts, which I power with a separate BEC from the one powering my rx and servos. I use a Y cable, with the red wire pulled at the rx, and the loose end connected to the BEC. The common ground remains connected from all sources. If you have multiple loads to power this way, there are power-tap adapters made just for this, commonly found in the larger 3D models.
Wintr is offline Find More Posts by Wintr
Old Jan 06, 2013, 03:15 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
As has been mentioned, connecting BECs in series would be a disaster, and connecting them in parallel can sometimes cause problems.
In your situation I would be tempted to split the supplies, with the external BEC powering the receiver and servos (so power won't be lost if the ESC fries, or if the retracts stall and cause a voltage drop), and the ESC's BEC powering the retracts and lights. But you'll need to verify that both BECs are capable of giving enough amps for what you want them to power.
abenn is offline Find More Posts by abenn
Discussion ESC wiring in series or just parallel? crispycargo Multirotor Talk 3 Sep 13, 2014 01:57 PM
Discussion Traxxas ESC XL-1 BEC wiring plane58 Dock Talk 8 Dec 05, 2012 11:30 PM
Question BEC to ESC Wiring odecius Power Systems 4 Feb 26, 2012 05:59 PM
Discussion Wiring ESC's and BEC's in Parallel? dashunde Power Systems 3 Mar 18, 2011 10:49 AM
Question 2 Phoenix 10 ESCs BEC 5 volt lines in parallel? Iain Power Systems 6 Aug 22, 2005 03:23 AM
