Old Jan 05, 2013, 03:56 AM
Azuritko is offline
Find More Posts by Azuritko
Azuritko's Avatar
Slovakia
Joined Nov 2011
Help!
Diy parallel Li poly and charging
I want to parallel connect two or three of theese batteries http://www.hobbyking.com/hobbyking/s...gle_Cell_.html to get 3,7V 2000 or 3000 mAh battery. As I found, I can only solder positive connectors together, and negative connectors together.
And I have B6AC charger. How can I charge this battery when I will make it? Can I plug it as 1S battery or I need to make ballance connectors somehow? If so, how?
Azuritko is offline Find More Posts by Azuritko
Old Jan 05, 2013, 07:23 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
When you parallel 1S batteries the result IS a 1S battery so that's what you charge it as. Since all the cells are connected directly together they will always be at exactly the same voltage so there's nothing to balance.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 05, 2013, 06:24 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
^^that^^
dacaur is offline Find More Posts by dacaur
Sold Li-poly / Li-ion Balance Charger From Common Sense RC RobT01 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 21, 2012 12:35 AM
Sold Poly Charge 4 / charge 1-4 cells at a time fly2bob Aircraft - Electric - Batteries & Chargers (FS/W) 10 Jun 21, 2012 05:17 PM
Charging 2 LI-Poly packs in parallel??? aireze Batteries and Chargers 13 Dec 05, 2003 11:11 AM
Charging Li-Poly = charging Li-Io ? Niels Batteries and Chargers 2 Aug 22, 2003 03:47 PM
