Old Feb 18, 2013, 06:36 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Hey man, no worries
My turn now... What's that headphone amplifier in the background of your pics?
Cheers.
Soma is offline Find More Posts by Soma
Old Feb 18, 2013, 05:09 PM
vpsporb is offline
Find More Posts by vpsporb
Canada, ON, Ottawa
Joined Dec 2011
My headphone amp is a Millet Hybrid MiniMax, a hybrid Tube, transistor amp.
Below it is an Audio-GD NFB-11 based on 32bit Sabre ES9018, and below that is the Digital Interface for Co-ax in-out.
So from PC, Spdif out-->Digital Interface(co-ax in-out)-->NFB-11-->to Logitech Z5500 console/interface for PC 2.1-5.1DD/DTS or NFB-11 L+R out to Millet MiniMax headphone amp to either Fostex T50RP or Beyerdynamic DT990 600ohm.
Important is the adionsoft WASAPI output dll for Winamp/Mediamonkey for best sound quality.
I have an Asus Xonar D2 soundcard... but I prefer to pump the audio thru all that
Perhaps a bit more than you wanted to know.... but there you have it.
vpsporb is offline Find More Posts by vpsporb
Old Feb 24, 2013, 03:41 AM
Soma is offline
Joined Sep 2012
Hey mate, thanks for the details.
Phew! I wasn't expecting that much complexity
But good sound is always worth the effort.
I'll have to look up the hardware you're using.
Sorry for my late response, I've been away a while.
Cheers!
Old Feb 24, 2013, 07:46 PM
vpsporb is offline
Canada, ON, Ottawa
Joined Dec 2011
Well then, I hope you've been away busily building your "Alien Spider" frame at last! or were @least taking a few money shots of her for us. hehe j/k
here's a few links if you want to check it out a bit..
http://www.diyforums.org/MiniMAX/MiniMAXoverview.php
http://www.head-fi.org/t/452404/just...0rps-today-wow
http://www.audio-gd.com/Pro/Headphon...NFB11.32EN.htm
http://www.audio-gd.com/Pro/dac/DIv3/DIv3EN.htm
The Hybrid MiniMax headphone amp is a really stunning sounding Amp. Much much better sounding than the NFB-11's built-in HP amp. Combined with the ~$100. Fostex TP50RP headphones (based on Orthodynamic technology) the Bass reproduction is skull shakingly, massively HUGE! (definately a Club/Concert experience)
take care
Old Mar 12, 2013, 09:49 PM
heli-yeah is offline
Find More Posts by heli-yeah
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
I'm back, and with a frame!
I received it a short while after my last post, but I've had a lot going on, and haven't been able to spend much time on the forums.
Unfortunately, It arrived with some minor damage, but nothing too bad to be fixed. The lower center plate had a bit of splintering, and separation of the CF layers at the rear left FC post. I injected CA in between the layers, and clamped it, and now it is barely visible.
Description:
Hopefully it will never be an issue...
Now I'm waiting for motors, and ESCs to show up.
heli-yeah is offline Find More Posts by heli-yeah
Old Feb 12, 2014, 03:55 AM
Dimmitri is offline
Find More Posts by Dimmitri
Joined Aug 2012
Hi guys!
Here is my Alien Spider.
motors- http://www.buddyrc.com/sunnysky-x220...ess-motor.html
prop Gemfan 5030
ESC-http://www.hobbyking.com/hobbyking/s...ontroller.html
Flight controller-http://www.hobbyking.com/hobbyking/s..._GYRO_ACC.html
Control UHF 433Mhz.
Coursework Camera -http://www.readymaderc.com/store/ind...oducts_id=1275
Video Transmitter -http://www.hobbyking.com/hobbyking/s...er_Module.html
maiden flight FPV
Mini Alien Spider (2 min 7 sec)
Dimmitri is offline Find More Posts by Dimmitri
Old Feb 12, 2014, 07:56 PM
Soma is offline
Joined Sep 2012
Great build man!
The way you've mounted the 2204's on the X-mounts is brilliant!!! Was that a perfect fit? Fantastic idea!
It sounds light in flight too, as the 5030 props don't sound stressed at all. Do you have an AUW?
Love the flight cam mount too! Perfect fit. Also the silicone tube clean section is a great idea. Do you have a side pic of that? What plate have you used?
Did you buy the frame from GLB?
Inspiring stuff
Old Feb 13, 2014, 05:47 AM
Dimmitri is offline
Joined Aug 2012
Originally Posted by Soma View Post
Great build man!
Yes, perfect fit.
Do you have an AUW?
Did not understand, the language barrier, I use google translate.
Cut from a similar board http://www.ebay.com/itm/10Pcs-FR4-PC...item5aefa46803
Yes, frame from GLB.
Some more photos.
Old Feb 13, 2014, 07:03 AM
Soma is offline
Joined Sep 2012
Cheers mate!
AUW is short for "All Up Weight" meaning the weight, ready to fly.
Your idea to bolt up the Sunnyskys with the X-mounts is just brilliant! Can't get over that
Old Feb 13, 2014, 12:38 PM
Dimmitri is offline
Joined Aug 2012
Thanks Soma!
AUW with battery 3S-2140mA, is 490 grams.
Old Feb 13, 2014, 08:25 PM
Soma is offline
Joined Sep 2012
Wow! That's what most mini FPV quads are weighing with a 3S 1500mAh pack!
I hope you don't mind another question... What's the 'Dry' weight. Meaning the total weight, with Mobius, but NO LIPO?
Cheers man.
Old Feb 14, 2014, 01:13 AM
Dimmitri is offline
Joined Aug 2012
Weight without lipo, 330 grams. My Lipo 185 grams
My scales not quite accurate +10 / -10 g
Old Feb 14, 2014, 01:35 AM
Soma is offline
Joined Sep 2012
Thanks mate. Very good weight!
Your scales might not be too accurate, but they have a smiley face
Cheers man, enjoy!
Old Jan 05, 2015, 06:31 AM
angusfly is offline
Find More Posts by angusfly
Joined May 2013
hello guys,
my mini spider inverted flying
Cheers
Multicopter Inverted fly + Crash (4 min 19 sec)
angusfly is offline Find More Posts by angusfly
For Sale 3 pcs. Mini TiTan CF Frame + CF tail Fin $40 shipped GuiwanZC Aircraft - Electric - Helis (FS/W) 0 Sep 09, 2012 11:33 AM
Sold Uap1 Quad Frame with electronics + Spider Frame Kit + GoPro mount airbagit13 FPV Equipment (FS/W) 3 Aug 14, 2012 10:55 AM
Sold Uap1 Quad Frame with electronics + Spider Frame Kit + GoPro mount airbagit13 Aircraft - Electric - Multirotor (FS/W) 0 Aug 13, 2012 02:57 PM
Sold Trex 600E CF frame w/ bearings, etc (clone frame) [$45 shipped] Boomkidd Aircraft - General - Miscellaneous (FS/W) 0 May 12, 2012 11:00 AM
Question Anyone mount a cmaera on a GLB frame AusTelemetry Multirotor Talk 0 Jan 29, 2012 06:59 AM
