Old Jan 04, 2013, 07:13 PM
B450guy is offline
Find More Posts by B450guy
United States, FL, St Johns
Joined Jan 2012
Help!
How much does the feathering shaft need to be bent to necessitate replacement?
I am checking my Blade 450 for damage after a crash. When I checked the feathering shaft/spindle, it was moving a minute little bit. How much movement should it be before I replace it?
Thanks for your help!
B450guy is offline Find More Posts by B450guy
Old Jan 04, 2013, 08:20 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Considering how much vibration you get from the pitch linkage being so much as half a twist off, i'd say, not a lot. The slightest movement would translate to big ones as it travels down the length of the blade.
Hajile is online now Find More Posts by Hajile
Old Jan 04, 2013, 08:42 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
They are so cheap, and replacement is a 5 minute job, so I always replace mine when they are bent. If it is bent only a very slight amount, I might keep flying on the day, but will always replace it when I get home. I like to have my heli's flying silky smooth. No matter how little it is bent, I am always pleasantly surpised how much better it flies with the new one.
Harrow is offline Find More Posts by Harrow
Old Jan 04, 2013, 09:36 PM
old4570 is online now
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Not much , once you detect a variance [ bend in the shaft ] replace it ..
If the feathering shaft moves a lot , it can change pitch on you and put out your blade tracking .
????? $1 to fix ?????
old4570 is online now Find More Posts by old4570
Old Jan 05, 2013, 09:08 AM
B450guy is offline
Joined Jan 2012
OK. Thanks guys!
Old Jan 05, 2013, 10:25 AM
Elios000 is online now
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
if it doesnt roll smoothly on a flat glass surface replace it
same test for the main shaft
Elios000 is online now Find More Posts by Elios000
For Sale Align spindle/feathering shaft wrench captainpitts Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2012 08:17 PM
Help! need help bad how do i replace shaft onpermax bl-480 jesawer33 Power Systems 1 Jul 26, 2012 07:34 PM
Help! How much balancing does the hub on your APC 13x6,5E prop need? wizprod Multirotor Talk 0 Mar 30, 2012 06:38 AM
Discussion Tarot250 FBL spindle shaft = align FB spindle shaft??? mattijs321 Mini Helis 1 Mar 05, 2012 11:04 AM
Discussion PLEASE HELP! Walkera V120d02 - Tutorial on how to remove/replace feathering shaft the desolate one Micro Helis 8 Jan 20, 2012 08:02 AM
