Old Jan 04, 2013, 04:29 PM
jelled123 is offline
Find More Posts by jelled123
Joined Jan 2013
Help!
My First Build - Can Someone Check My Parts List?
hello everyone!
so...
I'm new here to rcgroups and new in the rc world. I had a good electric rc car if I was 9 but it was just buy and drive. You learn nothing with that.
My first big question was: tricopter or quadcopter but I decided to go tri because it looks more flexible, cheaper and cooler. I'm going to do SOME areal video of the area were I live but that's all so the most important thing to me is speed and the ability to react, to make quick turns and so on.
now I saw a video on youtube and decided to build my tricopter somewhat like he did. He mentioned the parts in the description but some things aren't very clear to me.
as far as now these are the parts I have chosen:
http://www.hobbyking.com/hobbyking/s...idProduct=2164
http://www.hobbyking.com/hobbyking/s...rol_Board.html
http://www.hobbyking.com/hobbyking/s...occessors.html
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
http://www.hobbyking.com/hobbyking/s...idProduct=9678
http://www.hobbyking.com/hobbyking/s...idProduct=9679
http://www.hobbyking.com/hobbyking/s...dProduct=11331
http://www.hobbyking.com/hobbyking/s...rm_2s_4s_.html
so this is:
speed controller
multi rotor flight controll board ( pre programmed? )
USBasp AVR programming device ( do I need this? )
10cm M to M servo lead
wires ( red and blue )
8*4 props
low voltage warner.
so that's around 87$
now i have a budget of around 200$, a little more if needed so if some parts of me are too cheap...
I think that things that I need now are:
3 motors, in the video he uses this and it seems to be very powerfull
http://www.rctimer.com/index.php?gOo...0&productname=
1 servo, most guides say that it has to be a good one because it has to work very hard doing little corrigations all the time..
1lipo, in the vid he suggests: 3 cell 2200
is that good? better 4 cell? idk
1 transmitter and receiver. I know there's a really famous one on hobby king but I forgot the name :s
the frame i'll make my own unless there are some nice frame kits on the market?
not too fancy, the plan is to make it look like this:
Cheap easy tricopter build hobbyking rctimer hobbypartz (6 min 18 sec)
so my questions are:
are these parts all I need?
Do l need extra tools?
and then: wich battery, servo, transmitter and motors.
Thanks in advance and sorry for my bad english, I'm from Belgium.
greetz!
jelled123 is offline Find More Posts by jelled123
Old Jan 05, 2013, 05:50 AM
Joined Jan 2013
no one? ;\
Old Jan 05, 2013, 11:35 AM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Yes you'll need the AVR programmer to update the KK2. You don't need the voltage alarm if you solder a wire into the KK2 it has one included.
Turnigy 9x is the tx you're probably talking about, you can also use the programmer to upgrade the firmware on that.
I'd look at either the Blueseries speed controllers or the HK ones (F-30A part number). These can also have their firmware upgraded and will give smoother flight if you do that. The turnigy plush need a different programmer to upgrade their firmware and it's not nearly as well tested.
As long as your motors and ESC's can handle 4S you can use a 4S battery, however it results in hotter running ESC's and motors but does give you more power/speed
WendoNZ is offline Find More Posts by WendoNZ
Discussion My first Quadcopter!!!! - Build list dgonano Multirotor Talk 18 Jan 02, 2013 08:48 AM
Help! Can someone check my math? ritter4242 Power Systems 8 Oct 30, 2012 12:37 AM
Help! Help finalizing on parts list for first build! nloding Multirotor Electronics 9 Aug 08, 2012 06:49 AM
Discussion F-15 foam first time scratch build, parts list, help wanna go faster Foamies (Scratchbuilt) 5 Jul 27, 2012 11:03 AM
Build Log My First Quad Build, Parts List CH33ZEBURG3R Multirotor Talk 14 Jul 12, 2012 09:54 AM
