Old Jan 28, 2013, 11:09 PM
pyronaught is offline
Find More Posts by pyronaught
Potential Future Has-Been
Joined Feb 2009
Methane, like hydrogen, must be mixed with oxygen to burn. However, hydrogen has a much wider range of mixtures it will burn at than methane does. Methane will only burn when it makes up 4.4% to 17% of an air mixture, while hydrogen will burn in the range of 5% to 75%. So you could have quite a bit of air contamination in a methane balloon without worrying about it being flammable. The reverse situation is where you have the explosion risk-- which is a room full of air contaminated with a much smaller amount of methane. That's where you get the problematic 5-17% range that causes the scary explosion stories you hear in the news. In a balloon filled only with methane you would not be anywhere near that mixture, even if you were very sloppy in filling it or started with an envelope that already had some air in it. Methane has about half the lifting force of helium though, so you would need quite a bit more of it. This does not mean your blimp would have to double in length though, since volume increases in a cubed relation to it's individual dimensions. For example, if you had a 15 ft long blimp with a volume of 132 cubic feet, you would only need to proportionately scale it to about 18.5 feet to double its volume to 272 cubic feet. That still keeps the envelope small enough to make flying with methane viable, you just have to keep in mind that you would be buying twice as much of it as the helium.
Ammonia is another gas that can be used for lift, but it has even less lift than methane and has very noxious fumes.
Flammability Limit Reference:
http://en.wikipedia.org/wiki/Flammability_limit
pyronaught is offline Find More Posts by pyronaught
Old Jan 29, 2013, 08:44 AM
powerblimp is offline
Find More Posts by powerblimp
rc blimp manufacturer
powerblimp's Avatar
Switzerland, VD, Crans-près-Céligny
Joined Dec 2005
one good thing with methane is that the molecules are really big copare to helium or hydrogen
so the ris of leak by porosity is almost null!
loss per day will be minimum !
powerblimp is offline Find More Posts by powerblimp
Old Jan 29, 2013, 10:15 AM
Joined Feb 2009
Methane does seem like a good alternative that could keep RC blimps going even if the helium shortage makes helium unobtainable, at least with larger size blimps. It's much cheaper, much more available, much easier to keep from leaking over time and much less flammable than hydrogen when contaminated with air. The only down side is having half as much lift as helium, but that is at least a manageable problem.
Old Jan 31, 2013, 09:15 PM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
I still get helium for less than 10 cents a cube... truckloads or it
patrickegan is offline Find More Posts by patrickegan
Old Feb 01, 2013, 10:14 AM
Joined Feb 2009
Assuming you are talking cubic feet, that is still 25 times more expensive than the methane price mentioned here, which was .4 cents per cubic foot.
Old Feb 01, 2013, 12:34 PM
Yumastan RCAPA.NET
Joined Feb 2003
Yeah, but with half the lift.
Old Feb 01, 2013, 01:37 PM
Joined Feb 2009
OK, adjusted for lift it is 12.5 times more expensive. Plus you lose more due to leakage.
Old Feb 02, 2013, 01:46 PM
Yumastan RCAPA.NET
Joined Feb 2003
Depends on your fabric and some other conditions.
Old Feb 02, 2013, 10:44 PM
Joined Feb 2009
For any given envelope, fill that same envelope with methane and it will lose gas at a slower rate than helium. The smaller the molecule, the easier it slips between the "cracks." Helium has the smaller molecule, which is of course why it also has more lift.
Old Feb 03, 2013, 11:48 AM
Yumastan RCAPA.NET
Joined Feb 2003
True.
Old Feb 12, 2013, 03:19 AM
powerblimp's Avatar
Joined Dec 2005
and you can use methan to power gas motors so no more buyoancy problems!
Old Feb 12, 2013, 08:58 PM
Joined Feb 2009
This is actually what the Graf Zeppelin did. The gas cells were divided into two sections,with the lower one being filled with a propane-like gas called "blau gas" that had the same density as air so that there was no change in buoyancy as it was consumed by the engines. I guess they decided it took up too much volume though since this practice was discontinued on the airships built after the Graf.
Old Feb 14, 2013, 06:20 PM
xfc3dcd is offline
Find More Posts by xfc3dcd
Joined Dec 2007
We have a gig this weekend and had no problem getting helium albeit at a higher cost than before.
xfc3dcd is offline Find More Posts by xfc3dcd
Old Mar 06, 2013, 11:48 PM
broken flyer is offline
Find More Posts by broken flyer
Joined Sep 2009
Update:
Just thought I should check back in. I read how far this thread has come along and it is pretty interesting. When I had trouble obtaining helium earlier this year I went and looked at a variety of different lighter than air gases as well as gas mixtures and had come across both methane(I decided for my application it was too heavy, but I could see this being used effectively in a different lighter than air application) and ammonia(I decided this was far too dangerous to work with after reading about all the nasty side effects it has such as corrosion, that type of thing).
As for obtaining helium... I was fortunate enough to be able to secure enough helium through my school to fly my prototype aircraft and it was a success. I've also found a source though for helium if I need more later through one of my relatives that has been a long time welder. It is definitely not cheap. I believe it was $300 or $400 or so for a large tank which would just fill my craft as it had been originally designed.
I am proceeding with the project and am currently working on the final design for my UAV version of the design. I'm planning on designing it to be capable of flying with different gases and then the owner can determine what is the most economical and safest gas to fill it with for their application. One thought I had for safely using hydrogen was a vacuum pump integrated into the filling mechanism. Image a two prong filling handle where one side is a vacuum pump and the other is a nozzle for the hydrogen. You could insert the mechanism, pump any air out of the inside of the craft, stop the vacuum/close that valve and then fill it with research grade hydrogen, then that valve is shut and the entire gas bladder is isolated from the electronics. You could also empty it remotely from a distance so that encase of an ignition you would only lose the craft. Just one of my thoughts for how this could be done semi-safely.
Also. I've been asking around in the UAV forum for some suggestions as to what kind of a payload I need to make this capable of carrying for it to be useful to others involved with UAVs and so far I really haven't gotten much feed back. If any of you guys have an opinion or a suggestion I'd appreciate it if you would post it.
Here's that thread: http://www.rcgroups.com/forums/showthread.php?t=1845789
If you would like to take a look at the aircraft's design it can be found under the heading "Aerospace", sub heading "UAV", as well as the heading "News" at( www.awkengineering.com ). I'm very excited about this design and the platform in general and I have high hopes for it in the near future.
If there is an interest in it I wouldn't mind starting a build thread/discussion for it, but I'm a bit at a loss for where I would put it. This aircraft/near space craft falls under so many categories its hard to categorize in a single area if that makes sense. It incorporates electric power systems, scratch building, airframe design, it's a UAV, it's an airship, it's a VTOL craft, it's a multi-rotor, and it's an electric jet just to mention a few of the categories it could fall under.
Any thoughts as to where this belongs and if there is any interest in it?
Thanks.
broken flyer is offline Find More Posts by broken flyer
Discussion If I could get a good list of all of the parts I need it would really help. fooferdoggie Beginner Training Area (Aircraft-Electric) 11 Sep 18, 2012 12:29 AM
Discussion I need some help on a prop size and opinion if its going to work or not sherlockshah Pusher Prop Jet Models 1 Apr 20, 2012 10:04 PM
Discussion Would you buy LX models if you could get them on the East Coast wswayze USA - District IV 2 Jan 26, 2012 12:29 PM
Alert Would you buy LX models if you could get them on the East Coast? wswayze Electric Ducted Fan Jet Talk 11 Jan 18, 2012 03:41 PM
Help! I wonder if i could get some help here... bzn0941 Micro Helis 3 Aug 03, 2007 11:47 AM
