Old Jan 04, 2013, 02:30 PM
Daz393 is offline
Find More Posts by Daz393
Depron Daz
Daz393's Avatar
United Kingdom, England, Basingstoke
Joined Feb 2012
Question
Is this enough power?
Evening all!
The wife bought me the HobbyKing E-Fair electric glider http://www.hobbyking.com/hobbyking/s...40mm_ARF_.html for Christmas, but do I have enough power?
The model inc 1500mah 3s lipo, weighs 580g. I have a 28/31 1000kv outrunner turning a 7.5x4 folding prop. This gives around 70 watts at 6'ish amps.
Would this be ok? I've never flown a glider before so I'm not sure what I should be aiming for.
Many thanks
Daz
Daz393 is offline Find More Posts by Daz393
Old Jan 04, 2013, 05:00 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hi, Daz.
As motors get smaller it gets a bit harder to predict their performance. There just isn't much margin. The general rule is roughly 100-150 watts per 500 grams so you would be on the low end of the scale. Could you go with a larger prop without frying your motor and/or ESC? If one keeps in mind that a glider's motor isn't run for long periods one can push a quality motor pretty close to its limits. I would say that it will fly either way but it won't be able to climb very fast. But? One could give it a try as is and see how it works.
Cheers!
peterlngh is offline Find More Posts by peterlngh
Old Jan 04, 2013, 05:27 PM
Daz393 is offline
Depron Daz
Daz393's Avatar
Joined Feb 2012
Hi Peter.
The ESC is 25amp (35 burst) and the motor is rated to 150w, so there's plenty of scope. Would I go bigger in diameter or pitch?
Daz
Old Jan 04, 2013, 05:50 PM
Joined Apr 2012
Bigger diameter. One adds diameter for thrust and pitch for speed. At the speed of most gliders there's very little reason for a high pitch. Just guessing here but I would think your motor would work with a 9X4 or 9X5 prop. A 10X4 might even be a possibility. Assuming 150 watts you would still be well under 20 amps, assuming my rusty math skills aren't deceiving me, and would get very decent performance.
There are many vendors but Air Craft seems to have the best selection for low pitch folding props. Of course, in Europe, there are plenty of places that offer the whole Graupner line but this will provide a reference of what's available.
Cheers again!
http://www.aircraft-world.com/shopdi...-+AERONAUT+CAM
Old Jan 05, 2013, 04:42 AM
Daz393 is offline
Depron Daz
Daz393's Avatar
Joined Feb 2012
Thank you Peter
Question Motor has enough power for this plane? cad2blender Electric Plane Talk 1 Jun 25, 2012 11:51 PM
Discussion not enough dihedral...or is this airfoil just not suitable? ZAGNUT Modeling Science 34 May 25, 2012 01:51 PM
Discussion Is this amount money enough to keep me going in RC Planes? asdfghjk Electric Plane Talk 45 Apr 14, 2012 11:46 PM
Discussion This may be large enough shadco Batteries and Chargers 5 Apr 12, 2012 02:02 PM
Discussion PC power supply - Does this have enough power? Sherlock Batteries and Chargers 42 Feb 23, 2007 04:30 PM
