Old Feb 12, 2013, 07:31 PM
KDS450QS(ZYX4),V922,V959
FyreSG's Avatar
Singapore
Joined Apr 2012
The 0.67x macro+wide angle lenses for iPhones, would not work at 100% because it is designed for a "larger" lens (as compared to the 808). You do get a little bit of wide angle effect with the 808 as I had tried on it.
To achieve the full wide-angle effect, the "source" lens (i.e. 808 camera) has to be the same size as the intended one, i.e. iPhone camera lens. Putting this 0.67x lens over the 808 is like fitting a baseball cap on a fist.
Other than a reduced wide angle effect, the additional weight of the 0.67x is another concern.
But it does work very well on an iPhone.
FyreSG is offline Find More Posts by FyreSG
Old Feb 12, 2013, 07:35 PM
FyreSG's Avatar
Singapore
Joined Apr 2012
Activating/Deactivating video recording.
Originally Posted by FyreSG View Post
Transmitter
The button at the top left corner starts or stops video recording. When the video camera is not recording, the green LED beneath the camera module lights up; when it is recording, the red LED lights up.
Recap from the initial review in case anyone had missed it.
Old Feb 12, 2013, 07:52 PM
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
Video Processing
Just got the V959 Very impressive flight characteristics. My video however leaves a lot to be desired. It starts out really great but gradually degrades into stutters to the point that eventually I'm getting sequential stills. I've only tried the stock supplied micro 4gb micro sd. Do I need a faster (higher numbered) sd card? I am importing into a Windows 7 computer and using their stock video program. Do I need a different program? Thanks
7AC is offline Find More Posts by 7AC
Old Feb 13, 2013, 03:27 PM
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
finally received my v959 so excited even shot a unboxing video. But seller sent battery separately claiming that it's illegal to send by China Post with battery? Battery sent by HongKong Post but it's not tracking so far. I had battery from coaxial heli with the same connector so I checked the quad, seems to be great.
asanovrus is online now Find More Posts by asanovrus
Old Feb 13, 2013, 03:36 PM
asanovrus's Avatar
Joined Mar 2012
WOW. video is 16Mbps. incredible. that's why you need fast memory card with it. I recommend class 10. for 640x480 it's a bit too much. sound is decent too: 352kbps. I think I can slow video and even use stills. but in low light it's pretty noisy
Old Feb 13, 2013, 03:41 PM
asanovrus's Avatar
Joined Mar 2012
yes, you need Linux with new KDENLIve or at least ffmpeg can't imagine how people may use windows it can't playback file if it only slightly corrupted, shuts down windows and behaves like crap ... what it actually is. no offense. Linux saved my life 5 years ago. If you still need interface like W7 try sinclair
Old Feb 13, 2013, 10:06 PM
Canada, ON, Ottawa
Joined Jun 2009
... It starts out really great but gradually degrades into stutters to the point that eventually I'm getting sequential stills...
I took a short one. I was impressed by how smooth the video was with the 959 in flight. My V959 was ordered from BG. It came with a 2GB micro SD.
How long is your video? I can try something as long to see if I would have the same problem. I am using mplayer (basically with svn ffmpeg compiled in) on linux to play back though.
Wasp09 is offline Find More Posts by Wasp09
Old Feb 13, 2013, 10:12 PM
Canada, ON, Ottawa
Joined Jun 2009
Mplayer says.
Playing /opt/x/SUNP0000.avi.
libavformat version 54.59.106 (internal)
AVI file format detected.
[aviheader] Video stream found, -vid 0
[aviheader] Audio stream found, -aid 1
VIDEO: [MJPG] 640x480 24bpp 60.000 fps 19014.7 kbps (2321.1 kbyte/s)
I am using the stock 2GB SD.
Old Feb 14, 2013, 05:42 AM
X_Marine's Avatar
Joined Sep 2012
For any having problems viewing video from cam, please try the absolute best video/media player,, VLC open source and completely free. http://www.videolan.org/vlc/index.html
This thing does it all and with lots of option etc..
For your still pics I recommend XNview, also free and will allow quick easy adjustments of levels "brightness&contrast" cropping adding text and converting etc.. http://www.xnview.com/
Hope those help some..
Many thanks
X/BillyD..
X_Marine is offline Find More Posts by X_Marine
Old Feb 14, 2013, 11:30 AM
United States, SC, Irmo
Joined Sep 2011
+1 for VLC. It plays where the other ones fail. Plus I was lucky enough to get VLC for my iPod before Apple pulled it.
shahram72 is offline Find More Posts by shahram72
Old Feb 14, 2013, 02:07 PM
Joined Sep 2012
2nd for vlc, it plays anything you throw at it...
username2620 is offline Find More Posts by username2620
Old Feb 14, 2013, 05:39 PM
South Africa, GP, Johannesburg
Joined Dec 2011
Here is a comparison of the v929vsv959 fpv and Arial photo ..if anyone is interested
http://www.rcgroups.com/forums/showp...&postcount=221
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Feb 16, 2013, 09:32 AM
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
I see in the video both worked, you took the V959 farther out was it because it felt more stable in wind? Did wind conditions change.
So what are your thoughts?
Hellysmack is offline Find More Posts by Hellysmack
Old Feb 16, 2013, 02:59 PM
Mosquito 6
Joined Jun 2012
I posted this in the V929 FPV HD thread .. just found this V959 thread ..
Originally Posted by TayNinh68 View Post
My My .. look at all the goodies on that v959 board Gotta be some way to access those ports with a T9x .. we hope. Soo .. guess I gotta fondle one .. just ordered from x-heli .. aka outtafriggenstock dot com
Anyway .. morning email greets included a discount code .. PRES10 for 10% off of $200 or more, but no free shipping like sister site HobbyPartz .. bummer BangGood has them for $68.99 .. x-heli is $75.95 less the 10% .. about on par without waiting a month. So if you have some other stuff to order this might be of interest. 3 day promo .. PRES10 .. 10% disc.
Cheers ..
TayNinh68 is offline Find More Posts by TayNinh68
Old Feb 16, 2013, 04:22 PM
Mosquito 6
Joined Jun 2012
I received the GWS EP5443 blades from Banggood. These blades are REALLY GOOD! My V959 flew like a different beast with these after market blades.
Orange: http://www.banggood.com/Wholesale-Gw...r-p-59945.html
Black: http://www.banggood.com/Wholesale-Gw...r-p-59941.html
Grey: http://www.banggood.com/Wholesale-Gw...r-p-59942.html
But they are not a direct fit because there is a big gap between the blade socket and the bearing. This allows the shaft to slide up/down and when that happens, the main gear and the pinion may be disenaged. I cut small pieces of duct tape to fill up the excess space. Need to find a better solution!
Thanks for the heads up on the spacer requirement. How long do they need to be?
http://www.zorotools.com/g/Metric%20...acer/00092393/
I better bookmark this myself They've got 2, 3, 5, 10 and 15mm. by 3.2mm ID.
Cheers ..
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 2892 Today 02:21 PM
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3424 Yesterday 10:32 PM
Mini-Review WLtoys V949 UFO Quad Mini-Review FyreSG Mini Multirotors 1274 Yesterday 09:42 AM
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5130 May 16, 2013 07:52 AM
