Old Jan 04, 2013, 11:23 AM
Paul Harvey is offline
Find More Posts by Paul Harvey
Canada
Joined Jun 2009
Help!
Spring/string tail set-up
This will be my first string/spring set-up, I've been reading through the Stobel threads, and am wondering if anyone has set-up their tail surfaces to fold over 180 deg. if the string fails or is released?
Good idea or bad? My thinking is it would effectively neutralize the control surface and not set the surface to an extreme position, full up elev. or full right/left rudder.
As long as this does not cause de-lamination and the spring is capable, it seems sound or am I missing something?
Paul Harvey is offline Find More Posts by Paul Harvey
Old Jan 04, 2013, 12:31 PM
sporter is online now
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
If you put a huge bend in the spring, it will fold over to 180. This may also stress the servo. Personally, I wouldn't worry about it. If you use the right line, it shouldn't break anyway. I have not had any breaks after years.
It's a good idea to be safe though. I find most failures occur on launch, if you lose the rudder or elevator on launch your probably toast anyway.
Sean
sporter is online now Find More Posts by sporter
Old Jan 04, 2013, 01:17 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
It would take way to much spring tension and would stress the hingeline .
Consider this. If you use spectra line [research knots though] you will never ever break the line. If you want a good trick for reducing friction /wear on the line. Buy a package of those very cheap beads the kids use for necklaces. they have a flared hole and can be used for anti friction turn arounds and such .
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Jan 04, 2013, 02:56 PM
VintageFan is offline
Find More Posts by VintageFan
a.k.a Frank Campbell
Long Beach, CA, USA
Joined Jan 2007
Or you can use wire instead of string. I use .3 mm (.012 in) or .015 in wire. Available in your LHS
VintageFan is offline Find More Posts by VintageFan
Old Jan 04, 2013, 05:46 PM
electrich is online now
Find More Posts by electrich
65 Buick =make my own thermals
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
Thin "E" guitar strings works good too if the music store is closer than the hobby shop. You can get an 08 size string for about 99 cents.
electrich is online now Find More Posts by electrich
Discussion Tail rotor set up for 450 size MD500E STO Scale Helicopters 2 Mar 15, 2012 05:02 PM
Help! GY401 SET-UP - DX7 - tail set up... help :( d1cky_kds Electric Heli Talk 16 Jun 27, 2011 06:10 PM
For Sale (1) Set Of Robart Air Up Spring Down Retracts W/ Air Valve $120 Shipped FlyBoyTha1 Aircraft - General - Miscellaneous (FS/W) 0 Mar 28, 2010 08:34 AM
Sold Dlg Tail set with spring-v mount mccainml Aircraft - Sailplanes (FS/W) 1 Mar 04, 2010 09:19 PM
Discussion Drifting spring set up nedved Electric Power Cars 4 Jun 10, 2007 12:42 AM
