Old Jan 04, 2013, 10:51 AM
LowlyElevated is online now
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Question
WHOAH high humidity makes my KK board not funtcion!!!
So today I went to fly my tricopter with a black KK board between some rain showers and discovered that it has issues with humidity.
When I try to boot it up, my escs make a beeping sound and when I arm it, the red light comes on but my escs don't work.
They are rctimer 30 amp, but I beleive it is not the escs because my escs on my planes do fine in humidity.
Yesterday I was flying a foamy and almost lost it in the fog, but no motor problems.
I know that it is the humidity because it works fine when I boot it up indoors, but not when I do it outside.
Is this normal?
LowlyElevated is online now Find More Posts by LowlyElevated
Latest blog entry: More Miniquad FPV!
Old Jan 04, 2013, 12:14 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
it is most likely due to temperature change not humidity. The esc internal clock problably is shifting with temperature and changing the throttle calibration points. To test recalibrate esc throttle after you get outdoors and see if it works ok.
pug398 is offline Find More Posts by pug398
Old Jan 04, 2013, 12:16 PM
Joined Sep 2012
It can't be temp, I have been flying it outside in these same temps for a few days for no problems.
Old Jan 04, 2013, 12:19 PM
pug398 is offline
VA
Joined Nov 2009
if it is fast beep 4 times per second it sees high throttle and you can try lowering throttle trim.
Old Jan 04, 2013, 12:28 PM
Joined Sep 2012
Could be. If they are seeing high throttle, then why hasen't this happened before now?
EDIT I just tried it out, and it worked. Thanks.
Rave HK KK V2 Quad board (and other recent KK boards) randall1959 Multirotor Electronics 2584 Aug 11, 2014 02:01 PM
Discussion HK KK V2.1 board not arming Woodchuck12 Multirotor Electronics 6 Aug 24, 2012 01:43 PM
Help! kk black board not showing blue "alive" led custom t Multirotor Talk 4 May 12, 2012 03:08 PM
Help! kk black board not showing signs of life... custom t Multirotor Talk 6 Apr 22, 2012 12:51 AM
Question KK board will not arm 2 motors? bakon Multirotor Talk 10 Apr 10, 2012 06:03 AM
