Old Jan 21, 2013, 10:03 PM
VCscott is online now
Find More Posts by VCscott
VCscott's Avatar
United States, CA, San Diego
Joined May 2011
Here is a yet to be finished Ridge Runt.
VCscott is online now Find More Posts by VCscott
Old Jan 22, 2013, 06:58 AM
BluIIs is online now
Find More Posts by BluIIs
O'Fallon, Mo.
Joined Apr 2010
Thanks Jim, I found your build thread for the Whynot and will be following.
BluIIs is online now Find More Posts by BluIIs
Old Jan 22, 2013, 10:58 PM
aviatortom is offline
Find More Posts by aviatortom
aviatortom's Avatar
United States, PA, New Tripoli
Joined Sep 2010
My Unionville 6' Beave kit. The build log is located here http://www.rcgroups.com/forums/showthread.php?t=1780948
aviatortom is offline Find More Posts by aviatortom
Old Jan 24, 2013, 03:00 AM
gjap is offline
Find More Posts by gjap
Joined Jun 2010
Here is my sig clipped wing cub 1/6th scale. I'm currently finishing it up and its now covered in solartex. I do like the covering but I miss the bare bones look already. Here is a link to build log if you want to see her all dressed up:
http://www.rcgroups.com/forums/showt...1739311&page=2
-Greg
gjap is offline Find More Posts by gjap
Old Jan 24, 2013, 03:07 PM
new2rc is offline
Find More Posts by new2rc
Warbird crazy!
new2rc's Avatar
United States, CA, San Mateo
Joined Sep 2004
Originally Posted by tim hooper View Post
Excellent thread!
I can never resist taking a pic of my birds in the raw.....
tim
Really like that Airspeed Courier Tim.
Sure wish the full kit was caried here.
John
new2rc is offline Find More Posts by new2rc
Old Jan 26, 2013, 07:47 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
My 8yo sons Micro Telemaster...he made me post it!
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Jan 26, 2013, 10:06 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
ure
ARUP is offline Find More Posts by ARUP
Old Jan 27, 2013, 03:55 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Here are 2 that I have built
The delta is my Favorite!
I also posted pics of after I covered the delta
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Jan 27, 2013, 04:10 AM
Joined Jul 2007
-Greg
Thats some fine framework there!.
any reason you didnt use transparent film so you could still see the frame?
Old Jan 27, 2013, 09:07 AM
ARUP is offline
Joined Mar 2010
hat
Old Jan 27, 2013, 07:12 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Originally Posted by RMCCOR7737 View Post
"Hot wood on wood". That's just WRONG in so many ways!
ROTFLMAO!!!
And Rattlesnake, that delta is one sweet looking plane (I like the motor position)! I don't see any rudders though, does it use differential thrust to turn?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 27, 2013, 09:24 PM
gjap is offline
Joined Jun 2010
Thank you. I considered using transparent blue but I wanted to keep it more scale and use fabric. The antique solartex I used is semi transparent though so some of the framing is visible in the light.
Old Jan 28, 2013, 05:18 AM
Joined Jul 2007
Originally Posted by ARUP View Post
That B.O.T. is neat!
Thanks! I built it over 3 months
Originally Posted by Fly Wheel View Post
[B][SIZE="5"]
Thanks! Its a scratch design and build by me.
Good guess, no rudders and Differential throttle.
I designed it to fly High Alpha hover Vertically.
Delta was chosen as they naturally do high alpha well.
The foil is the same thickness the entire wing, this means that the leading edge near the nose is sharper and stalls before the wing tip.
The motors were put infront of the wing so that there is always air flowing
over the wing tip, meaning the wing tip should never stall.
All these ideas must work as it simply doesn't tip stall.
The Motor / Elevon position also means that is has thrust vectoring.
Essential for hovering and great for high alpha.
The props are counter rotating ans installed in a way that goes against
the direction that tip vorticies flow.
Lastly the wingtips go above and below the wing greatly reducing bad tip
vorticies.
The vertical surfaces were designed like that ( Even amount above and below)
to enable it to be put on its end and take off vertically.
I had origionally intended to land vertically too but that needed a good stabaliser.
I tried the Guardian 2d/3d but they are garbage.
The Orange 3ch gyro is much better, I just need some good weather so I
can adjust the gains a bit more.
Old Jan 29, 2013, 12:15 AM
mmcgirk is offline
Find More Posts by mmcgirk
Joined Dec 2012
Great post. Nothing I like more than scouring the Build Logs and looking at the pictures.
Most complete picture I have of my Tyro before I covered it. It is my second plane and first kit build. Finished it about a month ago and have since enjoyed many, many hours of flying it. I think I enjoyed building it as much as flying it. I already have bookmarked about 20 more that will likely be next.
mmcgirk is offline Find More Posts by mmcgirk
Old Jan 29, 2013, 07:31 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
This is my current project, a Monoprep. I'm building it from Doc Mathews plans.
It'll be a 72" span, powered by an OS .52 4 stroke.
TomCrump is offline Find More Posts by TomCrump
Gallery Show off your 3D foamie Free Scratchbuilt Indoor and Micro Models 24 Feb 01, 2015 04:44 PM
Cool Show off your parkzone micros! RCAddict16 Scratchbuilt Indoor and Micro Models 3 Aug 15, 2012 09:11 AM
Gallery show off your gas rc boats wildtay Racing Boats - Internal Combustion 6 May 11, 2012 08:40 AM
Discussion Show off your cases if you have them Jeffem62 Multirotor Talk 3 May 08, 2012 06:48 AM
Gallery Show me your naked Corona 120 cutty01 Electric Heli Talk 14 Aug 02, 2008 06:36 PM
