Old Feb 01, 2013, 07:31 AM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Vacuum breach valve.
Description: Fitting with pipe attached.
Sarboy is offline Find More Posts by Sarboy
Old Feb 01, 2013, 07:33 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Description: Valve broken down.
Old Feb 01, 2013, 07:36 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
The result from the first attempt.
Description:
Old Feb 05, 2013, 01:16 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
I just picked up a hand-operated brake bleeder vacuum pump yesterday from Harbor Freight for $18 with a coupon from the newspaper (could probably be found online as well). I plugged the line and pulled vacuum this morning to test it. I was able to get 20" Hg and four hours later it's still sitting at 20" Hg. As long as you can make sure your vacuum bag is well sealed this seems like a pretty good inexpensive option.
bwill6 is offline Find More Posts by bwill6
Old Feb 05, 2013, 05:27 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I show how to use that in my videos. One BIG suggestion for you; Once your bag is sealed up first pull the air out with a vacuum cleaner, then go to the hand pump. if you try to pull all the air out with the hand pump soon you will have forearms bigger than a Gorilla!
My arms have gone back to the original size now.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Feb 05, 2013, 11:13 PM
bwill6 is offline
Joined Jun 2011
Thanks for that tip. What do you use to seal your bags? I imagine the bag clips don't seal well enough for a hand pump, but the gray bag sealer tape (we call it "elephant snot" at work ) is a real pain to work with.
Old Feb 06, 2013, 12:37 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Acrylic grout!
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Feb 06, 2013, 07:02 AM
Red Merle ALES
Joined Apr 2002
I use the bag clips but double the bag into the clip. Normally I have to come back every hour or so and give a few pumps to bring the pressure back up.
Curtis
Old Feb 09, 2013, 09:06 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
[QUOTE=CloudyIFR;24044746 if you try to pull all the air out with the hand pump soon you will have forearms bigger than a Gorilla!
Curtis[/QUOTE]
Eat your spinach. It worked for Popeye
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 10, 2013, 05:06 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Hi all. If you want to see how I've been getting on with my aquarium pump please have a look at my DLG thread, http://www.rcgroups.com/forums/showthread.php?t=1821107
Old Feb 10, 2013, 05:13 PM
Joined Aug 2008
Why not post here?
This is where you started. Or should we unsub this thread and go over to your DLG thread?
In your hands...............so to speak.
Old Feb 11, 2013, 04:36 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Hi Jim, I started this thread for cheap vacuum pump options. I just thought you might like to see my DLG build using this pump.
Old Feb 11, 2013, 06:21 PM
Joined Aug 2008
Originally Posted by Sarboy View Post
................. I just thought you might like to see my DLG build using this pump.
For sure! I'll get to look at it as soon as I have the time.
I also have ambitions of one day building a DLG. So, need lots of education in that regard.
Jim.
Old Feb 12, 2013, 03:12 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Err, I wouldn't use me as a refrance except maybe to see what not to do. This is my first build since I was a kid. It's kind of off the kuff.
Old Jun 09, 2013, 08:27 AM
Mike_ is offline
Find More Posts by Mike_
Random slope flyer
Mike_'s Avatar
United Kingdom, Scotland, Currie
Joined Feb 2013
Originally Posted by Dani123 View Post
Hand pump is the way to go, at least in the beginning, I bought this one:
http://www.actron.com/product_detail.php?pid=16177 and using it for over a year.
My bags are the ones that used for cloth storage with vacuum cleaner The sealing is good.
Dani
Dani,
How do you attach your handpump to the vac storage bags? Do you attach via the existing fitting or do you add an additional one?
Mike_ is offline Find More Posts by Mike_
For Sale EZ Vac Vacuum Bagging Pump cbk07 Aircraft - General - Miscellaneous (FS/W) 4 Feb 28, 2013 12:48 AM
Sold Vacuum Bagging Pump Papasoar Aircraft - Sailplanes (FS/W) 3 Oct 25, 2012 05:34 PM
Mini-HowTo Vacuum Bagging Made Easier - Aqua Vac, Foodsaver, Gast Pump & Tire Pump Geode Hand Launch 264 Nov 29, 2010 03:14 PM
Question Can we use the cheap Airconditioning vacuum pumps for bagging? Bosk Composites Fabrication 18 Jun 21, 2010 04:25 AM
Sold Vacuum Bagging Equipment - package deal, dual head vacuum pump rakm Aircraft - General - Miscellaneous (FS/W) 8 Jun 05, 2007 04:53 PM
