Old Jan 08, 2013, 02:45 PM
Cory is offline
Find More Posts by Cory
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
I've had good results with a food saver...and there's the added bonus that the wife was happy to spend money on it.
Cory is offline Find More Posts by Cory
Old Jan 08, 2013, 03:19 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Yes, I have heard that they are good Cory.
How much money do they cost?
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Jan 08, 2013, 11:43 PM
Cory is offline
Cory's Avatar
Idaho Falls
Joined Jul 2006
This is the one I have: http://www.foodsavercanada.com/product.aspx?pid=9081. I think I paid about $150 for it. There are cheaper ones out there. I know I could get a good vacuum pump set up for about that price, but a happy wife is a good thing.
Old Jan 08, 2013, 11:48 PM
Joined Aug 2008
Originally Posted by Cory View Post
................. I know I could get a good vacuum pump set up for about that price, but a happy wife is a good thing.
Absolutely!
Old Jan 09, 2013, 12:07 AM
Cory is offline
Cory's Avatar
Idaho Falls
Joined Jul 2006
With the food saver you have to be really careful about sharp points on your mylars so you don't puncture the bag. I've read about guys ruining projects with a minute leak. I have not had the problem yet in about 6 bagged projects of various types. I don't have a lot of experience with it yet, but what I have done has turned out very good. See my latest here: http://www.rcgroups.com/forums/showt...7#post23722886
Old Jan 10, 2013, 03:29 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Here is a fish pump I converted in a matter of a minute. I have not used it yetbut it should work fine to just mess around with. It's In my blog here is a link.
http://www.rcgroups.com/forums/member.php?u=44257
unclecrash is offline Find More Posts by unclecrash
Old Jan 18, 2013, 07:15 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
I have been using #1 for 3 years now on 2' x4' size molds with no problems.
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Jan 18, 2013, 02:41 PM
Joined Aug 2008
............... I've read about guys ruining projects with a minute leak. ....................[/url]
That can happen with just about any vacuum system.
I almost spoiled a project and burned out my fridge compressor pump due to, what turned out to be, leaks in the plumbing "T" junctions in the pump system itself. The tube dries out and with some movement, it can result in a poor fit over the barbed fittings.
The first thing I do now if I have a slight leak is pinch the vinyl tube closed between the pump and the vac bag. If the vac system stops cycling, the problem is in the bag. If it doesn't, its before the pinched shut off point.
The bigger leaks can be heard of course.
Jim.
Last edited by Jim.Thompson; Jan 18, 2013 at 06:23 PM. Reason: correction of garbled syntax!
Old Jan 21, 2013, 05:36 AM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Not managed to bag a wing yet.
Had too many distractions and not enough time. It also doesn't help to have a dump of snow with sub zero temps. My work space is in a very cold garage.
But, I've managed to convert an aquarium pump. It took two pumps as the first had an integral valve which could not be reversed. I don't know if works yet to bag a wing but I hope to try in a week or so.
Does any body have a good recommendation for a bag valve system? I'm struggling to come up with anything?
Tom
Sarboy is offline Find More Posts by Sarboy
Old Jan 21, 2013, 08:20 AM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Tom
Purchase a tire valve at your local Auto parts store.
http://www.napaonline.com/Catalog/Ca...282_0215254711
I spent about $5.00
Drill the innards out.
Then cut two crosses in the bottom of it to keep the bag from sucking up in the hole and shutting off the vacuum.
I took two photos, the quality isn't very good but you should get the idea.
That's it.
Curtis
Curtis Suter is offline Find More Posts by Curtis Suter
Old Jan 21, 2013, 12:37 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Cheers cloudyIFR,
I can not find a car tire valve? A bit weird.
However, what do people think of this?
http://shop1.r-g.de/4DCGI/ezshop?act...COUNT=62598896
Should do the job, not too expensive and should connect to aquarium tubing?
BTW, cloudyIFR, is the IFR I Follow Roads, rivers and railways?
Tom
Old Jan 21, 2013, 03:17 PM
Joined Aug 2008
Skin fitting.
Cheers cloudyIFR,
Tom
For what it's worth, I no longer use any sort of skin fitting for my vac bags. I simply wrap the end of the vinyl vac tube with some paper towel and/or some peel ply (Taffeta) and run it out between the bag joins. I use acrylic filler for sealing the bag and this also seals around the suction tube.
On wing moulds where the bag is only one layer sealed on the mould flanges, I use a small length of tacky tape wrapped around the tube to secure it and prevent any sucking in of the acrylic filler. Then the filler runs over the tacky tape etc.
Jim.
edit: I also use cheap, universally available drop sheet plastic for my vacuum bags. Cheap and disposable. Very flexible for following internal corners and such.
Old Jan 31, 2013, 03:56 PM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Hi all,
I brought the bag valve I linked in the previous post.
It's now doing a sterling job on my first bagged component.
I took off the push fit adapter, heated sone aquarium tubing in some hot water to make it pliable and pushed it over he fitting. Job done and a good seal. Not to bad for €20 or so.
Will be able to tell if it worked tomorrow.
Aquarium pump seems to be doing the business. Not sure what its pulling but it is defiantly pulling.
Tom
Old Jan 31, 2013, 04:17 PM
Joined Aug 2008
Any pics Tom?
Good to read it's : "defiantly pulling" .
For Sale EZ Vac Vacuum Bagging Pump cbk07 Aircraft - General - Miscellaneous (FS/W) 4 Feb 28, 2013 12:48 AM
Sold Vacuum Bagging Pump Papasoar Aircraft - Sailplanes (FS/W) 3 Oct 25, 2012 05:34 PM
Mini-HowTo Vacuum Bagging Made Easier - Aqua Vac, Foodsaver, Gast Pump & Tire Pump Geode Hand Launch 264 Nov 29, 2010 03:14 PM
Question Can we use the cheap Airconditioning vacuum pumps for bagging? Bosk Composites Fabrication 18 Jun 21, 2010 04:25 AM
Sold Vacuum Bagging Equipment - package deal, dual head vacuum pump rakm Aircraft - General - Miscellaneous (FS/W) 8 Jun 05, 2007 04:53 PM
