Old Feb 09, 2013, 04:06 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
I agree, Charles. Apples and oranges.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 09, 2013, 06:31 PM
Jpm76 is offline
Find More Posts by Jpm76
Australia, QLD, Gold Coast
Joined Feb 2013
Originally Posted by everydayflyer View Post
Say you are charging at 10A then with the End set for 10% of CC when the charge rate drops to 1A in the CV stage the charge ends.
Since the PL keeps getting mentioned the 10% or 1/10 is the End charge rate used by the P{L8 and 6 when set to Faster charge and 5% or 1/20 is used for Accurate charge.
The ending charge rate yas an effect on how full the cells are at the end of charge.
Easy to follow example: Fill you auto gas tank at a high rate and after pump cuts off you can add more if you do it slowly.
4010DUO comes with 1 LiPoly Preset and PLs come with a bunch. PLs have 23 or 24 preset as delivered and all are backedup in the Libary plus some extras and it is possible to have 25 user presets all of which can be saved to commputer's HD and loaded whenever all or 1,2, or any number.
DUO can have 64 Presets but only 6 or 7 from factory and only one for each chemistry,Nicad,NiMH.Pb, LiPoly,Lion etc. At present no way to merge Factory and custom presets on the DUO. CCS makes creating and modifying PL Preset supper simple and even without the CCS PL is easier to create or modify Presets than the DUO is.
DUO has onbaord and Micro DS logging whereas PLs do not. Everyone wants them compared but they are not really all that similiar IMO.
Charles
Ok thanks Charles, so if you set it at 5% the last past of the charge would be even less resulting in a higher standing charge correct?
Cheers Justin
Jpm76 is offline Find More Posts by Jpm76
Old Feb 09, 2013, 06:52 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
The last part of the charge will be more because it will continue (past 10% of current setpoint) until 5% of setpoint current. It will result in a higher ending resting voltage.
gulio is offline Find More Posts by gulio
Old Feb 09, 2013, 08:23 PM
Jpm76 is offline
Joined Feb 2013
Ok so 5% would give a higher standing voltage but would result in a slowing charge charging cycle correct.
Old Feb 09, 2013, 08:38 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Yes, at the sacrifice of longer charge cycle as you've indicated and also fewer usable cycles.
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 09, 2013, 08:50 PM
Jonnydb is offline
Find More Posts by Jonnydb
Brazil, São Paulo, São Bernardo do Campo
Joined Aug 2007
anyone recommend the hobbyhut.com?
thanks!
Jonnydb is offline Find More Posts by Jonnydb
Old Feb 09, 2013, 11:10 PM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
What do you mean by fewer usable cycles? Charging to a higher voltage reduces pack life?
mdv is offline Find More Posts by mdv
Old Feb 09, 2013, 11:48 PM
So. Cal.
Very much so. Reducing peak voltage by .1V can extend useful life by as much as 100%. It's for this very reason that EV manufacturers deliberately undercharge their lithium based batteries to well less than 100% charge state and terminate discharge with significant remaining capacity. As I recall, the Chevy Volt uses only ~65% of available capacity.
Here's a graph that Julez posted a while back that clearly demonstrates the benefits of charging to a lower charge state: http://www.rcgroups.com/forums/attac...mentid=5349064.
The first thing I did with my iChargers prior to placing into service was to lower the termination voltage such that my packs were never above 4.15 volts after charging and my lipolys have been very happy. I have a few that are almost 3-1/2 years old and ~250 cycles and are performing nearly as well as they did when new.
Mark
Old Feb 10, 2013, 12:39 AM
Jpm76 is offline
Joined Feb 2013
Mark
Ok that's interesting, what I thought was by going to5% and slowing the charge at the end would be better for your packs, but in fact what your saying is it's worse because it would increase the standing volts and therefor be harder in your batteries.
Do I have this correct ?
If so then I agree with lowering the end current to keep your packs nice and happy
Old Feb 10, 2013, 12:53 AM
So. Cal.
You are correct. Your lipolys will be much happier if the charge cycle is ended earlier rather than later.
Mark
Old Feb 10, 2013, 08:31 AM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
I think you have it , but the language sometimes is confusing. "lowering the end current"
The end % setting tells the charger to stop at x% of original setpoint. Thus a lower % will result in a longer charge because it will continue to ramp down to a LOWER current. This results in a HIGHER termination voltage, capacity and thus a HIGHER resting voltage.
I agree with Julez' chart and what Mark says about higher voltage. I see it first hand because the first thing I do is to jack mine up to 4.3 per cell. I can ruin a cheap lipo within 100 cycles. One of these days when I buy a expensive pack I may lower the voltage just to prove it. I "should" do it on one of my cheap packs though.
Old Feb 10, 2013, 09:09 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
The Revolectrix chargers come with a default long-life preset that charges to 4.10v.
Ohmic is offline Find More Posts by Ohmic
Old Feb 10, 2013, 04:11 PM
Jpm76 is offline
Joined Feb 2013
Ok I think I'm on to it now, just a quick one though, am I better to lower the end current % and end voltage to say 4.15 volts and keep it as close to 4.15 volts standing charge or raise the end current % to say 30% and leave the end voltage at 4.2 volts which in theory would fall back under 4.2 volts standing and result in a quicker charge time?
I feel the first option would be better for the packs as they would never go over 4.15 volts but would be slightly slower?
Ps I'm not worried about a slightly slower charge time, I'm just trying to get my head around this, sorry for the endless dumb questions
Cheers Justin
Old Feb 10, 2013, 04:21 PM
Greenland
Joined Mar 2012
Justin, no one was born with complete knowledge, here. Asking is best!
Old Feb 10, 2013, 04:42 PM
Jpm76 is offline
Joined Feb 2013
Agreed, I'd rather ask a dumb question then make a stupid mistake and burn my house down lol
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 251 Jun 22, 2016 05:31 PM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
