Old Feb 08, 2013, 07:12 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Originally Posted by syndr0me View Post
Was there a difference? I didn't see any after the upgrade. The charger continued to work flawlessly for our needs. I was able to bypass the balance board and plug directly into the charger (2S car packs don't have a traditional balance plug) which made wiring a lot less convoluted. Worked perfectly.
Most obvious to me is the number of lipo cells in the upper part of each display.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 08, 2013, 07:16 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
EP Buddy.com
The Tug is online now Find More Posts by The Tug
Old Feb 08, 2013, 07:19 AM
Greenland
Joined Mar 2012
Somewhat steep learning curve on this one Brazilian dude, but the display is gorgeous!
Old Feb 08, 2013, 04:03 PM
Jonnydb is offline
Find More Posts by Jonnydb
Brazil, São Paulo, São Bernardo do Campo
Joined Aug 2007
talking about me?
Jonnydb is offline Find More Posts by Jonnydb
Old Feb 08, 2013, 04:27 PM
Greenland
Joined Mar 2012
Originally Posted by Jonnydb View Post
talking about me?
Yup. If.you buy one, be ready....
Old Feb 09, 2013, 01:46 AM
Jpm76 is offline
Find More Posts by Jpm76
Australia, QLD, Gold Coast
Joined Feb 2013
Parralel charging questions
Ok so I've just got my charger and ep buddy paraboard v3, I've hooked up 4 2s lipos with the leads and balance leads connected, should I be reading 8 cells on the voltage screen or still only 2, I'm only seeing 2 but thought I may have it wrong as I thought 8 would show up?
Cheers Justin
Jpm76 is offline Find More Posts by Jpm76
Old Feb 09, 2013, 02:13 AM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
Cheers Justin
Only 2 as same cells from each pack are connected in parellel on the paraboard.
wjs is offline Find More Posts by wjs
Old Feb 09, 2013, 02:29 AM
Felborn is online now
Find More Posts by Felborn
Norway
Joined Jul 2008
I found it pretty intuitiv, a lot easier to get going than my PL8. There are advanced featuresvto play with, but to just start charging you dont even need to open the manuall
Felborn is online now Find More Posts by Felborn
Old Feb 09, 2013, 03:25 AM
Jpm76 is offline
Joined Feb 2013
Thanks for that I wasn't sure but now I think about it since there in parallel it's stands to reason.
Also when charging say 4 packs, 5000mah at 2c (40amps), if one pack was slighly more discharged, towards the end of the cycle would it receive 40 amps or because there all in parallel would the higher volts of the other 3 packs act as a charger and bring the lower voltage pack up to the same level as the higher 3?
Another question, I can't work out what charge end current is, it's set as default 10% but not sure what it does?
Cheers
Old Feb 09, 2013, 05:58 AM
Cavokk is offline
Find More Posts by Cavokk
Cavokk's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Aug 2012
Cheers
Hi
There is NO difference in voltage of the cells and packs because they are parallel. The current when you are charging is shared among the cells / packs in the way that the pack/cell with lowest internal resistance draws more current than the one with high internal resistance.
When you couple packs or cells in parallel you equalize the voltage over them, - so for at short period if pack voltage differs when you connect them in parallel then the pack with highest voltage charges the other pack(s) very quickly.
Cheers
C
Cavokk is offline Find More Posts by Cavokk
Old Feb 09, 2013, 06:21 AM
Jonnydb is offline
Joined Aug 2007
yes i know! i was watching this charger since april of last year when was announced. mainly of features like 40A /70A of discharger.
and now is time to buy one
Old Feb 09, 2013, 06:24 AM
Jonnydb is offline
Joined Aug 2007
Yup, looking the display looks easy compared of mine Turbo 35 GFX
Old Feb 09, 2013, 06:26 AM
Jonnydb is offline
Joined Aug 2007
Originally Posted by The Tug View Post
EP Buddy.com
thanks Dude!
and about hobbyhut? is recommended?
Old Feb 09, 2013, 07:00 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
WOW! this charger is REALY EXPENCIVE! Although I have the funds to buy this if I wanted to, I dont think I would spend this much on a charger of any kind.
goldsworthy is offline Find More Posts by goldsworthy
Old Feb 09, 2013, 07:35 AM
Bubba Gump is offline
Find More Posts by Bubba Gump
F3P, Slap, IMAC, Helis
Joined Jun 2007
Its cheaper then buying 2pl8 so In retrospect its not that bad considering your get 2pl8s in it one
Bubba Gump is offline Find More Posts by Bubba Gump
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 251 Jun 22, 2016 05:31 PM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
