Old Feb 05, 2013, 02:10 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Just tried to upgrade to v 2.02: the charger beeps, then goes "dead" (all power off), and the computer comes up with a "communications error."
So, apparently the charger shut itself off when I tried to "download," and it appears to be working as before, thank God.
I don't know if it matters but I'm using Windows 7 "home," 64 bit.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 05, 2013, 02:16 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Originally Posted by Ohmic View Post
Have you measured the accuracy difference between fully-recovered and semi-recovered?
We're drifting a little OT for this thread.
There's no real way to measure accuracy difference between fully-recovered and semi-recovered unless semi-recovered voltage is clearly defined and understood. Since this will be highly variable for different packs, the results will be a rough estimate as Charles and I indicated previously. If recovery time is not sufficient, results will be far less accurate, much in the same way that reported IR from FMA chargers becomes increasingly inaccurate on lower quality packs with high IR. This is due to the very short 'rest' time of the FMA algorithm. High performance packs recover faster and will thus produce reasonably accurate results. Lower performance packs recover much slower so the reported IR will be far less accurate and will be more optimistic than actual. Same concept applies for Fuel level.
Regards,
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Feb 05, 2013, 02:44 PM
FeffeSvl is offline
Find More Posts by FeffeSvl
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
Good to hear it started up again!
I think the shutdown is part of the plan though, mine does that too. When the update is initiated, the charger goes dark like shutdown, the USB disconnect/connect pc-sound chimed twice today I think, the progress indicator for loading update in the application started to fill and after about 17 seconds the charger booted up by itself again.
Did you wait and let the sequence run its course or have a moment of panic when it shut down and intervened?
FeffeSvl is offline Find More Posts by FeffeSvl
Old Feb 05, 2013, 02:46 PM
Greenland
Joined Mar 2012
well, I say the latter, but I did wait a bit and nothing changed: Junsi, you are scaring my donkey!
Uh, Swedish dude, what do you recommend?
By the way, I got one beep or chime and the charger "went dark".
Scared my donkey right proper.
Old Feb 05, 2013, 02:58 PM
Greenland
Joined Mar 2012
O.K., Swedish dude, I used some salts to wake up the donkey and got it to work.
Here is how:
1. Did as you suggested and after 1 minute the communication error came up and ole donk fell over again;
2. Then, I pressed upgrade one more time and low and behold, it worked, uploading the new firmware in less than 10 seconds!
I turned off the charger and turned it back on, finding 2.02 in the opening screen!
Hee, haw, Junsi, you darn sure scared my donkey!
Old Feb 05, 2013, 03:08 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
It is best to use one of the Main USB ports on the rear of the ccomputer to do updates. On most computers the ones on the front are less powerful (voltage / Amps.wise) and if one uses a USB Hub they are even weaker or atleast most are.
Using the front USB ports on a E machine running Win7 64bits. I have had to restart the update(s) numerious times before they take. Part of this may have been due to mine be a pre release beta version which in fact had different fireware installed and it in fact would not update past ver. 1.24.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 05, 2013, 03:17 PM
Greenland
Joined Mar 2012
Charles
Thanks, Charles. I used a dell laptop and the side USB ports since I have no others. The darkness sho did sceer my donkey! (Paddle faster if you hear banjo music!)
Addendum: Junsi, the new screens are great! Donkey seal of approval.
Old Feb 05, 2013, 09:38 PM
alexf1852 is offline
Find More Posts by alexf1852
alexf1852's Avatar
United States, FL, Inverness
Joined Jan 2010
Smooth upgrade for me. I even used the front USB port of my computer.
alexf1852 is offline Find More Posts by alexf1852
Old Feb 05, 2013, 09:41 PM
Greenland
Joined Mar 2012
Did you have to select upgrade twice?
What do you think of the new screen info?
Seems far more reliable than the thunder donkey 820' eh?
Old Feb 05, 2013, 10:03 PM
syndr0me is offline
Find More Posts by syndr0me
United States, CO, Parker
Joined Jan 2013
Any descriptions of the new screens? My charger is at the track, so I can't upgrade it until Thursday.
syndr0me is offline Find More Posts by syndr0me
Old Feb 05, 2013, 10:34 PM
alexf1852's Avatar
Joined Jan 2010
1. Just once.
2. I didn't notice what is new. What is new re: the screen info?
3. yes
Old Feb 05, 2013, 10:43 PM
Greenland
Joined Mar 2012
1. Just once.
3. yes
Yes, info expanded.
Old Feb 07, 2013, 10:24 AM
Nelvick is offline
Find More Posts by Nelvick
Joined Feb 2008
Can some one screenshot the new Info Screen ?
Nelvick is offline Find More Posts by Nelvick
Old Feb 08, 2013, 12:39 AM
syndr0me is offline
Joined Jan 2013
Was there a difference? I didn't see any after the upgrade. The charger continued to work flawlessly for our needs. I was able to bypass the balance board and plug directly into the charger (2S car packs don't have a traditional balance plug) which made wiring a lot less convoluted. Worked perfectly.
Old Feb 08, 2013, 06:05 AM
Jonnydb is offline
Find More Posts by Jonnydb
Brazil, São Paulo, São Bernardo do Campo
Joined Aug 2007
can you suggest a place to buy one? who send overseas... thanks!
Jonnydb is offline Find More Posts by Jonnydb
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 250 Oct 06, 2015 08:48 AM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
