Old Feb 04, 2013, 11:53 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Originally Posted by mrforsyth View Post
No, the statement applies exclusively to single packs. It was meant to illustrate that % charge cannot be accurate due to physics involved. e.g. - charge state based on voltage is only reasonably accurate in static (no load) condition. Since charging is a loaded condition, % charge will be a rough estimate, much in the same way that voltage during discharge tells little about remaining capacity.
Regards,
Mark
But as I mentioned earlier, if the percentage displayed in the UI to the user is simply based on a lookup table of the voltage then there s a 1:1 relationship between voltage and percentage.
Ohmic is offline Find More Posts by Ohmic
Old Feb 04, 2013, 12:04 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
True, but the lookup table is based upon resting voltage, whereas a battery that is being charged is anything but resting. As such, traditional lookup tables are useless and are greatly exacerbated by charge rate and cell internal resistance, as stated previously. Thus, no 1:1 ratio exists unless the charger periodically stops charging for a good amount of time to allow the cell to recover to resting voltage. This must be done throughout the charge cycle and can wreak all sorts of havoc if not implemented properly.
mrforsyth is offline Find More Posts by mrforsyth
Old Feb 04, 2013, 12:16 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Percentage Fuel Table I have linked to numerious times is from a PL8 and is accuarte during charge.
http://www.rcgroups.com/forums/attac...5&d=1299261126
IMO to many make to big of a deal about such.
4.2 is 100%
4.1 is 90%
3.7 is 0% useable remaining but is fime for storage.
Guess I am old ,set in my ways and just can not understand why it matters if Fuel % is 45,65, 70 % or what.
FYI As mentioned Fuel % is not accuarte for all LIPoloy. Different IR,temperature ,real remaining capacity etc. Percentage displayed in the first 10 min. of a 1C charge should just be ignored unless it is les than 10% in which case reduce your flight times.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 04, 2013, 12:35 PM
Ohmic is offline
USA
Joined Jan 2002
What level of accuracy are you expecting? If charge rate and internal resistance are the only variables then additional calculations could be easily performed using these two values to still provide a reasonably accurate value.
Old Feb 04, 2013, 12:51 PM
So. Cal.
Agreed.
Further, implementing the estimated fuel % on the FMA chargers is much easier than iChargers due to the fact that FMA has periodic rest periods throughout the charge cycle to allow for semi-recovered voltage. These short rest periods also serve as the basis for reported IR, as you know.
Old Feb 05, 2013, 12:28 AM
scotty59 is offline
Find More Posts by scotty59
Joined Jul 2008
Originally Posted by JohnathanSwift View Post
Anyone?
i have done it. No problem.
scotty59 is offline Find More Posts by scotty59
Old Feb 05, 2013, 07:10 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
O.k. That's one. Others?
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 05, 2013, 09:34 AM
TylerL is offline
Find More Posts by TylerL
United States, IL, Momence
Joined Nov 2003
I personally remove my packs from the model and test their voltage with a handheld meter that offers a suggested % of capacity left. This is a very valuable tool for adjusting my timer for each model. As the packs age, weather changes, or model adjustments are made I have a reference to help me set my flight times to the proper duration. Also, I may adjust my flight aggression and demand on the packs based on this feedback.
Would it not be helpful to simply plug the pack into the charger and see what the consumption was on the pack and leave the handheld meter on the workbench, thus eliminating one more connection and reading per pack used?
I like the idea of a % of charge, even if it is a rough value and not scientific lab reference quality.
Now, what about those SD cards?
TylerL is offline Find More Posts by TylerL
Old Feb 05, 2013, 09:51 AM
FeffeSvl is offline
Find More Posts by FeffeSvl
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
I use a 4gb Sandisk SDHC class 10 in my 4010duo, it works for me.
FeffeSvl is offline Find More Posts by FeffeSvl
Old Feb 05, 2013, 09:55 AM
Greenland
Joined Mar 2012
Have you loaded v 2.02?
Old Feb 05, 2013, 10:11 AM
FeffeSvl is offline
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
No sorry, not yet. I was actually waiting for you to test it first But seriously, I have loaded beta 4 and one earlier before that and it worked.
Old Feb 05, 2013, 10:39 AM
Greenland
Joined Mar 2012
Hee, haw!
Old Feb 05, 2013, 10:48 AM
TylerL is offline
Joined Nov 2003
Those of you using an sd card, what is the real world use/value of utilizing this feature?
Next, what is a desirable sd card capacity? I see some are using a 4G. Any regrets on this size? More/less?
I find the manual and online discussion/resources very vague in this area.
Old Feb 05, 2013, 12:08 PM
FeffeSvl is offline
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
Well, the only point with the memory card is if you want to log the charging. I suppose it can also be good to have a log file to send to Junsi if necessary.
I don't know about the size, just used what I had on hand. Loaded 2.02 BTW, worked fine.
Old Feb 05, 2013, 12:28 PM
Ohmic is offline
USA
Joined Jan 2002
Have you measured the accuracy difference between fully-recovered and semi-recovered?
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 251 Jun 22, 2016 05:31 PM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
