Old Feb 03, 2013, 05:30 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
% is easy to understand (like fractions) , when using voltage for differing cell counts one might have trouble remembering the numbers. Even with only one cell count some math MAY be required.
gulio is offline Find More Posts by gulio
Old Feb 03, 2013, 09:14 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Originally Posted by gulio View Post
% is easy to understand (like fractions) , when using voltage for differing cell counts one might have trouble remembering the numbers. Even with only one cell count some math may be required.
+1!
Ohmic is offline Find More Posts by Ohmic
Old Feb 03, 2013, 09:36 PM
TylerL is online now
Find More Posts by TylerL
United States, IL, Momence
Joined Nov 2003
what type of micro sd card is needed? can a micro sdhc (high capacity) be used?
TylerL is online now Find More Posts by TylerL
Old Feb 03, 2013, 10:06 PM
mdv is online now
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
I meant I only care about per/cell voltage. I would definately have trouble making use of total voltage only. Now I see why people like %.
mdv is online now Find More Posts by mdv
Old Feb 03, 2013, 11:11 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
% capacity during charge can only be a rough estimate at best as it will be directly dependent on charge rate and internal resistance of cells. Packs with higher internal resistance will have a higher voltage than packs with lower internal resistance and will thus show higher charge %, even though actual charge % is identical. Consequently, this 'feature' would be marginally useful, IMO.
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 03, 2013, 11:48 PM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
Hello Everyone,
V2.02 for 4010DUO has been updated, please see details in the first post.
BTW, from February 5th to 18th is our holiday for Chinese New Year--Spring Festival, your problems for Junsi will not be handled during this period until we come back to work on 19th. Sorry for the inconvenience caused and thanks for your understanding.
Best regards,
Junsi
junsi is offline Find More Posts by junsi
Old Feb 04, 2013, 07:15 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Originally Posted by junsi View Post
Hello Everyone,
Best regards,
Junsi
Anybody done this, yet?
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Feb 04, 2013, 08:09 AM
Ohmic is offline
USA
Joined Jan 2002
It appears your statement is only assuming parallel charging. You wouldn't have to worry about packs with varying internal resistance when charging a single pack.
Old Feb 04, 2013, 08:43 AM
FeffeSvl is offline
Find More Posts by FeffeSvl
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
Any displayed charge in % is calculated, not directly measured as a constant. This is true for single pack or with parallell charging, although the calculation is probably screwed up by parallell wiring (unless all packs are identical).
The charger can only see the voltages of the cell/pack and the IR of cell/pack at any given time, and based on these values an estimation is done in those chargers who has the "feature". Unfortunately IR (cell or pack) varies between manufacturers AND within the same pack depending on charge, so it is not an exact science to determine charge %.
It would probably be simple to implement the feature if he decide to do it but I suspect that Junsi prefer to not show a number that cannot be determined with enough accuracy to meet his standards.
FeffeSvl is offline Find More Posts by FeffeSvl
Old Feb 04, 2013, 08:45 AM
Greenland
Joined Mar 2012
Well no less than FMA do it and they are the gold standard.
Old Feb 04, 2013, 08:53 AM
So. Cal.
No, the statement applies exclusively to single packs. It was meant to illustrate that % charge cannot be accurate due to physics involved. e.g. - charge state based on voltage is only reasonably accurate in static (no load) condition. Since charging is a loaded condition, % charge will be a rough estimate, much in the same way that voltage during discharge tells little about remaining capacity.
Regards,
Mark
Old Feb 04, 2013, 08:56 AM
Greenland
Joined Mar 2012
Look, folks, in many fields, like aviation, there are helpful trend instruments. Take the vsi for example. A trend can be very helpful.
Old Feb 04, 2013, 09:48 AM
syndr0me is offline
Find More Posts by syndr0me
United States, CO, Parker
Joined Jan 2013
It would be neat if the section of the display that shows individual cell voltage could scale its font size based on the number of cells. For 2S packs, for example, you could fit a lot more information on one screen. All that space for the extra cells that aren't connected is going to waste.
syndr0me is offline Find More Posts by syndr0me
Old Feb 04, 2013, 10:02 AM
Greenland
Joined Mar 2012
Anyone?
Old Feb 04, 2013, 10:09 AM
Air Head is online now
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
SD Cards
Is there a list of SD Cards that will work with this. I read through the thread and it seems that some are not compatable.
Air Head is online now Find More Posts by Air Head
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 251 Jun 22, 2016 05:31 PM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 10:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 12:34 PM
