Old Jan 30, 2013, 02:30 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Simply add an additional connector in parallel with both your source battery and charger such that both the battery and charger each have two connectors. Add a 5-10 Ohm, 1 watt resistor in series with this second connector. The second connector will be connected first and will limit current while the capacitors charge. After a few seconds, simply plug in your EC5 connector and you're good to go.
Some graphics here: http://static.rcgroups.com/forums/at...Highspark3.jpg
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 30, 2013, 03:05 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
I must say that while the one that Mark shows works well, the one that Tyler linked to is pretty compact and simple and chances are, that by the time you buy the resistor, wires and plugs, you may very well have spent the $10 that the Jeti unit costs. I may buy one of the Jeti units the next time I need a spark arrester. I really like the way it looks and works.
still4given is offline Find More Posts by still4given
Old Jan 30, 2013, 03:07 PM
TylerL is offline
Find More Posts by TylerL
United States, IL, Momence
Joined Nov 2003
Im checking with esprit now on the max voltage. Otherwise the 10 ohm resister sounds very simple.
Thanks guys.
New charger on the way.
TylerL is offline Find More Posts by TylerL
Old Jan 30, 2013, 03:21 PM
Sky Pilot
Victorville, CA
Joined Jun 2006
Yes, the in-line resistor is simple but it requires another step in connecting. You must connect the resistor plug first and then the main power plug. You must also disconnect both plugs when finished. On the Jeti unit, it is one step. Once you unplug the Jeti plug the power is off. Also, with the in-line resistor, you must make sure that you don't forget to attach the main plug before you start charging or you can burn out the resistor. Not trying to dissuade you, just adding some info.
Old Jan 30, 2013, 05:22 PM
TylerL is offline
Joined Nov 2003
Esprit says that theoretically there is not a voltage limit on these spark arrestor bullet connections. They do have suggest Amperage limits, and the 5.5mm is rated at 150A. Since the iCharger has a maximum input limit of 65A I believe these will be fine.
Anyone disagree or have a word of caution?
Junsi, How large are the capacitors inside the 4010Duo that must be charged by the spark arrestor capacitors during the connection? Knowing the number and size of the internal iCharger capacitors would better help us determine if the 5.5mm connector is enough. Esprit says they make up to an 8mm connector with more capacitors built in. These larger units can handle 300A, but more importantly they gather and pass through a larger volume of energy to the internal charger capacitors.
These connectors were designed to load the caps in ESC's, but I bet there is more capacity bank inside the iCharger.
Old Jan 30, 2013, 05:45 PM
Sky Pilot
Victorville, CA
Joined Jun 2006
The connector is a two part unit. The first thing the bullet touches is a ring that is separated from the female connector by a resistor. As soon as the bullet touches a charge is sent to caps in the charger. It only takes a moment for the caps to charge enough to stop the spark. Once the plug is inserted the rest of the way, the resistor is shorted out and no longer in the circuit. Those 5.5mm plugs will handle way more than you will be drawing with that charger.
Old Jan 30, 2013, 06:03 PM
So. Cal.
Note that the parallel connector can be a very small (and cheap) connector since it carries very little load. JST connectors can be had for pennies. The resistors are pennies as well. An extremely effective parallel spark arrest connector can be assembled for well less than $1.
Mark
Old Jan 30, 2013, 09:38 PM
mdv is online now
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
Mark
Seems like this should have been incorporated into the charger
mdv is online now Find More Posts by mdv
Old Jan 31, 2013, 04:07 AM
junsi is offline
Find More Posts by junsi
iCharger
junsi's Avatar
Joined Mar 2007
The capacitors inside the 4010Duo are 7*220u/63V.
Junsi
junsi is offline Find More Posts by junsi
Old Jan 31, 2013, 12:51 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Junsi, I'm getting an error 0801 on channel 1 from time to time: thoughts?
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jan 31, 2013, 08:51 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
Have you upgraded to the latest version beta 4?
Junsi
Old Jan 31, 2013, 08:53 PM
Greenland
Joined Mar 2012
Junsi
No. What if it fails?
Old Jan 31, 2013, 09:13 PM
junsi is offline
iCharger
junsi's Avatar
Joined Mar 2007
You can fix this error via upgrading, see details about the update notes in first post.
Junsi
Old Jan 31, 2013, 09:15 PM
Greenland
Joined Mar 2012
But what if the attempt bricks the charger?
And what is the rollover function?
Old Jan 31, 2013, 10:44 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I guess the quality stopped oozing on this thing?
Ohmic is offline Find More Posts by Ohmic
Article iCharger 4010Duo - Review CSpaced Batteries and Chargers 250 Oct 06, 2015 09:48 AM
Question What else has Jack been hiding from us? Newtron North Coast Electric Flyers 2 Mar 05, 2012 11:09 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 09:21 AM
Sold message has been deleted sonicboom24 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 01:34 PM
