Jan 04, 2013, 01:42 AM
United States, NC, Lexington
Joined Jul 2012
Safety reminder! Remove the prop before servicing your plane!
Well, I relearned a valuable lesson tonight, and one that I already knew and should've known better than to do. Always, Always and ALWAYS remove the prop before you work on you're plane and make extra sure you unplug the battery before you turn off the transmitter! Not doing so can be painful and expensive! It sure was for me tonight. I had just finished replacing a servo in my Mini Funtana and committed 2 No-No's. Number 1, I didn't take the prop off before working on and powering up to do a test with the new servo, and #2, I failed to unplug the battery before I turned off the TX, which in turn caused the motor to power up to wide open! I knew better than to do either one but I had worked on planes so much the last several months that I had gotten lax and didn't even think about the dangers of a spinning prop. I even had the plane sitting in a PVC stand and it still took off, stand and all!! Things happened so fast that my natural reflex was to grab the plane, and when I did, the prop struck me right in the wrist! It cut me about a inch and a half long and to the bone. 1 inch further to the left and it would've hit the artery and then I would have really been in trouble! Needless to say, I've spent the last 2 1/2 hours at the hospital getting stitched up. It took 5 or 6 stitches or more (can't see how many for the bandage) to close the wound. I just wanted to post my accident with the hopes that it will be a heads up to a new person to the hobby ( or even a seasoned pilot) about what can and will happen by being careless! Be careful guys and gals!
